Canon: Rumor Thread
#201
Received 2,787 Likes
i know its been posted but i want to post it in here too..
http://www.dpreview.com/news/1001/10...n70200isii.asp
Pre-CES 2010: Canon has released a successor to its professional workhorse fast telezoom, in the shape of the EF 70-200mm F2.8 L IS II USM. Although outwardly similar to its predecessor, the new lens features a revised optical design, incorporating a fluorite element and no fewer than 5 UD elements for the correction of chromatic aberrations. The minimum focus distance has been reduced to 1.2m, with a corresponding increase in maximum magnification to 0.21x. The mechanical design has also been modified, with the most obvious external change being a wider focusing ring. As usual for an L series design, the lens features dust- and drip-proof construction. It's also fully compatible with Canon's existing teleconverters and extension tubes.
Jump to:
* Press Release
* Specifications
Press release:
The new EF 70-200mm f/2.8L IS II USM – Canon’s essential, high-quality, telephoto zoom lens for professionals
5th January 2010 – Canon today adds to its acclaimed L-series with the launch of the new EF 70-200mm f/2.8L IS II USM telephoto zoom lens. The lens launches as the successor to the immensely popular EF 70-200mm f/2.8L IS USM, offering improved performance in every area.
True to the L-series’ heritage, the EF 70-200mm f/2.8L IS II USM delivers optical excellence in the most challenging situations. As well as a revamp of the internal optical system, the lens has also been structurally re-developed as a direct result of user feedback, making it as robust and reliable as it is optically advanced.
“Reuters’ photographers have used the EF 70-200mm f/2.8L IS USM for a number of years and it allows photographers a great level of flexibility,” said Reuters Production Editor Kevin Coombs. “The focal length, fast aperture and Image Stabilizer all contribute to it being a workhorse lens and you’ll find it in many professional photographers’ camera bags. I’m very much looking forward to seeing the improvements offered by the EF 70-200mm f/2.8L IS II USM.”
Premium quality, premium performance
The EF 70-200mm f/2.8L IS II USM features a re-designed optical system, consisting of 23 elements in 19 groups to deliver truly impressive results. A high-performance fluorite element is used at the heart of the lens path, coupled with no fewer than five ultra-low dispersion (UD) elements, drastically reducing chromatic aberration throughout the zoom range to produce high contrast images with edge-to-edge definition.
A high-speed Auto Focus (AF) system perfectly matches the abilities of the recently-launched EOS-1D Mark IV and EOS 7D Digital SLR (DSLR) cameras. The new model also features a ring-type USM AF motor, which combines with a new high-speed CPU and an optimised AF algorithm to make auto focusing both faster and quieter.
A reduced minimum focusing distance of 1.2 metres (3.9 ft) and improved 0.21x magnification will allow photographers to get closer to subjects without needing to swap lenses – greatly benefitting time-pressured news and events photographers who require flexibility. An updated Image Stabilizer mechanism also offers a shutter speed advantage equivalent to four-stops, reducing the effect of image blur resulting from camera shake in busy shooting environments.
Enhanced design, exceptional ease of use
As well as an update to the internal construction, the EF 70-200mm f/2.8L IS II USM features an enhanced external appearance to improve lens operation. The thickness of protruding exterior parts and switches has been significantly reduced, guarding against accidental switching and creating an improved overall look. The rubber focusing grip has also been redesigned and widened; with finely-patterned grooves making it easier to manually focus.
Being an L-series lens, the EF 70-200mm f/2.8L IS II USM is fully weatherproof, making it ideal for use in all weather conditions. The mount, focus mode switch and focusing ring all feature a completely dust and drip-proof structure, preventing dust or water from getting inside the camera and lens when used with accompanying weatherproof EOS bodies. The lens has been designed to stand up to the daily wear and tear of professional usage, making it a highly durable, reliable lens for use day-to-day by professional photographers.
High quality L-series accessories
The EF 70-200mm f/2.8L IS II USM is supplied with several accessories, including the new ET-87 Lens Hood and the Ring-Type Tripod Collar B (W). A brand new Lens Case LZ1326 is also included as standard, offering quick and easy access when users need to switch lenses in time-pressured situations.
Compatibility with a range of optional Canon accessories also allows users to pair the EF 70-200mm f/2.8L IS II USM with the Lens Extender EF 1.4x II, Lens Extender EF 2x II, Extension Tube EF 12 II, Extension Tube EF 25 II, and 77mm filters.
