Canon: Rumor Thread
#401
Earth-bound misfit
*fingers firmly planted in ears* Lalalalalala I can not hear this!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#402
A Very Detailed 1D Mark V Spec List [CR1]
850Share
![](http://www.canonrumors.com/wp-content/themes/magnet/scripts/timthumb.php?src=http://www.canonrumors.com/wp-content/uploads/2011/08/1d4.jpg&a=t&h=100&w=200)
1D Mark V
It’s rare to see a spec list such as the one below. It goes down the same path as most information coming in. The 1D & 1Ds will be merged into the 1D Mark V. The 1Ds will be replaced by a more studio oriented camera and called something else.
Specs of the 1D MK V
- August 6, 2011
- 1D Mark V
- Follow on our forum
850Share
1D Mark V
- Image ratio w:h 3:2
- Effective pixels 32,2 megapixels
- Sensor photo detectors 32.5 megapixels
- Sensor size Full frame (36 x 24 mm)
- Sensor type CMOS
- Processor Digic 5
- ISO 100, 200, 400, 800, 1600, 3200, 6400, 12800 (50, 25600, 51200 and 102400 Hi)
- White balance presets 8
- Custom white balance Yes
- Image stabilization No
- Uncompressed format RAW JPEG quality levels Fine,
- Normal (can have ratios programmed)
- Autofocus Contrast Detect (sensor), Phase Detect, Multi-area, Selective single-point, Single, Continuous, Face Detection, Live View
- Digital zoom No
- Manual focus Yes
- Number of focus points 45
- Lens mount Canon EF mount
- Focal length multiplier 1.0×
- Articulated LCD Fixed
- Screen size 3.2″
- Screen dots 1.200,000
- Touch screen No Live view Yes
- Viewfinder type Optical (pentaprism)
- Viewfinder coverage 100 %
- Viewfinder magnification 0.76×
- Minimum shutter speed 30 sec
- Maximum shutter speed 1/8000 sec
- Aperture priority Yes
- Shutter priority Yes
- Manual exposure mode Yes
- Subject / scene modes No
- Built-in flash No
- External flash Yes (Hot-shoe plus Sync connector)
- Flash modes External / Radio Controlled
- Continuous drive Yes (9.1 fps)
- Self-timer Yes (2 or 10 sec)
- Metering modes Multi Center-weighted, Spot
- Exposure compensation ±3 EV (at 1/3 EV, 1/2 EV steps)
- AE Bracketing ±3 (3 frames at 1/3 EV, 1/2 EV steps)
- WB Bracketing Yes (3 frames in either blue/amber or magenta/green axis)
- Format H.264
- Audio channels Stereo
- Clips Yes (1920 x 1080 (120, 60, 30, 25, 24 fps, 1280 x 720 (120, 60, 50 fps), 640 x 480 (120, 60, 50 fps))
- HD Modes 1920 x 1080 (120, 60, 30, 25, 24 fps, 1280 x 720 (120, 60, 50 fps), 640 x 480 (120, 60, 50 fps) FPS 1920 x 1080 (120, 60, 30, 25, 24 fps, 1280 x 720 (120, 60, 50 fps), 640 x 480 (120, 60, 50 fps)
- Storage types Compact Flash (Type I or II), UDMA, SD/SDHC card
- Storage included None
- USB USB 3.0
- HDMI Yes
- Remote control Yes (N3 connector)
- Environmentally sealed Yes
- Battery Battery Pack
- Battery description Lithium-Ion LP-E4 rechargeable battery & charger
- Battery Life (CIPA) 1500
- Weight (inc. batteries) 1228 g
- Dimensions 157 x 159 x 80 mm
- Orientation sensor Yes
- Timelapse recording Yes (by cable and PC)
#403
Received 2,787 Likes
A Breakdown of Rumors
AUGUST 8, 2011 1D MARK V, CANON 1DS MARK 4, CANON 5D MARK III FOLLOW ON OUR FORUM
Share
Opinion
Below is an update of the current state of rumors surrounding camera bodies. Most of what’s below is opinion, or clarification of what’s going on.
