Hummer H3 News **More power for '07 (page 6)**
#48
Beware of leakage
My dad and his girlfriend are two engineers on this project, yet I still have not made it out to the plant to visualize these things.
#49
Hummer H3
Anaheim, Calif. - GM revealed the next Hummer-styled and off-road capable addition to the Hummer family at the California International Auto Show in Anaheim, California today - a mid-size SUV called the H3. The H3 is expected to arrive at dealers in spring 2005.
"H3's arrival establishes an extraordinary new presence in the previously ordinary world of midsize SUVs," said Susan Docherty, Hummer general manager. "Hummer has developed a passionate following because of its unmatched style and capability, and the H3 extends that appeal by making the brand accessible to a broader range of potential owners."
Compared to the H2, the H3 is 16.9 inches shorter in length, 6 inches shorter in height and 6.5 inches narrower - roughly the same length as a midsize family sedan.
Powered by the Vortec 3500 engine with dual overhead cams and variable valve timing, the H3 features a combination of power and greatly improved fuel economy. H3 is projected to reach peak fuel economy of up to 20 miles per US gallon. H3 will be the first Hummer to offer the choice of a manual or an automatic transmission, as many off-road enthusiasts value the ultimate control of a manual.
The H3 was engineered for off-road capability. The electronically controlled four-wheel-drive system is augmented with a fully locking rear differential, traction control, underbody shielding and GM's StabiliTrak vehicle stability enhancement system. H3 offers two tire packages, a Goodyear 32-inch all-terrain tire and Bridgestone 33-inch, both larger than any other midsize SUV.
The H3 also provides the refinement, comfort and convenience required for enjoyable on-road driving. It offers premium options such as heated leather seats, a large electric sliding sunroof, a DVD-based navigation radio and numerous customized accessories.
The H3 represents a significant step in the Hummer brand's rapid growth, and an important product for its new network of dealers. It joins the H1, the cornerstone Hummer that was based on the legendary military vehicle; the H2 SUV, the more modern and civilized full-size Hummer; and the H2 SUT launched in 2004 that features an innovative reconfigurable cargo bed.
Specifically designed as a truck engine, the Vortec 3500 is a 3.5L inline five-cylinder delivering 220 horsepower at 5600 rpm and 225 lb.-ft. of torque at 2800 rpm. In terms of performance, the Vortec 3500 provides acceleration that equals the V-8 powered H2 in most driving conditions. The Vortec 3500 includes dual overhead cams, variable valve timing, electronic throttle control and low mass. The engine also features unique counter-rotating balance shafts to help minimize noise, vibration and harshness.
The Vortec 3500 is available in the H3 with either a standard, smooth-shifting five-speed manual transmission or a Hydra-Matic 4L60-E electronically controlled four-speed automatic transmission. The automatic transmission includes shift modes specific to low-range operation, which, combined with speed-based throttle progressions, help optimize driveability in low-range, off-highway operation.
The H3 also has a standard new Borg-Warner two-speed electrically controlled full-time four-wheel-drive system with a 2.64:1 ratio low-range gear reduction for highly controlled off-road obstacle climbing. An optional version provides aggressive low range gearing ?- a 4.03:1 ratio ?- for ultimate obstacle-climbing control.
Both versions provide the choice of operating modes:
4High-range Open, for optimum highway performance and comfort under normal road conditions
4High-range Locked, which allows torque to be transferred to the front or rear wheels as needed
4Low-range Locked, for severe off-pavement use, such as crawling over large rocks or logs, or deep sand or snow.
4Low-range Locked plus driver-selectable electronic rear differential locked, with the optional 4.03:1 low-range transfer case gearing, providing crawling and climbing power every bit as capable as the legendary H1 and H2.
Neutral, for flat-towing the H3.
H3's more maneuverable size provides advantages, such as a 37-ft. turning circle and 9.1-inch ground clearance, which contribute to maximum breakover angle of 25 degrees (with 33-inch tires). Serious off-road performance is also aided by the maximum approach angle of 40 degrees and maximum departure angle of 37 degrees. These approach and departure angles permit the H3 to drive right into a hole and back out again, without getting hung up in front or rear.
Among its off-road capabilities, the H3 can ford 16 inches of water at 20 mph or 24-inch streams at a 5-mph pace, climb 16-inch vertical steps and rocks, make its way through deep sand and race over sandy surfaces.
Key chassis features include:
A fully welded ladder-type frame, with a modular, three-piece design that incorporates fully boxed components.
An independent front SLA torsion bar suspension and "Hotchkiss" design multi-leaf, semi-elliptic, single-stage leaf spring rear suspension.
Underbody protection that includes four standard protective shields, including the front skid plate; an oil pan skid plate that also protects the front axle; and a transfer case shield and a fuel tank shield. Additional protection is also available from optional chassis-bolted rocker panel protectors.
