Hartge: H50 V10 (based on BMW 3-Series) news
2006 BMW Hartge H50 V10
The 3 series BMW from Hartge is a masterpiece in many ways and not all of them are visual. The Hartge engineers have achieved something very special under the thermodynamically optimized bonnet in particual. Fitted with a modified M5 V10 engine, a 7-speed SMG transmission and the Hartge modification to raise top speed from the electronically limited 155 mph to 200 mph, the H50 V10 puts all its power – 550 bhp and torque of 384 lb-ft – onto the tarmac via a reinforced rear axle and a special suspension setup that is adjustable in terms of both rebound and compression.
Also new and made especially for the Hartge H50 V10, is the stainless steel exhaust system, which turns the V10 sound into an acoustic delight. Customers can choose between two dual round (or oval) tail pipes. The wheel / tire combination consists of 9 x 20 offset 40 at the front and 10 x 20 offset 40 at the back fitted with 245/30 ZR20 and 285/25 ZR20 tires respectively.
The Hartge H50 V10 Interior
The interior highlights are a 205 mph speedometer, the carbon interior trim, the 3-spoke leather steering wheel with carbon inserts, the illuminated aluminum gear knob and the leather handbrake cover.
With the H50 V10, Hartge is continuing its long tradition of making wolves in sheep's clothing for individualists who attach importance to understatement.
The H50 V10 is based on the BMW 3 series saloon (E90). A comparable conversion is currently being developed for the Touring (E91) and Coupe (E92).
Specifications
Engine
Type: V10
Displacement cu in (cc): 301 (4941)
Power bhp (kW) at RPM: 550(410) / n.a.
Torque lb-ft (Nm) at RPM: 384(520) / n.a.
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 245/30 ZR20 - 285/25 ZR20
Driveline: Rear Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 178.0 × 71.5 × n.a.
Weight lb (kg): n.a.
Performance
Acceleration 0-60 mph s: n.a.
Top Speed mph (km/h): 200 (320)
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
Specifications
Engine
Type: V10
Brakes & Tires
Performance
RS4 who?
omg
Engineer
AMG who?
Engineer
Originally Posted by goldmemberer
I doubt that car can put down that much power effectively. And the styling does nothing for me.
slicks? otherwise i am sure the traction control cuts most of the power for everyday driving...
personally the i would take a Hartge M3 with the E39 M5's 400hp V8...
Originally Posted by srika
omg
Photography Nerd
Originally Posted by rezurex
i bet this engine will be about $100,000 to get from hartge. not worth it.
That was uncalled for...
This does indeed look like a chop...Both Hartge names (front and side) look chopped, and the black just doesnt seem convincing...its a sweet car if its real picture and Im sure the V10 is a real hoot...
PS. Do they even make tires with that low of a profile? thats like a inch of sidewall.
Hartge H50 V10 Coupe
From Worldcarfans...
Back again this year: the HARTGE H50 V10 under the guise of the E92 3 Series Coupe. The first thing that strikes you is the two-tone paintwork, then the ventilated bonnet and front wings, as well as the HARTGE front spoiler lip and HARTGE boot spoiler.
From the Saarland region, the H50 V10 features a thermo-dynamically optimised bonnet. In addition, HARTGE's engineers and mechanics have achieved an extraordinary feat of engineering: the installation of a modified M5 V10 engine producing 550 hp (404 kW) and a torque of 520 Nm, which is coupled to a 7-speed SMG transmission and de-restriction to 320 km/h.
To help the H50 V10 put all this power onto the road, it is also fitted with a reinforced rear axle and a special suspension system that can be adjusted not only for height but also for rebound and compression.
Also especially made for the HARTGE H50 V10 is the stainless steel exhaust system, which makes the V10 sound an acoustic delight. Customers can choose between dual twin oval or dual twin round tail pipes.
The wheel/tyre combination consists of 9 x 20" offset 40 wheels at the front and 10 x 20" offset 40 at the rear fitted with Pirelli 245/30 ZR 20 and 295/25 ZR 20 tyres respectively.