1Ds Mark IV
I was told a long time ago that a 1Ds Mark IV (or similar) camera would not arrive until late 2011 or early 2012 and would be 40+ megapixels. It would be a “big departure” from the current 1Ds line.
There’s been no information on the line that I’d call factual yet, the information I have been told seems to lead to a new type of camera on top of the Canon lineup.
1D Mark V
We’ve heard a lot about the amalgamation of the 1D/1Ds line over the years. It’s been a lot stronger in the last 6 months. It was over 6 months ago that I was first told a new 1D would arrive before any 1Ds replacement.
I personally think most spec lists recently have been wish lists more than fact, however I post them anyway just in case. I suspect we’ll have better information in the coming week or so.
All signs point to this camera, more than any other.
5D Mark III
Everything I get now says it’s a 2012 camera. Most likely in the February timeframe.
There’s a lot of rumblings about the line splitting into 2 models, nothing concrete though. If this camera was coming this month, I believe we’d hear a lot more about it.
Share
Opinion
1Ds Mark IV
1D Mark V
5D Mark III
#404
#405
http://www.canonrumors.com/2011/09/1...ark-iii-cr0-5/
September 14, 2011
5D Mark III
Other bits of information from the same email.
Check the previous post for something I think is a bit more believable. I do hope some of you can point out any obvious flaws in this spec list that I have overlooked. Have fun!
cr
5D Mark III
- 24MP
- Pro grade AF (not 7D like)
- 2 stops better ISO than 5D mk II
- Digic V
- 6 fps
- New video codec, not Raw. MPEG 4:2:2, new video functions such as tracking focus in video mode
- Compact body with improved weather sealed
- Same introduction price as the predecessor
- 54MP (no low pass filter)
- Decent 6400 ISO performance
- Same AF as 1D Mark IV
- 14 stops DR
- 16 bit Raw file (mode to be confirmed)
- Digic V
- Limited new HD video function in comparison with the 5D III
- All current L lens can perform at the level of the 1Ds sensor resolution,there is no low pass filter in front of the sensor and there is digital on/off software switch to reduce moire.
- Video function in the new 1Ds is not as complete as the one on the 5D mk II and due the massive data reading of the sensor there is no MPEG 4:2:2 coded.
- It seems that in one of the prototype there was an option to shoot 16bit Raw files that this option cut down dramatically the fps.
- It’s rumored that Canon will also announced one zoom and 2 prime lens with the Ds camera.
cr
#406
CR0.5 thou....
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#407
is learning to moonwalk i
There are two Canon announcement events coming up soon:
Sept 22, 2011 - looks like this may be just copiers
:thumbsdow
http://www.canonrumors.com/2011/09/c...ember-22-2011/
Nov 3, 2011 - could be big, or could be![Lame](https://acurazine.com/forums/images/smilies/lame.gif)
http://www.engadget.com/2011/09/15/c...red-carpet-on/
![Yawn](https://acurazine.com/forums/images/smilies/yawn.gif)
#408
I shoot people
so close to the holidays, and that's just the announcements. Doesn't necessarily mean they'll be out for Christmas
#409
Moderator Alumnus
Canonrumors just posted a rumor indicating a Nikon D3s competitor is currently in production for october release.
If it has faster video autofocus it will be VERY hard to resist buying it.
- Frank
- Frank
#410
in case you missed it 4 days ago.. article itself is kinda dumb, it's been common knowledge that there are 5D3's out "in the wild", for at least a couple months now
New Canon 5D Mark III in the wild | EOSHD.com
Saturday, 24 September, 2011 03:16
There’s some pretty compelling evidence that the 5D Mk3 is out there.
![](https://i.imgur.com/gambr.jpg)
To be honest Canon are in no rush with the 1DS since the 5D Mk2 is more important and the 1D Mk4 relatively fresh in the memory. These cameras provided for 95% of people and the 1DS Mk3 was not a big seller. But Canon badly need an answer to Sony and Panasonic in the video market and so the evidence for the 4K camera is more compelling.
I think it will be EF mount not PL, although if there are two cameras announced it makes sense to do what Sony have done and do both mounts, possibly even a new mirrorless mount like Sony has on the E-mount FS100.