Jump to:
* Press Release
* Specifications
Press release:
![](http://www.dpreview.com/news/1001/canon/70200ii-slant.jpg)
#202
ohh and the latest rumor on the 1Ds mk IV puts it at 32mp...
![Bored](https://acurazine.com/forums/images/smilies/bored.gif)
#203
is learning to moonwalk i
Sounds like nice improvements to an already great lens. IQ now should surpass the f4 version.
Oddly enough, the line that really caught my eye was:
Did I miss that announcement or am I confusing the 1D with the 1Ds?
#204
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
#207
Firmware for 5DII is rumored for feb.
Also so is the 1DsmkIV
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#208
I miss my 03 CL-S :(
From inside the 1D Mark IV 1.0.6 Firmware
52b2b6 [GYO]CameraModleID = K252 = 500d
52b2d6 [GYO]CameraModleID = K215 = 1ds 3
52b2f2 [GYO]CameraModleID = K169 = 1d m3
52b30e [GYO]CameraModleID = K176 = 450d
52b32a [GYO]CameraModleID = K190 = 40d
52b346 [GYO]CameraModleID = K218 = 5d m2
52b362 [GYO]CameraModleID = K250 = 7d
52b56e [GYO]CameraModleID = K270 = unknown!!!
52b58a [GYO]CameraModleID = K261 = 50d
52b5a6 [GYO]CameraModleID = K281 = 1d m4
52b5c2 [GYO]CameraModleID = K287 = unknown !!!
52b5de [GYO]CameraModleID = K254 = 1000d
52b5fa [GYO]CameraModleID = OTHER
I think I'm finally gonna be getting my 60D in a few months!
#209
There is also a rumor that the 5DII firmware is not in feb and won't have 720p
#210
![Whistle](https://acurazine.com/forums/images/smilies/whistle.gif)
#212
And not funny man. Seriously.
#213
#214
Canon rebel t2i rumor
Canon Rebel T2i [CR2]
February 1st, 2010 by Canon Rumors
Next week
The new Rebel coming next week is apparently going to be called the “T2i”.
Spec List
New LCD (Even Higher Resolution)
Selectable FPS (Video)
New build quality and shape for a Rebel
No articulating screen
New battery LP-E8
New battery grip
CR Editorial about Articulating Screens
I don’t think Canon will introduce an articulating screen until we have a faster liveview autofocus technology. There are situations that an articulating screen is handy on an SLR with the current liveview performance, however I don’t think it’s an issue for a majority of SLR users.
Canon has probably focus grouped this feature to death.
That’s just my 2 cents.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
cr
Next week
Spec List
New battery LP-E8
New battery grip
cr
#216
That's all I saw
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#217
was i the one that said that? dont think i was.
and besides i wasn't criticizing it, if you wanted to "get even" or whatever you're doing, pull up a post where i bitch about it.
#219
I didn't mean to insinuate that you said it. In fact, if you HAD said it, I probably would not have said it in here. It was more of a "global" reaction.
#220
Stock information
The stock system at a large retail chain appears to have struck again.
Both cameras have a street date of March 28, 2010
SD1200 “A” (SD1200 Replacement)
12mp
3x Zoom
2.5″ LCD
UPC: 013803119534
Model: 4214B001
SD780 “A” (SD780 Replacement)
12mp
4x Zoom
2.7″ LCD
UPC: 013803119251
Model: 4181B001
There was no mention of any other camera, including the rumored T2i. More info will be sent my way if it’s found.
cr
12mp
3x Zoom
2.5″ LCD
UPC: 013803119534
Model: 4214B001
12mp
4x Zoom
2.7″ LCD
UPC: 013803119251
Model: 4181B001
cr
#221
60D rumors
do not want...
Specifications:
18mp
6.3fps
DIGIC IV
24p & 30p HD (It lists 36fps, I’m assuming typo)
Announced February 4, 2010.
18mp
6.3fps
DIGIC IV
#222
Wait... That's tomorrow... Yea I don't see that happening.
#223
Whatever, I want. I was hoping for a better 15mp sensor rather than 18, but whatever. It'll be better than my Rebel which is starting to get on my nerves.
If it comes out with those specs, I'll buy it when it's available. These rumors are the only think keeping me from buying a 50D in March.
#224
Well if it's true i only have to wait until 9pm
#226
![](http://www.canonrumors.com/wp-content/uploads/2010/02/canon-camera-announcement-8-february-0.jpg)
#227
waiting for the 90D heard its gonna be sick
#228
Earth-bound misfit
![Crazy](https://acurazine.com/forums/images/smilies/crazy.gif)
#230
Originally Posted by Canon Rumors
have people forgotten that they can go get a video camera if they want to be filmmakers? at this rate, in 10 years canon will be bragging about their “dedicated camera button” on their dslr’s.
