MTM: Bimoto (based on Audi TT) news
WYHI...?
From Supercars.net...
The mtm Bimoto, probably the most impressive vehicle produced by mtm, is based on the Audi TT and is equipped with two four cylinder turbo-engine. Even the starting performance makes overwhelming driving powers possible. Because of further engine-modifications together is a maximum 1000 HP possible.
The latest project - the mtm bimoto - is one of the exclusive and extraordinary special vehicles of mtm. Once more it shows that the founder Roland Mayer wants more engine power and perfection.
Mercedes made a similar study (two engines in a A 190) with 15 employees in 4 months which means 60 work-hours in a month, mtm developed the TT bimoto in only 50 work-hours. The idea of two engines sounds strange at first, but it has lots of advantages compared with other ideas. To construct a vee eight turboengine for example we would have had to choose a central engine arrangement, which would have required the development of a special and more expensive allroad transmission.
For the drive of his two axles the mtm bimoto has two engines and two transmissions. Below the slightly changed body of the Audi TT hides more than expected at first sight. Both in front and rear every transmission is driven by its own 1.8 I four cylinder turbo-engine. A partition made of carbon including a rear window separates the maximum two passengers from the second drive unit in the rear. What you can find in it is that almost every component is doubled like the front one. Likewise there is a manual six gear transmission installed on the opposite of the driven direction which is driven by a 1.8 I cylinder in almost he same axis of the front part. To make power shifts possible double-clutches-transmissions will be obstructed in the new future. A welded cage stabilizes the complete car and includes the both aggregates.
The engines in the rear and in front move independently. The power comes from the street which is the connecting part between the two engines. Loading air, oil and water cooler, clutch and a second petrol pump, everything exits twice. Air not needed is lead back to the aerodynamic formed parts below the body and should especially at high speed improve the drive at the rear and it is supported by a diffuser. A marked carbon lip at the mtm tail wing supports this effect, too.
By the standard rear window, similar to a Ferrari 360 Modena, it is possible, even desired, to look at the technology of the second drive unit. According to Roland Mayer the plastic covers only use is not to have tc tidy up electronic cables and lines. This expenditure is operated by mtm because the customer should be able to look at the technology of the bimoto.
The customer will feel the technology, that's already sure. The project double engine vehicle is remarkable but for a firm with the entitlement of mtm not sufficient. Both engines will be far away concerning th performance output compared to the series. Unwaveringly and also everyday life-suited 740 HP, thus 370 H for each engine, are the minimum. Even 501 HP per four-cylinder are possible, which will be reached by capacity enlargement to 2 litres, big turboloaders and working on the periphery, says Mayer full of proud Finally however the customer should have the choice to decide on performance variant respectively deployment purpose of the vehicle.
The target is to give the car a handling, which is any time calculable. It may not surprise the driver with a change between under- and overriding but has to show the tendency to override. In Wettstetten we use therefore the standard sensors for the ABS system. The monitoring of the number of revolutions at all four wheels allows, by the help of the engine-electronic, an exact invasion to the handling of the bimoto. For example with slip at the front axle performance will be taken back from the front four-cylinder to avoid under riding. Similarly to that traction problems and power influences of the driven front axle to the steering will be avoided.
Behind the front, forged 19M-light metal rim a Brembo braking system is installed. Ventilated disc brakes, 32 millimeters strong and 355 millimeters in the diameter are taken there by a four-piston caliper into the pliers. At the rear axle acceleration will be converted to delay with ventilated, 330 millimeters big brake discs and a four-piston caliper.
With six-point-belts in Recaro full-bucket seats in future maximally two passengers have the possibility to feel the experience double engine in the exclusive MTM bimoto.
The development costs for the prototype are about 600.000 euro, A small series of 10 vehicles is planned. Optionally also a race-suspension and/or race-suspension-parts can be ordered.
Originally Posted by poohlikeshunny
^^ wise man...yummy, you need to find more car pics with hot/mostly naked babes...
SSM Accord V6 6 Spd
Originally Posted by godfather2
i just read on rs6.com that it broke some sort of land speed record
I can't say that I wouldn't hit it. Compared to some of the other cars posted here it seems bland, but then again I drive an Accord.....
That's Racist
i've been meaning to ask this for a realy long time...
but what does whyi stand for lol
-and while we're at it, can someone spell out what QFT means?
thx
and to stay on track, i'd love to see that horsepower into the new audi TT platform
thx
Money is funny.
lol..seems like the chick got more reps than the car man...althoughi must say even though i never used to be a tt fan, now that the new one is out (hotness), the older convertibles are starting to look attractive...an AWD convertible is hot...isn't it the only one under 100k too? I may have to look into them as I have seen them on ebay for 14-20k...they are gettin pretty cheap!
The 1000HP TT...
WYHI now...?
From Top Gear...
From Top Gear...
Perm-destroyer: the 1000bhp TT
Anyone who thought the previous generation Audi TT was a bit, well, effeminate will need to swallow their male pride as one has just hit 245mph.