- Canon’s Tim Smith was seen at Hollywood rental house Birns and Sawyer testing a new camera, concealed from view with the whole thing under an NDA, he was said to be walking around holding 5D batteries (according to Wide Open Camera).
- There will be a stand set aside at Canon Pro Photo solutions in London for a new camera, this is on October 25th. EOSHD will be there for it.
- Canon USA are running a high profile Ron Howard EOS movie-making campaign which climaxes later this year with a short film shot on DSLRs by Howard. From the official press release - “These eight winning photos will become the basis and inspiration for a short film shot with Canon DSLR products that will premiere later this year in New York City with the winners in town for a red carpet event where they will have the opportunity to meet Ron Howard.”
- Now a lot of people have been linking this to the Canon ‘The Story Begins’ Hollywood event on the 3rd of November where a new Canon 35mm 4K cinema camera might debut. But why link the video camera launch to a DSLR marketing campaign? It doesn’t make sense. Project Imagination is similar to Vincent LaForet’s Story Behind The Still competition. And why does it say New York premiere in the Ron Howard / Canon press release? Yes it is possible the venue has changed to Hollywood but it still points more to a new DSLR than a video camera despite the location because the link to the Ron Howard DSLR stuff is pretty strong.
- Unusually the 5D Mark II has an instant rebate running until 29th October 2011, days before the Hollywood event – and has seen the first ever meaningful price drops this week, to under $2000 in Canada. Also, dealers have been offered bulk-buy discounts on the 5DMk2
- Canon’s new S100 compact has been announced and it is the first to feature DIGIC 5, the next generation image processor that the 5DMk3 is expected to feature. Precisely 3 years ago on the 16th September 2008 DIGIC 4 was introduced in the Canon G10 compact. A day later the 5D MkII was officially announced. Is History about to repeat?
- Fujinon who already have PL cinema glass on the market are said to be developing EF mount cine lenses for the system to compete with Zeiss CP2s, the advantage of these is that they will work on EF mount DSLRs unlike PL mounts which require hardware modding of the mirror box. The move will also earn mount licensing royalties for Canon. Fuji lenses on a Canon? It makes more sense than it seems.
- According to other rumours the EF mount video camera will be designed to compete with the FS100 at around $6,000 and there is a PL mount version will squash the Sony F3 for $15,000.
- Canon are said to have new video optimised EF lenses that can be used on both the new 5D Mk3 as well as the EF mount video camera.
- The 1DS Mk3 – somewhat unpopular due to the more attractive 5DMkII – has now been discontinued and it has come well past its 3 year cycle. Dutch dealers have been told ‘no more’ stock, and the Canon Canada and New Zealand websites have removed it. It is time for a replacement but will there be one?
- Although probably a typo Art Wolfe let slip on his Facebook status the following: ”I just wanted to extend an extra thank you to Michael Gurley from Canon for bringing the keys to the candy store this past weekend for the workshop participants. Mike brought with him just about every Canon lens… along with numerous backs including the new 1DS Mark 4.” It was since removed and corrected to simply say ’1D Mark 4′ instead of ‘new 1DS Mark 4′ (view).
- First the 5D Mk3 in October. A big marketing push in November. Limited stock on sale for Christmas.
- Possibly the Super 35mm cinema camera(s) in November potentially to be unveiled at the Paramount studios event in Hollywood on the 3rd.
- Sales of the 60D, 600D, 7D and G12 are still strong so I think it will be 2012 before we see an update to those, featuring DIGIC 5.
#411
Looks promising, but people just need to come out and say it. People didn't buy the 1Ds3 because the AF problems on the 1D3 and the 5D2 took off.
#412
New DSLR on Tuesday, October 18, 2011. [CR3]
OCTOBER 12, 2011 CANON 1D MARK V COMMENTS OFF
645
Share
Which one?
I am 99% positive we’re going to see a new DSLR next Tuesday, all the clues are pointing that way and I’m willing to give it a [CR3] rating.
What camera? No [CR] rating on this yet.
Everything is pointing to a new 1D series camera, I am getting zero information from sources or from anywhere else on the web about any other camera. We started hearing 6 months ago that the next EOS camera would be a new 1D and the bits of information are all pointing that way again.
