Cameras & Photography Because there aren't already enough ways to share photos...
HD Camcorder
Old Jun 13, 2008 | 09:54 AM
  #41
Billiam's Avatar
Big Block go VROOOM!
Originally Posted by Sarlacc
camcorder to mac....import straight in to iMovie....iMovie does the rest including making the DVDs.
Couldnt be easier.
Actually it is if you have a Blu-ray player. Shoot on 4GB cards, put card in reader, disk image card to standard 4 GB DVD, insert in Blu-ray player, watch in full hi-def glory.
Old Jun 13, 2008 | 09:55 AM
  #42
dom's Avatar
dom
Couldnt be easier.
How long does that process take?
But still too much to spend IMO. Of course my wife doesn't bring home a mill a year so.....
Old Jun 13, 2008 | 10:10 AM
  #43
Sarlacc's Avatar
The Third Ball
If its anything like dumping P2 cards or other flash media, only about a minute per gig.
Which is honestly nothing and WAY faster then digitizing tape of any format.
Old Jun 13, 2008 | 10:33 AM
  #44
Billiam's Avatar
I think you may be a little spoiled dude. The DVCPRO (HD) stuff you mess around with is probably supported natively on your Mac from your installation of FCP. Not the case with AVCHD on the Mac. It has to be transcoded into something when "imported." For an out of the box Mac, this will of course be AIC. That transocding process is generally going to take 1.5x to 2.5x real time.
Old Jun 13, 2008 | 10:59 AM
  #45
Sarlacc's Avatar
The Third Ball
It gets put into a quicktime wrapper.
But its a similar process when importing straight into FCP since, the native P2 format has to be rewrapped. I dont remember that taking too much longer, but I never straight import. I just transfer footage and import later. Either way I'd be surprised if it was 2.5x longer...maybe 1.5x
Old Jun 13, 2008 | 11:02 AM
  #46
Moog-Type-S's Avatar
The sizzle in the Steak
Originally Posted by Billiam
One minor warning on the Sony SR11/12. They have a 10K foot altitude limit due to the hard drive.
CRAP!!!! So I can't take it on my Everest climb?!?!?!!?
Old Jun 13, 2008 | 11:10 AM
  #47
Billiam's Avatar
My experience so far with the AVCHD material has more often than not been in the range of 1.5x or less. I have had some footage with lots of motion though that took about 2-2.5x. The behavior was the same for transcoding to both AIC and ProRes 422 so I'm guessing it's more to do with the variable bit rate nature of the source compression than the destination format.
Old Jun 13, 2008 | 11:16 AM
  #48
Sarlacc's Avatar
The Third Ball
interesting, and a bummer.
Either way...it is still WAY less time consuming then digitizing a tape.
Old Jun 13, 2008 | 11:19 AM
  #49
Billiam's Avatar
And infinitely more convenient to archive.
Old Jun 13, 2008 | 11:20 AM
  #50
Mizouse's Avatar
Old Jun 13, 2008 | 11:24 AM
  #51
Sarlacc's Avatar
The Third Ball
Originally Posted by Mizouse
why dont you go take some more pics where you over accentuate chicks huge noses, they will love you for it.
Old Jun 13, 2008 | 11:41 AM
  #52
Mizouse's Avatar
Old Jun 13, 2008 | 11:53 AM
  #53
Whiskers's Avatar
Go Giants
Thanks for the info....
Old Jun 13, 2008 | 11:57 AM
  #54
Whiskers's Avatar
Go Giants
I want something fairly small though and I'm more concerned over easy of use then picture quality.
Old Jun 13, 2008 | 12:00 PM
  #55
dom's Avatar
dom
Standard def Flash FTW. They are tiny.
I figured you're concerns were similar to mine. I'd buy a DVD cam if they weren't so big (relatively speaking) and fairly unrelaible.
Old Jun 13, 2008 | 12:11 PM
  #56
Sarlacc's Avatar
The Third Ball
The one I linked you to is tiny...helps if you actually click on it.
Old Jun 13, 2008 | 12:15 PM
  #57
Whiskers's Avatar
Go Giants
Yep, more then likely....
  #58
Whiskers's Avatar
Go Giants
Its hard to pick up things on the Internet...
Old Jun 13, 2008 | 12:19 PM
  #59
Sarlacc's Avatar
The Third Ball
They state the dimensions.
You also have the model number now, you can always go to a store and find it, im sure they make a PAL version for europe.
Its like people become helpless on here.
Old Jun 13, 2008 | 12:23 PM
  #60
Whiskers's Avatar
Go Giants
People just aren't as egotistical as you are....
