Cameras & Photography Because there aren't already enough ways to share photos...
multi-photo merge tutorial
Old Jun 28, 2007 | 02:01 AM
bug230's Avatar
mushroom mushroom
Does any one know of a tutorial illustrating the proper technique to merge two photos using Photoshop? I believe you use the channel function?
For example I want to merge these two photos. Use the photo where the furniture is exposed properly, and merge it with the other photo where outside the windows are exposed properly.
Old Jun 28, 2007 | 08:58 AM
Dan Martin's Avatar
Photography Nerd
Your best bet would be to use a program called Photomatix to do the HDR blend. However, the exposure difference between the two images above is too extreme for a natural looking blend. For this type of shot I would take about 5 exposures spaced 1 stop apart. Something like +1, 0, -1, -2, -3 would work well here.
Old Jun 28, 2007 | 10:39 AM
Bdog's Avatar
Not Registered
to what Dan said.
How I merge photos is just open both, then layer one over the other. Cut the Opacity on the top layer down and erase what you don't need. I gave yours a quick shot at work, but this one is hard because of the drastic exposure changes inside the house. You would have to take a little more time and adjust everything up front then merge the photos. The very tops of the glass in the windows need some work on mine.
Old Jun 28, 2007 | 11:13 AM
NumberFive's Avatar
Involuntary Karatechopper
^ looking 1000x better already! The shine in the bottom right is distracting, though... any way you can bring back the detail from the darker photo?
Old Jun 28, 2007 | 12:06 PM
Billiam's Avatar
Big Block go VROOOM!
If you're going the way of merging via layers, you're better off using layer masks. When you do this, you're merely hiding or revealing what you want and not actually removing any image data from your layers like you are when you erase.
As Dan and Bdog have said though, you'd want to use HDR tools and techniques for merging a shot like this. There are some situations though where merging via layers can be more efficient. Think of a sunset landscape shot with a well-defined horizon. You could shoot one exposure for the sky and one for the ground.
Old Jun 28, 2007 | 12:13 PM
Bdog's Avatar
Not Registered
Little better?
Old Jun 28, 2007 | 01:40 PM
NumberFive's Avatar
Yeah, that's more like it! It might still need some tweaking to get it to that reddish-brown color of the wood (color balance to add more magenta/red, maybe?).
I'm really an amateur at this stuff though, so it looks great to me already.
Old Jun 28, 2007 | 02:30 PM
danny25's Avatar
Bdog, you use Photomatix to do that?
Old Jun 28, 2007 | 04:50 PM
bug230's Avatar
mushroom mushroom
Thank you for all the help. I'll have to reshoot the inside of the house again and give it a whirl.
First of all I'm a beginner in the photography world. I understand the basics but I feel that my learning curve is evolving nicely. I just purchased the Sony a100 a couple of weeks ago and I have A LOT to learn.
You all have made me a true believer of the HDR technique. I just downloaded the demo version of Photomatix. I took this of my Vizsla pup to test the technique out and I'm amazed. I'll have to get the full expedition of Photomatix to optimize its full potential.
Top using HDR / Bottom single exposure
Old Jun 28, 2007 | 05:16 PM
jupitersolo's Avatar
nnInn
I haven't read yet, but you may want to.
http://stuckincustoms.com/?p=548
Old Jun 28, 2007 | 05:44 PM
srika's Avatar
Moderator Alumnus
the part about doing HDR from a single RAW file is rather stimulating... :P
Old Jun 28, 2007 | 07:38 PM
Bdog's Avatar
Not Registered
Photoshop CS2 for this, I need to get into HDR and look into the Photomatix plugin and try it.
ibGTV
Sep 28, 2015 03:40 AM
Rob144
Sep 21, 2015 08:18 AM
HeloDown
Sep 8, 2015 06:51 PM
skyeflye
45
Jan 23, 2011 11:51 AM