For now the best spec list I have is what I posted a few days ago.
16-18mp
Full Frame
ISO 51,200
Dual Digic V
Crazy frame rates of 12-14fps have been reported
61 AF points has also been reported
Stock levels of the 1D Mark IV also point me in this direction. It seems they are very much being built to fill orders. There doesn’t seem to be any excess stock too many places
645
Share
Which one?
16-18mp
Full Frame
ISO 51,200
Dual Digic V
#413
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
![](http://img100.imageshack.us/img100/4582/rubhandsne2.gif)
#414
looks like those came true.
#415
I shoot people
Dual Compact Flash slots, NICE!
#416
interesting....
if thats the case i think the 5D3 is more for me....
5D Split? 5D X & 5D Mark III [CR1]
FEBRUARY 9, 2012 CANON 5D MARK III FOLLOW ON OUR FORUM
143
Share
Interesting thought
A split in the 5D line has been rumoured for a while now. This rumor was not submitted to me, instead it was sent to [NL]. It’s consistent with some things I have heard, however take this one with a large grain of salt.
5D X
45MP (With a pixel size similar to the power shot G1X)
61 points AF (Similar to the 1DX but simpler)
3.4 fps, 100-6400 (50-12800)
1 Digic 5+ Digic 4
5D Mark III
22MP
6.9 fps, ISO 100-25600(50-51200)
1 Digic 5+ Digic 4
Best HD video quality of any EOS camera
Both over $3k
143
Share
Interesting thought
5D X
1 Digic 5+ Digic 4
5D Mark III
22MP
1 Digic 5+ Digic 4
Both over $3k
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
#417
i think maybe the numbering is mixed up, with the way the 1DX and G1X is, id say the 22mp would be the X and the 45mp
would be the III
![what](https://acurazine.com/forums/images/smilies/what.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#418
so whats gonna happen with the 7D?
#420
New Flash & Lenses [CR3]
FEBRUARY 22, 2012 CANON FLASHES COMMENTS OFF
54
Share
Canon 590EX Speedlite
To be announced with the coming 5D replacement. As mentioned previously, it will have radio capabilities built in.
I also note that a big USA retailer has the 580EX II listed as EOL (End of life) in their system.
Expect it to be announced with the 5D replacement on February 27/28, 2012
54
Share
curious on the built in radio capabilities...
#421
New Lenses Coming [CR3]
FEBRUARY 22, 2012 CANON LENSES FOLLOW ON OUR FORUM
32
Share
New Lenses Coming
The announcement dates for the following lenses haven’t been confirmed. However, they will be coming sooner rather than later.
EF-S 18-135 II
This lens will have a silent autofocus motor geared to video. It will arrive with the new Rebel T4i. This has shown up in a US retailer inventory system. No price for the kit with the T4i.
EF 200-400 f/4L IS 1.4X
This highly anticipated lens will be officially announced shortly. The price will most likely be $10,999 USD.
EF 40 f/2.8 Pancake
I think it’ll be EF, but a 40 f/2.8 Pancake lens is coming. Expect it to be announced either with the 5D or shortly after.
32
Share
New Lenses Coming
EF-S 18-135 II
EF 40 f/2.8 Pancake
#422
The Next 5D on February 27/28, 2012 [CR3]
FEBRUARY 22, 2012 CANON 5D MARK III FOLLOW ON OUR FORUM
978
Share
5D Mark III/X
Below are the specs for the coming 5D replacement, the full name of the camera is currently unknown.
Specs
22mp
61pt AF
100% VF
3.2″ LCD
Dual CF/SD Card Slots
Price: Around $3500 USD
Announcement on February 27 or 28, 2012 (Depending where you are on earth)
So this pretty much confirms what we’ve been saying for a while now.
978
Share
5D Mark III/X
Specs
22mp
61pt AF
100% VF
3.2″ LCD
ohhh if that so, i may just get that instead of saving my pennies for a 1DX
#424
announcement date for the 5DX/III is on March 2nd..
