We have already told you about both the hybridized V-12 powertrain and carbon-fiber structure of the replacement for the long-lived Lamborghini Aventador. But now we can show you the finished car, and tell you its name. This is the 2024 Lamborghini Revuelto.
Yes, as with most famous Lamborghinis, there is a bull connection. The original Revuelto apparently fought in Spain in the 1880s. But the name’s direct translation from Spanish, "scrambled," is also well-suited to this remixed Lamborghini. It features the apparent paradox of both an onboard battery pack for its innovative new plug-in-hybrid drivetrain but also the traditional presence of an almighty V-12 engine.
Powerful Plug-In Hybrid
The combination of the 814-hp 6.5-liter V-12 and a trio of electric motors will give a maximum combined peak of 1001 horsepower. There are two electric motors on the front axle, and these allow torque vectoring under both power and regenerative braking. A third motor is integrated into the eight-speed dual-clutch transmission which is now mounted behind the combustion engine. The 3.8-kWh battery pack mounted between the seats can only produce a peak current flow of 187 hp, but this can be moved between the three 147-hp electric motors as required. Unlike the Ferrari SF90 Stradale, the Revuelto can send power to both ends while working as an EV.
The battery can be recharged from a port inside the front luggage compartment, and the awkward location suggests it is only intended for infrequent use. More fun, although less green, will be the option to replenish it using the V-12 which turns the rear electric motor into a generator. Doing that takes just six minutes to top up the battery pack.
Looks Like a Lambo
The Reveulto’s design manages to be both familiar and different. Its proportions and stance are both trademark Lamborghini—low, wedgy and with visual mass gathered to the back of the car. But there are also myriad new details, with the most striking being the hooded headlights set under a hood that now runs all the way to the front of the car. It’s a detail that Lamborghini’s head of design, Mitja Borkert, admits was inspired by the Panigale superbike made by Lamborghini’s sister brand, Ducati.
The front also features Y-shaped running lights previewed by the limited-run Lamborghini Sián from 2021, as well as a pair of spherical radar sensors giving a visual cue to the Revuelto’s dramatically increased level of technology. The side view is dominated by the huge air intakes behind the doors made more aggressive by blade-like details. Above these what looks initially looks like solid bodywork is just a skin laid over massive air channels on each side. Borkert describes these buttresses as "aero wings" and nominates them as his favorite detail on the car.
The top of the Revuelto’s V-12 is visible through the rear engine cover, this being one of the core stipulations laid down by Lamborghini CEO Stephan Winkelman. The car’s back end is dominated by huge center-exit exhaust tailpipes beneath a moving wing element. We don’t have a final downforce figure for the car yet, but chief technical officer Rouven Mohr says the peak is greater than that generated by the Aventador SVJ when that car’s user-adjustable wings were in their low drag configuration. Figure at least 650 pounds.
More Spacious Interior
Lamborghini says that the limited space of the Aventador’s tight-fitting cabin was one of the biggest complaints from buyers, especially American ones. The Revuelto is bigger, with more headroom and elbow space, with its cockpit also gaining several stowage areas (the Aventador lacked any) plus a pair of Porsche-style cupholders that deploy from in front of the passenger position. Rich people have stuff, too.
The Revuelto’s cabin also gets three digital display screens. The driver has a 12.3-inch instrument pack, a portrait-orientated 8.4-inch touchscreen suspended beneath the "alien’s head" air vents in the center of the dashboard that serves as the primary user interface. There is also a new 9.1-inch letterbox display in front of the passenger, which can be configured to display different sets of scary numbers when the car is driven hard.
To our mild disappointment, the wiper and turn-signal controls have been moved to the face of the steering wheel. The Aventador was one of the last supercars to use stalks. This ergonomic purging is somewhat undone by the fact the Reveulto now has an Audi-sourced stalk for its active cruise control instead. Dial controls on the steering wheel will manage the chassis and powertrain modes, as well as adjustable aerodynamic and ride height settings.