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
#231
First rumor!
I’ve been told today that internally Canon has bumped the 5D Mark III launch deadline ahead about 6 months. With the limitations of the Mark II as far as adding features via firmware (more on that in a second), Canon feels the camera needs an update to utilize the features of current dSLR’s.
The email said we can rest assured that Canon will not be on a 3 year product cycle for the 5D line. The source went on to say the 3D is a myth, there are no plans for it currently. The 5D Mark III would get the full frame and 7D autofocus system and a better featureset for video.
720p & 60fps
A clarification. I’m told that Canon is omitting 720p and 60fps from the 5D Mark II firmware update. The firmware update will have the 24/25p update.
*UPDATE*
Before people start cancelling orders. I still think this is a late 2010/early 2011 camera and the rumor is CR1.
cr
720p & 60fps
*UPDATE*
cr
#232
The Third Ball
Received 4,937 Likes
#233
![Run](https://acurazine.com/forums/images/smilies/run.gif)
James Cameron has hooked up with Canon to develop the next 5DMIV. That's right everyone, you'll be seeing Avatar-like tech along with a new mind blowing sensor.
#235
that's all I need to hear to convince me to wait for the next 5D!
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
#236
http://www.usa.canon.com/templatedat...2_full_hd.html
CANON ANNOUNCES MPEG-2 FULL HD (4:2:2) FILE-BASED RECORDING CODEC FOR UPCOMING PROFESSIONAL VIDEO CAMERA
New Canon MPEG-2 Codec Promises Improved Color Resolution and Compatibility With Industry-Standard Editing & Processing Software
LAKE SUCCESS, N.Y., February 2, 2010 – Canon U.S.A., Inc., a leader in digital imaging, announced today the Company has adopted an MPEG-2 Full HD (4:2:2) file-based recording codec for a new file-based professional video camera currently under development. The new Canon MPEG-2 codec will enable high-quality imaging and audio performance with up to 50 Mbps data recording and twice the color data of the HDV*1 profile format. File-based recording helps video operations realize greater efficiencies during post-production, making it an ideal format for many industry applications such as newsgathering, documentary filmmaking and event videography. The main features of the new Canon MPEG-2 codec include:
# MPEG-2 Full HD compression and 4:2:2 color sampling
The adoption of MPEG-2 Full HD (MPEG-2 4:2:2P@HL compliant) compression enables the recording of 1,920 x 1,080-pixel full high-definition video. Additionally, compared with the 4:2:0 profile format used in HDV and other standards, 4:2:2 color sampling offers twice the volume of color data, providing double the level of color resolution.
# Maximum 50 Mbps data recording
With approximately twice the data volume of HDV, the new codec supports higher resolution and increased color data to enable the recording of high-quality video.
# Industry-standard MXF*2 file format
MXF (Material eXchange Format) is a widely supported open source file format for the recording of video and audio and metadata, developed to suit the latest editing systems used by broadcasters.
Canon partners with major editing and processing software developers
To support the swift adoption of its new MPEG-2 Full HD (4:2:2) file-based recording codec, Canon is working in cooperation with Adobe Systems Incorporated, Apple Inc., Avid Technology, Inc. and Grass Valley to ensure compatibility with major editing and processing software programs widely used within the video imaging industry. Additionally, at future industry events, Canon intends to demonstrate the overall video-production workflow, from initial video capture to clip-trimming and final editing, with video clips stored in a file-based recording system and using industry-standard software applications.
Advantages of File-Based Recording
File-based recording enables video and audio data to be managed and stored by file, much in the same way as computer data. It supports efficiency throughout the production process, from initial video capture to final editing through the entire workflow. Additionally, file-based recording provides users with the flexibility to utilize different editing environments and workflow solutions without the restrictions associated with some other video recording formats, helping to reduce investment costs.
About Canon U.S.A., Inc.
