Cameras & Photography Because there aren't already enough ways to share photos...
Nikon D80
Old Nov 17, 2006 | 08:42 PM
Neech's Avatar
At least it's not Jersey
Nikon D80
So this camera seems the ideal choice for me. Features, quality and price are all what I'm looking for in a SLR.
Now I need the pro and cons from those who have more experience. From what you've all read and maybe have had first hand with the camera, what can you tell me? Is it a good choice?
Am I over looking something with the same qualities and in the same price range?
Old Nov 17, 2006 | 10:07 PM
svtmike's Avatar
The Sony Alpha and the new Rebel XTi are both in the same price range with similar specifications. I'd go with the Nikon purely for the ergonomics myself, but I've been using Nikon DSLRs for a few years now. I assume you've read and re-read the dpreview.com review of all of these.
Lens choices are good and the Nikon Creative Lighting System is really nice if you're going to get into flash photography.
Mike
Old Nov 17, 2006 | 10:24 PM
Dan Martin's Avatar
Photography Nerd
Check out the Pentax K10D as well as the others mentioned. I love Pentax's unique lens lineup. That pancake 40 with the k10d would be such a beautiful walk-around setup.
Old Nov 18, 2006 | 07:01 PM
Neech's Avatar
Cool, thanks guys.
The Pentax is one manufacturer I never even checked out. I'll give it a look.
Old Nov 20, 2006 | 02:29 PM
khiyal's Avatar
I have always been a Nikon person so my response will definitely be biased towards Nikon. However, read these excellent reviews and decide for yourself:
*** The best review site: http://www.kenrockwell.com/nikon/d80.htm
http://www.imaging-resource.com/PRODS/D80/D80A.HTM
http://www.steves-digicams.com/2006_...nikon_d80.html
PS: I just got one for myself.
Old Nov 20, 2006 | 03:41 PM
Dan Martin's Avatar
Photography Nerd
Originally Posted by khiyal
Ken's site is a good one.... if you want to read biased reviews of Nikon gear.
Some curious observations of his 30D review:
Body Construction:
"The 30D is a well made, lightweight and reasonably solid camera that's the fastest in its category. This category, as defined by me, is plastic DSLRs. The Nikon D200 is as fast, but it's at the bottom of the sealed metal pro camera category and is a lot heavier and more expensive."
The 30D is magnesium, not plastic. The D200 is made from Aluminum, which of course is heavier than magnesium, hence the camera is heavier.
"(white balance) fine tuning is only deep in a menu, and setting a custom manual white balance is even trickier."
I don't know how it could be any easier to adjust. You just have to go to the white balance menu and tweak it to whatever value you want. To set a custom balance, you take a picture of a grey card or an expodisk, then go to the "Set custom white balance" menu option. How is the process easier on a D200?
Or, you could just shoot RAW and not worry about it at all.
Shots remaining display:
"The bad news is it can't read over 999. Nikons will read "2.7k" if you have 2,700 shots left."
Is this really a problem? I'd need a 10GB card installed before I hit that limit. Oh, I forgot, he only shoots JPG...
Pop-up flash:
"Slow sync isn't available in Program mode. I think you need to use one of the idiot modes or Manual to get it. This is too bad: I always shoot my Nikons in Program, and set the slowest flash shutter speed to about 1/30 or 1/15 to let in ambient light."
Why on earth is he using Program mode for flash work? He might as well just leave it on green box mode if he's not going to use manual.
There are only two flash modes: regular and high speed. In some of the auto modes, it will choose a longer shutter speed and fire a low-power fill flash in darker situations. I guess this is what he's calls slow speed sync. In manual mode you get full control of the balance between flash power and ambient light. As good as a camera is, it can never be as good as your eye when deciding how much flash to use. If you're using flash, use manual mode. Period.
My biggest concern with the 30D I used was that its LCD's white-point was a bit greenish-cyan. This made it impossible to use the LCD for color adjustments while shooting. The 20D's LCD is smaller, but its colors are fine.
I can't argue if his LCD had an issue or not, but I can say mine is fine. The bigger question is why is he adjusting colors on his camera? Who does that? I guess he must be the one guy who actually uses the direct print feature on the 5D.
The top LCD goes to sleep when the 30D does after a minute. You have to tap the shutter to wake it up to see your settings.
This is completely customizable. If you want, you can set up the camera to stay awake until the battery is dead.
Anyhow, this is pretty off-topic for a D80 thread, but this is the first time I've ever seen his 30D review. Like his other Canon reviews, I'd say he's pretty uninformed. He should read the manual that comes with the body, because most of his gripes could be solved easily. There's nothing wrong with being a site that only reviews Nikon gear. He should stick with what he knows best.
If you'd like an equally-biased site for Canon gear, The Digital Picture is quite good. He owns every piece of gear he reviews (practically the entire Canon lineup) and he's not affraid to say something is crap when it is crap.
Old Nov 20, 2006 | 03:45 PM
srika's Avatar
Moderator Alumnus
^^ there are a good number of people on the net that think KR doesn't know what he's talking about... and I have to agree to some extent - some of the things he writes make me ..
Old Nov 20, 2006 | 03:50 PM
dom's Avatar
dom
I know absolutely nothing about photography and even I knew you shouldn't be adjusting pics via the LCD. Thats common sense.
Old Nov 20, 2006 | 03:54 PM
dom's Avatar
dom
How can that review possibly be taken seriously?
srika
Jul 27, 2007 05:56 PM
evilone
Oct 31, 2006 04:12 PM
PixelHarmony
May 19, 2006 02:12 AM
datboynamsays
May 4, 2006 01:24 PM