Impressive Performance Claims
The Revuelto has gained a new mode in addition to the regular Lamborghini settings of Strada, Sport and Corsa. This is Città, the EV-only setting intended for low-speed urban use. Electric-only range is going to be very limited, as Lamborghini says it will probably be just six miles under European testing protocol. We have also learned that the peak power available will alter according to driving mode: Città limits it to the 178 hp of the EV-only mode, Strada increases that to 873 hp, Sport raises it to 895 hp and Corsa brings the full 1001 hp.
Although the Revuelto’s core carbon structure is claimed to be both lighter and stronger than that of the Aventador, and it loses the mass of its predecessor’s front differential and propshaft, hybridization has increased total weight. Lamborghini says that the central battery pack weighs 154 pounds and that the front motors add just 81.5 pounds of mass, with the new dual-clutch gearbox being 425 pounds including the weight of its integral electric motor. Total weight is claimed to be 3915 pounds based on the power-to-weight ratio Lamborghini is quoting, although we don’t know if that is with or without fluids.
Even with the increase in mass, and in its lowliest launch spec, the Reveulto will be both the most powerful Lamborghini road car to date and almost certainly the quickest. The company’s claim of a 2.5-second 60 mph time might not stand out in a segment where pretty much everything now runs below three. But the claim that it will be able to blast its way from rest to 124 mph in under seven seconds is a genuine eye opener. It takes the Bugatti Chiron 6.5 seconds for the same benchmark.
Deliveries of the Reveulto will start later this year, and although we don’t have a finalized price yet Lamborghini says that the first two years of production are already fully ordered.
I like it! I wonder what they will give me for my Odyssey on the trade in.
It’s interesting to look at the base prices of the new price the Murcielago, then Aventador and now the Revuelto. massive jump with the last one.
‘I’m not talking rare models or high up like SV SVJ trims, just the entry poor man spec.
I like the hurrican a lot, in most ways it’s a better car than the Aventador, but for me, a lambo must have a v12 and scissor doors.
Anyways, I can’t wait to see a revuelto at a car meet, it’s definitely striking in photos, I’m sure it’s stunning in person.
Automobili Lamborghini celebrates the first edition of its Lamborghini Arena event with an exclusive Revuelto created by the company's Ad Personam customization program, which recently inaugurated its new studio at the Lamborghini headquarters. The special version of the V12 hybrid plug-in super sports car was unveiled during the weekend of Lamborghini Arena, the biggest event in the history of the Sant'Agata Bolognese brand, held at Imola Circuit.
The exterior of this special car features contrasting hues with new carbon fiber elements that create a striking visual effect. The bodywork is painted in Grigio Hati (gray) with details in Verde Scandal (green) that accentuate the car's lower line, roof, mirror caps and rear diffuser surrounds, all combined with the Verde Chiaro (light green) of the brake calipers. The rear part celebrates the Italian flag, with red, white and green stripes embellishing the lower surface of the moving wing. The hood is crisscrossed by two racing-style stripes in Nero Noctis (black), highlighting the performance attitude of the V12 super sports car.
The roof, rear "cofango", spoiler, air intakes, sill inserts, and other details are made of high-gloss exposed carbon fiber, giving the elements a shiny effect enhanced by the 21-inch (front) and 22-inch (rear) high-gloss black Altanero alloy wheels.
The interior trim echoes the exterior colors, with Nero Ade (black) sport seats featuring stitching and piping in the Verde Scandal hue, the same color used for the Lamborghini logos embroidered on the headrests. The bulkhead panel lining is embellished with exclusive embroidery depicting the map of the Imola Circuit, the lettering "Lamborghini Arena 2024" in Bianco Leda (white), and escape route maps in Verde Scandal (green). Also exclusive are the carbon fiber plates with "Lamborghini Arena 2024" and "Ad Personam" logos located on the ends of the dashboard.
Unveiled in March 2023, Lamborghini Revuelto is the first V12 hybrid plug-in super sports HPEV (High Performance Electrified Vehicle). It is equipped with a 6.5-liter naturally aspirated V12 mid-engine combined with three electric motors, one of which is integrated into the new 8-speed dual-clutch transmission. Delivering maximum torque of 725 Nm at 6750 rpm and maximum power output of 1015 CV, it reaches a top speed of more than 350 km/with 0-100 km/h acceleration in just 2.5 seconds.