A highly sophisticated standard power rack-and-pinion steering system, with a three-bushing design and a 17:1 ratio that contributes to a very maneuverable 37-foot curb-to-curb turning circle.
Electro-hydraulic four-wheel anti-lock disc brakes with Dynamic Rear Proportioning, for quick, controlled stops.
Standard single-wheel, full-function traction control that uses a combination of engine intervention and brake management to allow as many as three wheels on a slippery surface and still provide impressive traction capability. It also interacts with the transfer case to provide additional off-road operating modes.
StabiliTrak vehicle stability enhancement system, which enhances safety, stability and control on all roads.
Interior finishing includes upscale touches such as a perforated, leather-wrapped and stitched steering wheel and automatic transmission shift handle; bright-accented instrumentation; brushed, machine-finished trim plates; chrome door release handles; chrome bezel for the automatic transmission shifter; and a chrome H3 emblem in the center of the steering wheel.
Sporty front bucket seats and 60/40 split rear seats, with foam inserts and soft bolsters are available in standard cloth and optional leather.
Four audio systems are available, all compatible with GM's OnStar system and optional XM Satellite Radio. They include an optional touch-screen DVD-based Navigation Radio, with a 6.5-inch screen, separate DVD and CD slots, Radio Data System capability and navigation map database.
A large, 36.1-by-24.6-inch power sunroof is available and includes easy-to-operate "express" opening and closing functions, with anti-pinch safety protection.
Some additional standard electronic features include power windows and door locks with lockout protection; electric rear window defogger; outside power-adjustable manually folding rearview mirrors; self-dimming "electrochromic" inside rearview mirror with compass and outside temperature indicator; and three 12-volt, covered auxiliary power outlets (two in front, one in the cargo area).
Safety features include available Stabilitrak vehicle stability control, roof rail-mounted side curtain air bags, rollover protection system, tire pressure monitoring and stout vehicle structure projected to earn five-star safety ratings for both the driver and passenger in front and side impacts.
Additional crash protection is provided by a standard frontal dual-stage air bag system. Optional roof-rail-mounted, side curtain air bags drop all the way down to the belt line to help provide head and rollover protection for the driver and front passenger. A rollover protection sensing system also helps protect occupants against impending rollovers by triggering side curtain air bags to increase the likelihood of occupant containment in a rollover event, and seat belt pre-tensioners to reduce the likelihood of occupant contact with the inside of the vehicle.
H3 will feature the new sixth-generation OnStar hardware with digital and analog coverage. OnStar's Gen 6 hardware includes upgraded hands-free voice recognition capabilities including more intuitive continuous digit dialing and improved voice recognition accuracy. OnStar features core safety services and Personal Calling that allows drivers to make and receive hands-free, voice-activated phone calls.
Some of the other standard safety and security features on the H3 include daytime running lamps, a PASSLock II anti-theft vehicle security system, remote keyless entry, battery rundown protection and an electronic tire pressure monitoring system.
![](http://www.canadiandriver.com/news/04images/hummer_h3_1.jpg)
![](http://www.canadiandriver.com/news/04images/hummer_h3_2.jpg)
![](http://www.canadiandriver.com/news/04images/hummer_h3_3.jpg)
I think this is one Hummer too many but we'll see I guess.
#53
Registered AssHat
Originally Posted by sipark
wish there was an actual person standing next to it.. can't tell how big/small it is.
EDIT:
H3 left, Jeep right (in inches)
Length 172.9, 181.3 (~9 shorter)
Height 73.2, 69.4 (~4 taller)
Width 84.7, 72.3 (~12 wider)
#59
Moderator Alumnus
![](http://www.autoweek.com/files/specials/galleries/h3/images/1.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_dust.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_front.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_group.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_interior.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_motion.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_rear.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_side.jpg)
![](http://www.autoweek.com/files/specials/galleries/h3/images/h3_street.jpg)
SPECS HERE
Hummer unveils big plans; brand aims to double sales, add models - - By JASON STEIN | Automotive News - - - Source: Autoweek
DETROIT -- Hummer has extra-large plans.
General Manager Susan Docherty says Hummer's short-term plans include nearly doubling its U.S. sales by the end of 2005. Hummer also will add variants and diesel engines.
"We want to take the brand, and the portfolio, to the next level both nationally and internationally," says Docherty, who replaced Mike DiGiovanni last month. DiGiovanni was put in charge of medium- and long-range strategy for increasing market share.
With the addition of the H3 mid-sized SUV, Hummer wants to become "more approachable," Docherty says. She expects to sell "north of 50,000" vehicles in 2005.
Through the first nine months of 2004, Hummer sold 20,284 vehicles, mostly H2s, in the United States. That's down 20.3 percent from the year-ago period.
A year ago, CEO Rick Wagoner said he thought there was "a chance to get to at least" 100,000 units in annual Hummer sales.