#425
![](http://cdn.canonrumors.com/wp-content/uploads/2012/02/5dmarkiii2.jpg)
![](http://cdn.canonrumors.com/wp-content/uploads/2012/02/5dmarkiii.jpg)
![](http://cdn.canonrumors.com/wp-content/uploads/2012/02/5d3_1dx.jpg)
#427
5DmkII is supposed to be discounted to 2199.99 after the new one comes out
#428
5D3?
![](http://cdn.canonrumors.com/wp-content/uploads/2012/03/5d3front.png)
![](http://cdn.canonrumors.com/wp-content/uploads/2012/03/5d3back.png)
![](http://cdn.canonrumors.com/wp-content/uploads/2012/03/5d3top.png)
![](http://cdn.canonrumors.com/wp-content/uploads/2012/02/5dmarkiii2470.jpg)
new flash and grip?
![](http://cdn.canonrumors.com/wp-content/uploads/2012/02/sctrip.jpg)
and supposed specs on the 5D3
we shall see tonight!
new flash and grip?
Unsurpassed Image Quality
22.3 Megapixel Full Frame CMOS sensor
DiG!C 5+ Image Processor
ISO 100-25600 (expandable to L:50 H1:51200, H2: 102400
Full HD Movie (ISO 100-12800 (H:25600)
High Performance Operation
61-point high-density reticular AF (up to 41 crosstype points)
6.0 fps for high continuous shooting
Intelligent viewfinder with approx. 100% coverage
3.2-type, approx.1.04m dot (3:2 wide) Clear View LCD II
iFCL metering with 63-zone dual-layer sensor
Shutter durability of 150,000 cycles
High end features
Silent & low vibration modes
Dual card slots (CF & SD)
High Dynamic Range (HDR) Mode
Multiple Exposures
Comparative Playback function
Improved durability & water and dust resistance
SPECIFICATIONS
Available Colours – Black
Megapixels – 22MP
Sensor Size – 36 x 24mm
ISO/Sensitivity – 100 – 25600
Autofocus Points – 61 points
Lens Mount – Canon
LCD Size – 3.2″
Liveview – Yes
Viewfinder – Optical TTL
Min Shutter Speed – 30 sec
Max Shutter Speed – 1/8000 sec
Continuous Shooting Speed – 6 fps
Self Timer – 10 sec, 2 sec
Metering – Centre-weighted, Spot, Evaluative, Partial
Video Resolution – Full HD 1080
Memory Type – Compact Flash
Connectivity – USB 2, HDMI, Mic Input, Wireless (optional)
Battery – LP-E6
Battery Type – Lithium-ion
Charger – Includes Li-Ion Charger
File Formats – AVI, RAW, H.264, MOV, MPEG-4
Dimensions – 152 x 116 x 76mm
Box Contents – Battery Pack LP-E6 .. Battery Charger LC-E6 .. AV Cable AVC-DC400ST .. Interface Cable IFC-200U .. Eyecup Eg .. Wide Strap EWEOS5DMKIII .. CR1616 Lithium Battery+
High end features
Multiple Exposures
SPECIFICATIONS
Megapixels – 22MP
Lens Mount – Canon
LCD Size – 3.2″
Liveview – Yes
Battery – LP-E6
#429
Hmmm 6fps.
Definitely could be used for sports. I had no issue with my 6.5fps on my 40D.
#430
Sweet on the dual CF/SD card slot, I could put my eye-Fi into it ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
One thing I'll miss if I got the 1DX
#431
I shoot people
delete
#432
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
#433
I shoot people
I posted in the wrong thread and when I tried deleting it, it wouldn't, but could only edit, so I just changed the post to "delete".
Mizouse (03-04-2012)
#437
more like 600...
#438
![](http://www.canonrumors.com/wp-content/uploads/2012/06/canon-t4i.jpg)
![](http://www.canonrumors.com/wp-content/uploads/2012/06/canon-t4i-18-135-stm.jpg)
the 2nd picture is the new EF-S 18-135 IS STM (silent motor).
#439
![](http://www.canonrumors.com/wp-content/uploads/2012/06/canon-40mm-f28.jpg)
pricing is supposed to be aroudn $200.
#440
40mm x 1.3 = 52mm....