Lamborghini presented an Opera Unica: a sole Revuelto created by the Ad Personam personalization department along with Lamborghini Centro Stile, honoring the distinctive blues and seascapes of the Italian island of Sardinia. Unveiled at an exclusive dinner in the luxury resort of Cala di Volpe adorned in blue tones for the occasion, in the heart of one of the most famous and high-end holiday destinations in Italy.
"A unique Lamborghini Opera Unica car celebrates the innovation, creativity and inherent art found within our super sports cars, which is at the heart of our brand," says Stephan Winkelmann, Chairman and CEO. "Our clients can explore colorways, detailing, different materials, embroidery and finishes inside and out with Ad Personam to produce a Lamborghini that is truly personalized to them: this Opera Unica takes our creativity a step further, demonstrating paint techniques and interior finishes that are reserved for Opera Unica one-offs, presenting a truly unique art-piece reflecting the distinctive seascape and emotions of Italy's most beautiful island destination."
In addition to the standard production time of a Lamborghini Revuelto, the exterior paint effects commanded an additional 475 hours of specialist craftmanship. The Opera Unica creation was realized by meticulously masking the car's body to create a canvas for the paint: localized two-tone and three-tone paint fading was then enhanced by brush painting, reminding of waves hitting the cliffs. Special coating techniques were used, to personalize details such as the Start/Stop button cover and the nominal plate. The interior embroidery finish required 85 hours alone to produce the new tool required for the watery stitching effect dedicated to this Opera Unica.
The unique Revuelto employs Lamborghini Ad Personam's specially developed paint techniques, showing off the intriguing angles and lines of the car like modern architecture. Three separate shades of blue are combined using Lamborghini's craftmanship in utilizing brush and spatula to create special effects, reserved for this Opera Unica. Inspired by the crystalline seas of Sardinia, bubbles of water, waves and the deep blue of watery caves, the darker and lighter shades of blue are used across the various surfaces of the Revuelto, with clean definitions between different hues accenting the intriguing planes and lines of the car. The light Blu Tawaret features as the base color on the front panels of the car and roof, contrasting with the brighter Blu Cepheus used to create a fading effect, and on rear panels. Blu Okeanos is combined as the third blue to create an even deeper fading effect on bonnet and around the front splitter, set off by black Nera Bocca paint, shiny carbon splitter and sill, and Shiny Black with Diamond Polished Altanero rims with black Carbon Ceramic Brakes. The 'dragged' brush and spatula paint effect carries waves of the three blues across the rear from the front to sides and the rear, evoking the sparkling turquoise blues found in the refracted light of sea over sand and stones.
The complementary interior features Blu Delphinus as the main upholstery color, set off by lighter Blu Amon on seatbacks, on doors and trimming the center console, with contrasting white Bianco Leda stitching and piping. The seats, door panels, tunnel and roofline introduce a novelty to Revuelto embroidery application: using a specifically-developed tool, the three-tone stitching in Blu Amon, Blu Chepeus and Bianco Leda, that recalls the sparkling hues of the Sardinian waters. This effect is echoed on the Blu Mira carbon Opera Unica plate on the rear wall of the cabin, and on the Start/Stop button cover on the center console.
Revuelto is the first super sports V12 hybrid plug-in HPEV (High Performance Electrified Vehicle). Lamborghini Revuelto defines a new paradigm in terms of performance, sportiness and driving pleasure from its unprecedented new architecture; innovative design; maximum-efficiency aerodynamics; and a new carbon frame concept. An output of 1015 CV is delivered from the combined power of an entirely new combustion engine together with three electric motors, alongside a double-clutch gearbox that has made its debut on a 12-cylinder Lamborghini for the first time. The super sports car combines these attributes to deliver performance figures at the peak of its segment: acceleration from 0-100 km/h in only 2.5 seconds and a top speed of more than 350 km/h. These numbers combine with its exceptional dynamism thanks to the introduction of electric torque vectoring, and four-wheel drive available also in fully-electric drive mode, ensuring the Revuelto super sports car expresses its amplified qualities both on track and in daily driving.