Hummer is expected to sell the H3 for between $35,000 and $45,000.
The H3, which is expected to debut in the second quarter of 2005, will be more fuel-efficient than its larger siblings. Docherty says it will average about 20 mpg on the highway.
Fuel economy has been a sensitive issue for Hummer in the J.D. Power Initial Quality Study.
DiGiovanni this year said Hummer will try to improve mileage.
The H2 ranges from 10 mpg to 13 mpg, according to dealers.
The average age of an H2 buyer is 40 with an average household income of $175,000, Hummer says. With the H3, Docherty hopes to retain the median age but attract families with incomes of $100,000.
Docherty also wants to increase female buyers to 40 percent in the H3.
The H2 averages about 25 percent female buyers.
She says more variants, such as the H2 SUT pickup, are on the way.
"SUVs, SUV trucks, potential pickup trucks - there's a big space Hummer can play in, and there's lots of room where we can grow," Docherty says.
Diesel also will be considered for more vehicles. A high-performance, low-volume H1 Alpha will debut in early 2005 featuring a Duramax diesel engine.
The H1 already offers a turbodiesel engine.
#65
6MT Snob
Just wait theres more.. coming down the pike is a Hummer pickup truck..
Have you guys seen www.fuh2.com
its amusing
#66
its amusing
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
#69
6MT Snob
Originally Posted by members78
H1 owners think H2 owners r pu$$ies - i saw the bumper sticker on an H1. wonder if H3 owners will get any respect.
#70
More News.
Hummer to budget big for H3 push, expecting women buyers
KATHY JACKSON | Automotive News
Posted Date: 10/28/04
LOS ANGELES -- Hummer will at least double its marketing budget to an estimated $50 million when the smaller H3 goes on sale the second quarter of next year.
The mid-sized H3 joins its big, expensive siblings - the H1, the biggest of the Hummers and the smaller but still full-sized H2 - which have been successful reaching a limited audience. Now, with the H3, Hummer hopes to reach a broader group, particularly women and younger drivers, who want the bold Hummer look in a smaller package.
Looking almost identical to the H1 and the H2, the four-door, five-passenger H3 is 11.2 inches shorter in length than the H2. The H3 weighs 4,700 pounds vs. 6,400 for the H2.
The H3's 3.5-liter inline 5-cylinder engine produces an estimated 220 hp. It will be the first GM mid-sized truck equipped with either a manual or an automatic transmission. It is expected to get 20 mpg.
It will cost an estimated $30,000 to $35,000 vs. more than $50,000 for the H2 and more than $100,000 for the H1.
Susan Docherty, the Hummer general manager since September, says the division spends about $25 million annually on the H2. She says it will probably spend more than that on the H3. She says much of the H3 advertising will be in print and non- traditional marketing such as sponsorships. Modernista in Boston is Hummer's advertising agency.
"We need to get out the price message that not all Hummers are $50,000-plus, and that we have a smaller and more fuel-efficient Hummer," Docherty says.
In its first marketing campaign for the H3, Hummer hosted a concert by the urban rap/rock group Black Eyed Peas at the Anaheim, Calif., convention center on Oct. 25. It issued up to eight tickets each to 1,200 Hummer owners in California.
"We wanted our owners to bring in their friends so we can conquest," Docherty said. "We're trying to portray that Hummer is growing. I need to demonstrate that we have Hummers that fit all demographics."
Docherty, 42, who launched marketing of the popular Cadillac Escalade SUV, says she believes women will buy about 40 percent of the H3s, double the 20 percent who buy the H2.
She expects the average age of buyers to be about 40 and for household income to average $75,000 for singles and $100,000 for dual earners. She estimates that the manual transmission version will account for about 10 percent to 15 percent of the sales.
The H3 will be produced at GM's plant in Shreveport, La., which also produces the Chevrolet Colorado and GMC Canyon pickups.
Docherty projects sales of about 25,000 H3s next year in the United States. Total U.S. Hummer sales through the first nine months of 2004 were 20,284, down from 25,453 during the same period last year.
#72
Registered AssHat
I do give them props for offering a MT
#74
is 220 hp & 225 lb/ft enough for truck bigger than grand cherokee?
No at all. It weighs 4700lbs. It is way underpowered. Why GM didn't go with the I6 from the trailblazer at minimum or at least as an option
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#76
Originally Posted by domn
No at all. It weighs 4700lbs. It is way underpowered. Why GM didn't go with the I6 from the trailblazer at minimum or at least as an option ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by 1st article
....the H3 features a combination of power and greatly improved fuel economy. H3 is projected to reach peak fuel economy of up to 20 miles per US gallon....
#77
#78
people will buy it for the same reason anyone buys a hummer, for the name. It doesnt matter how under powered it is.
I think all SUV's are massivly overpriced right now.