Canon U.S.A., Inc., is a leading provider of consumer, business-to-business, and industrial digital imaging solutions. Its parent company, Canon Inc. (NYSE:CAJ), a top patent holder of technology, ranked fourth overall in the U.S. in 2009†, with global revenues of US $35 billion, is listed as number four in the computer industry on Fortune Magazine's World's Most Admired Companies 2009 list, and is on the 2009 BusinessWeek list of "100 Best Global Brands." Canon U.S.A. is committed to the highest levels of customer satisfaction and loyalty, providing 100 percent U.S.-based consumer service and support for all of the products it distributes. At Canon, we care because caring is essential to living together in harmony. Founded upon a corporate philosophy of Kyosei – "all people, regardless of race, religion or culture, harmoniously living and working together into the future" – Canon U.S.A. supports a number of social, youth, educational and other programs, including environmental and recycling initiatives. Additional information about these programs can be found at www.usa.canon.com/kyosei. To keep apprised of the latest news from Canon U.S.A., sign up for the Company's RSS news feed by visiting www.usa.canon.com/rss.
#237
THE NEW CANON REBEL T2i DIGITAL SLR TAKES ASPIRING PHOTOGRAPHERS
BEYOND THE STILL WITH ADVANCED VIDEO FEATURES
The Family Camera is Back, Introducing the EOS Rebel T2i Featuring a Large 18-Megapixel
CMOS Sensor and Full HD Video Recording with Selectable Frame Rates up to 30 fps
MISSISSAUGA, ON, February 8, 2010 – Canon Canada Inc., a leader in digital imaging, today introduced the new flagship model for the Company’s highly popular Rebel DSLR line: the Canon EOS Rebel T2i Digital SLR camera. Today’s photo enthusiast is looking for a camera that will grow with them as they learn, and that is a perfect description of the new EOS Rebel T2i Digital SLR camera. Retaining all of the traditional characteristics that have made the EOS Rebel series beloved by entry-level photographers and an industry best-seller, the new Rebel T2i succeeds in bridging the gap between an entry-level camera and a true pro-sumer camera.
The Rebel T2i Digital SLR camera includes a variety of new features for photographic assignments as varied as grabbing that action shot from the sidelines or creating memorable family portraits, including: 3.7 fps shooting, an ISO range of 100-6400 (expandable to 12,800), a 63-zone Dual Layer Metering System, and Canon’s DIGIC 4 Imaging Processor. There are some moments in our lives where video helps capture the moment better than a still image, and the Rebel T2i offers the best of both worlds with Full HD 1080p video as well as 18-megapixel still images. The Rebel T2i DSLR continues Canon’s industry-leading trend in Full HD DSLR video capture with manual exposure control, selectable frame rates and a new external microphone input. There is also a new feature for standard definition recording, Movie Crop, which provides an approximate 7x additional zoom with no loss of image quality when shooting SD quality video.
“There is no question that HD video is the biggest trend in DSLR technology and because of this we are seeing the creativity of still photographers transferring to the moving image. Still photographers are using the various lenses and accessories they are already familiar with to create amazing video footage,” stated Ian Macfarlane, Vice President and General Manager of the Consumer Imaging Group at Canon Canada Inc., a wholly owned subsidiary of Canon U.S.A., Inc. “Taking that HD video quality and putting it in the hands of entry-level photographers with cameras like our new EOS Rebel T2i, we are seeing a new generation of creative digital artists emerge.”
Lights, Rebel, Action – EOS HD Video
Canon’s EOS HD video capture has helped spark a major movement in digital imaging, empowering still photographers with the ability to experiment, learn and capture stunning high-definition video through a variety of creative lenses. Continuing this imaging revolution, the new EOS Rebel T2i puts entry-level photographers on the frontline equipped with all the latest EOS HD video features including full HD video at 1920x1080 resolution, selectable frame rates, full manual exposure control and the visual options of interchangeable lenses. Manual video exposure control provides novice filmmakers with the image control they are accustomed to in a still camera, all while shooting professional-level cinematic video. Professional photographers utilize creative lighting, adjustable depth-of-field and a variety of lenses to create powerful still images and video footage, and these are exactly the tools that the new Rebel T2i gives to budding photo and video enthusiasts. Adding a new professional-level feature for EOS cameras, the Rebel T2i includes an Auto ISO function that works in all Creative Zone exposure modes including Manual where users can set a limit to the highest ISO the camera will use, enabling them to retain the lighting and look they desire for a scene. By setting an Auto ISO range, videographers can retain dark shadow areas and avoid blowing out highlight areas in a scene while still retaining the benefit of automatic ISO adjustments. The Rebel T2i DSLR captures video in both NTSC (National Television System Committee) and PAL (Phase Altering Line) standards at selectable frame rates including Full HD 1920 x 1080 at 30 (29.97), 25 or 24 (23.976) fps, and HD 1280 x 720 or Standard Definition 640 x 480 quality video, at 60 (59.94) or 50 fps.