In any case, $1100 is not what I was looking to spend...Dom had my needs correctly identified, so I most likely will get a small flash based model around $400...
Old Jun 13, 2008 | 12:32 PM
  #61
Sarlacc's Avatar
The Third Ball
literacy and common sense have nothing to do with ego.
Old Jun 13, 2008 | 02:20 PM
  #62
dom's Avatar
dom
I don't know much about camcorders. But what is the benefit of HD based over flash based?
I can't think of one.
Old Jun 13, 2008 | 02:43 PM
  #63
Billiam's Avatar
Assuming the flash and hard drive based camearas both use the same video format such as AVCHD, then the only differences are the obvious ones. Capacity, mechanical reliability, etc...
Old Jun 13, 2008 | 02:49 PM
  #64
dom's Avatar
dom
Capacity is higher on the flash and reliability should be better (less moving parts) so.....
I know both Canon HD Flash camcorders use AVCHD so I'd imagine so does everyone else.
I guess this explanation is as simple as knowing that Billiam bought a HD flash Cam.
Old Jun 13, 2008 | 02:55 PM
  #65
jupitersolo's Avatar
nnInn
I bought one of the first Sony AVCHD hard drive cameras. I've had nothing wrong with it, but to do it now, I go with the memory card version, less to break and easy to replace than the hard drive.
Old Jun 13, 2008 | 03:16 PM
  #66
Billiam's Avatar
Ummmmm.... capacity is higher on the hard drive cameras. Is Mr. Dom's brain already living out the weekend?
Old Jun 13, 2008 | 03:32 PM
  #67
Sarlacc's Avatar
The Third Ball
Most hard drive based cameras can also record to flash memory. For reliability sake, flash is always preferred to hard drive.
Old Jun 13, 2008 | 06:37 PM
  #68
dom's Avatar
dom
Should have explained that one....
16 built in + 16 external + 16 external + 16.... you get my point.
The potential for more capacity is there.
Old Jul 3, 2008 | 02:58 PM
  #69
dom's Avatar
dom
Just picked up a FS100 and a 8 gig card. Hope it holds me over for a couple years.
Old Jul 3, 2008 | 03:28 PM
  #70
Whiskers's Avatar
Go Giants
I got this Panasonic - http://www.bestbuy.com/site/olspage....=1201307507741
While nice and small, they pic quality is meh and battery sucks....Almost returned it, but 15% restocking fee stopped me...
Old Jul 3, 2008 | 03:33 PM
  #71
nnInn
That 8 gb will get you about two hours at best resolution.
  #72
Billiam's Avatar
For anyone that's still kicking these around, Sony recently announced their entry into the flash-based AVCHD market. I believe the model number is HDR-CX12. Essentially it's the flash-based take on the SR11/12. Or so I've read.
Old Jul 3, 2008 | 03:36 PM
  #73
dom's Avatar
dom
Yup. But ~95 minutes of battery life. Just waiting for SterlingTek to release an equivalent battery.
Old Jul 3, 2008 | 03:54 PM
  #74
nnInn
No, not a bad thing, for something smaller than a stick of gum. Carrying a couple around is no problem. Better than MDv and DVD, I think even better than hard drive cameras, which I have one of.
Old Jul 3, 2008 | 03:58 PM
  #75
Billiam's Avatar
When I was researching my camera (HF100) I saw many complaints about the low battery capacity. When I actually got the camera in my hands though and felt how small and light the battery was, I thought it was actually pretty decent.
Old Jul 3, 2008 | 09:32 PM
  #76
Sarlacc's Avatar
The Third Ball
FS100 as in Firestore? My advice...return it. I hate those things and they have a decent failure rate. If I get on a job that wants them I refuse.
Old Jul 3, 2008 | 09:34 PM
  #77
Sarlacc's Avatar
The Third Ball
With camcorders its always a good idea to have 2-3 batteries depending on how much you plan on using throughout a day.
Whiskers...of the picture quality is meh...youre probably watching SD footage on a HD TV or high res monitor set to full screen.
Old Jul 3, 2008 | 10:04 PM
  #78
dom's Avatar
dom
? Firestore? Not sure what you mean.
Old Jul 3, 2008 | 10:15 PM
  #79
Sarlacc's Avatar
The Third Ball
Is the FS100 a hard disk based recorder that attaches to your camcorder?
There is something called the Firestore 100...that is just that.
Old Jul 3, 2008 | 10:22 PM
  #80
dom's Avatar
dom
No. Canon FS100 Flash Camcorder. You know I only buy Canon dude.