OK, so this particular TT has benefited from a couple of teeny-tiny revision by Audi tune-meisters MTM, including a second engine where the rear seats normally fit, six-point race harnesses and a whacking great air intake on the roof.
You might remember Jeremy test-driving it yonks ago on TGTV, but MTM have been working on the engines since then and getting closer to their eventual aim - a speed of 250mph.
The pair of tuned 1.8-litre turbo engines each gives 370bhp, helping the bimoto TT see off 0-62mph in 3.7 seconds. However, the MTM engineers reckon each of the engines could be uprated to 501bhp - giving a combined power output of, yes, 1002bhp.
Scary, especially given MTM's admission that the TT has a slight tendency to oversteer. Eep.
But forget handling: top speed is the TT's real goal and the team behind the car, which includes driver Florian Gruber who normally races in the Porsche Carrera Cup series, is still aiming for 400kph, or 250mph.
The twin-engined TT will try to set the 250mph marker at the Nardo track in Italy, which has a massive banked circuit ideal for this sort of high speed highjinks.
If the Bimoto TT takes your fancy, MTM says it's planning to build a limited run of 10 cars. No prices as yet, but given the TT's 600,000 Euro development costs we fear it won't be cheap.
At least you'll never be accused of driving a hairdresser's car.
Originally Posted by TheMirror
Girl yes, car only if I lived within 30 minutes of the MTM shop.
Add another for girl yes car no
More pics and press release...
Press release...
The mtm Bimoto, probably the most impressive vehicle produced by mtm, is based on the Audi TT and is equiped with two four cylinder turbo-engine. Even the starting performance makes overwhelming driving powers possible. Because of further engine-modifications together is a maximum 1000 HP possible.
The story:
Mercedes made a similar study (two engines in a A 190) with 15 employees in 4 months which means 60 work-hours in a month. mtm developed the TT bimoto in only 50 work-hours.
The idea of two engines sounds strange at first, but it has lots of advantages compared with other ideas. To construct a V-8 turboengine for example we would have had to choose a central engine arrangement, which would have required the development of a special and more expensive allroad transmission.
For the drive of his two axles the mtm bimoto has two engines and two transmissions. Below the slightly changed body of the Audi TT hides more than expected at first sight. Both in front and rear every transmission is driven by its own 1.8 l four cylinder turbo-engine. A partition made of carbon including a rear window separates the maximum two passengers from the second drive unit in the rear. What you can find in it is that almost every aggregate is double of the front one. Likewise there is a manual six gear transmission installed on the opposite of the driven direction which is driven by a 1.8 l cylinder in almost he same axis of the front part. To make power shifts possible double-clutches-transmissions will be obstructed in the new future. A welded cage stabilizes the complete car and includes the both aggregates.
The engines in the rear and in front move independently. The power comes from the street which is the connecting part between the two engines. Loading air, oil and water cooler, clutch and a second petrol pump, everything exits twice. Air not needed is lead back to the aerodynamic formed parts below the body and should especially at high speed improve the drive at the rear and it is supported by a diffusor. A marked carbon lip at the mtm tail wing supports this effect, too.
By the standard rear window, similar to a Ferrari 360 Modena, it is possible, even desired, to look at the technology of the second drive unit. According to Roland Mayer the plastic covers only use is not to have to tidy up electronic cables and lines. This expenditure is operated by mtm because the customer should be able to look at the technology of the bimoto.
The customer will feel the technology, that's already sure. The project double enginge vehicle is remarkable but for a firm with the entitlement of mtm not sufficient. Both engines will be far away concerning the performance output compared to the series. Unwaveringly and also everyday life-suited 740 HP, thus 370 HP for each engine, are the minimum. Even 501 HP per four-cylinder are possible, which will be reached by a capacity enlargement to 2 litres, big turboloaders and working on the periphery, says Mayer full of proud. Finally however the customer should have the choice to decide on performance variant respectively deployment purpose of the vehicle.
The target is to give the car a handling, which is any time calculable. It may not surprise the driver with a change between under- and overriding but has to show the tendency to override. In Wettstetten we use therefore the standard sensors for the ABS system. The monitoring of the number of revolutions at all four wheels allows, by the help of the engine-electronic, an exact invasion to the handling of the bimoto. For expample with slip at
the front axle performance will be taken back from the front four-cylinder to avoid underriding. Similarly to that traction problems and power influences of the driven front axle to the steering will be avoided.
Behind the front, forged 19''-light metal rim a Brembo braking system is installed. Ventilated disc brakes, 32 millimeters strong and 355 millimeters in the diameter are taken there by a four-piston caliper into the pliers. At the rear axle acceleration will be converted to delay with ventilated, 330 millimeters big brake discs and a four-piston caliper.
The development costs for the prototype are about 600.000 euro. A small series of 10 vehicles is planned. Optionally also a race-suspension and/or race-suspension-parts can be ordered.
The story:
mlody
12-04-2019 02:11 PM