For easier video recording operation and familiar functionality for beginners, the Rebel T2i’s autofocus can be operated before or during video recording by pressing the shutter button half-way down in video mode. Another feature debuting in the Rebel T2i is Canon’s new Movie Crop mode, where the user can achieve 7x magnification when shooting SD video for a significantly increased “telephoto” effect. Unlike the digital zoom feature found in many compact digital cameras, Canon’s new Movie Crop mode actually crops the image directly from the CMOS sensor at full SD resolution to preserve maximum image quality and provide additional zoom power. The new Movie Crop feature is especially helpful for achieving extra full resolution zoom power when filming youth sports, such as a child running to the furthest end of a field. For better sound quality when shooting video, the Rebel T2i DSLR includes an external stereo microphone jack, a first for an EOS Rebel model, in addition to its built-in monaural microphone. These audio and video features supplement a tremendous range of additional must-have video features in an entry-level Digital SLR camera.
For enhanced viewing pleasure and easy video sharing at home, the HDMI video-out capability of the Rebel T2i DSLR includes a new Consumer Electronics Control (CEC) compatibility which allows users to play back still or video files on a CEC-compliant HDTV, using the TV remote to control the camera when connected via HDMI interface.
Camera Feature Set
The EOS Rebel T2i DSLR features a newly developed 18-million-pixel Canon CMOS imaging sensor providing outstanding resolution and light sensitivity for amazing poster-sized prints with fine detail and stunning color. The camera exhibits exceptional low-noise performance incorporating many of the same technologies used to reduce noise in professional cameras such as the EOS 7D. The Rebel T2i camera's basic ISO range is an amazing 100~6400, and via a Custom Function, it can be extended to ISO 12,800. The outstanding ISO range combined with its noise reduction technology allows the Rebel T2i to capture outstanding low-light pictures at events such as candlelit birthday celebrations or recitals where flash photography may be prohibited.
The camera provides 3.7 fps continuous shooting for still photos, making it the fastest shooting Rebel model to date and enabling users to capture that great image of a little leaguer’s first swing. The camera features Canon’s proprietary 63-zone dual-layer metering system offering intelligent Evaluative metering with much finer segmentation than any previous EOS Rebel model. The new Rebel T2i also has an expanded ± 3 EV exposure compensation range allowing for much more versatility when shooting in extremely bright or dark environments; or when shooting HDR (high dynamic range) images.
The Rebel T2i DSLR includes a number of professional-level user-selectable Canon image processing features to enhance the image quality of in-camera JPEG files, and to tag RAW images for processing later through Canon’s Digital Photo Professional software (included with the camera). These features include Canon’s Auto Lighting Optimizer to enhance shadow detail and add contrast to “flat” scenes, Highlight Tone Priority adding up to one stop of detail in bright highlight areas, Peripheral Illumination Correction for automatic correction of vignetting, High ISO Noise Reduction with four user-selectable settings, and Long Exposure Noise Reduction applied to exposures one second or longer. These Canon image enhancements provide new photographers with professional quality automatic image correction on JPEG files right out of the camera.
The EOS Rebel T2i digital camera includes a new enhanced 7.6-centimetre (3-inch) LCD monitor featuring 1.04 million dots with a wide 3:2 aspect ratio, wider than previous EOS models. The Rebel T2i camera's LCD monitor can display a full-screen video image utilizing the entire screen during playback. For maximum storage capacity the new EOS Rebel T2i Digital SLR camera is the first EOS model to support SDXC memory cards. With all the new and exciting features of the EOS Rebel T2i, the Rebel series continues to provide great Canon features such as Live View, a built-in pop-up flash, and the EOS integrated cleaning system, as well as compatibility with Canon EX-series Speedlites and Canon EF and EF-S lenses allowing users to fully explore multiple creative photographic possibilities. The new EOS Rebel T2i Digital SLR camera is also compatible with Canon’s new BG-E8 battery grip and new RC-6 wireless remote control for both still images and video capture.
Pricing and Availability
The Canon EOS Rebel T2i Digital SLR camera is scheduled to be delivered to Canadian dealers in early March, and will be sold in a body-only configuration at an estimated retail price of $899.99. It will also be offered in kit versions with Canon’s EF-S 18-55mm f/3.5-5.6 IS zoom lens at an estimated retail price of $999.99 as well as with Canon’s EF-S 18-135mm f/3.5-5.6 IS zoom lens at an estimated retail price of $1399.99.
Camera Feature Set
#239
#240
The Third Ball
yawn.
not the announcement I was hoping for, Canon, you bore me once again.