Last but not least: inside the HARTGE H50 V10 besides a 330 km/h speedometer, the first things you notice are the carbon interior trim, the 3-spoke steering wheel with carbon inserts and the leather/aluminium brake handle.
With the H50 V10, HARTGE maintains its long tradition of building wolves in sheep's clothing for individualists who prefer understatement.
HARTGE H50 V10 Coupé (based on 325i / E92)
Engine
Cylinders: 10
Displacement: 4999 cc
Bore / Stroke: 92.0 x 72.2 mm
Performance: 404 kW / 550 hp at 7750 rpm
Max. torque: 530 Nm / lb-ft 391 at 6100 rpm
Fuel grade: Unleaded, 98 Octane
Euro norm: Euro 4
Gear box: 7-speed SMG
Gear ratios:
1 = 3.99 : 1
2 = 2.65 : 1
3 = 1.81 : 1
4 = 1.39 : 1
5 = 1.16 : 1
6 = 1.00 : 1
7 = 0.83 : 1
Rear axle ratio: 3.45 : 1
LSD: 0 – 100 %
HARTGE equipment
E60 M5 V10 engine with reworked cylinder heads, sports camshafts, bespoke engine mapping, 7-speed gear box, special exhaust system with new manifolds, reinforced and adjustable wheel suspension.
HARTGE stainless steel rear silencer with dual twin oval or dual twin round tail pipes, left and right HARTGE adjustable sports suspension, 30 mm lower Brakes:
380 mm 2-piece perforated floating disks front with 8-piston fixed brake callipers
345 mm 2-piece perforated floating disks rear with 4-piston fixed brake callipers
HARTGE bonnet, ventilated
HARTGE rear wing
HARTGE set of carbon housings for exterior mirrors
HARTGE CLASSIC 2 wheel set
9 x 20" offset 40 with 245/30 ZR 20 Pirelli Nero
10 x 20" offset 40 with 295/25 ZR 20 Pirelli Nero
HARTGE 3-spoke-leather steering wheel with carbon inserts
HARTGE carbon interior trim for dashboard, gear lever panelling and door handle
HARTGE speedometer 330 km/h
HARTGE leather/aluminium handbrake handle
HARTGE aluminium pedals (2)
Set of HARTGE velours floor mats, black (other colours upon request)HARTGE set of emblems for bonnet and boot lid
Performance
Acceleration 0-100 km/h / 0-62 mph:
4.4 s
Maximum speed:
320 km/h / 200 mph
Weight DIN:
1670 kg / 3676 lbs.
Weight distribution, front / rear:
52.0 / 48.0
RRP:
157,650.00 EUR including 16% VAT
Technical data and prices are subject to changes without notice. November 2006
Engine
Cylinders: 10
Euro norm: Euro 4
Gear ratios:
1 = 3.99 : 1
2 = 2.65 : 1
3 = 1.81 : 1
4 = 1.39 : 1
5 = 1.16 : 1
6 = 1.00 : 1
7 = 0.83 : 1
LSD: 0 – 100 %
HARTGE equipment
HARTGE rear wing
Performance
4.4 s
Maximum speed:
320 km/h / 200 mph
Weight DIN:
1670 kg / 3676 lbs.
52.0 / 48.0
RRP:
Engineer
I will wait for the Hartage Z4 with this engine squeezed in...
on to the next one...
It looks like there may be one in the background of that last pic...
From rsportscars.com...
Back again this year, the Hartge H50 V10 under the guise of the E92 3 Series Coupe. The first thing that strikes you is the two-tone paintwork, then the ventilated bonnet and front wings, as well as the Hartge front spoiler lip and Hartge boot spoiler.
From the Saarland region, the H50 V10 features a thermo-dynamically optimized bonnet. In addition, Hartge's engineers and mechanics have achieved an extraordinary feat of engineering: the installation of a modified M5 V10 engine producing 550 bhp and a torque of 391 lb-ft, which is coupled to a 7-speed SMG transmission and de-restriction to 200 mph.
Also especially made for the Hartge H50 V10 is the stainless steel exhaust system, which makes the V10 sound an acoustic delight. Customers can choose between dual twin oval or dual twin round tail pipes.
The wheel/tire combination consists of 9 x 20" offset 40 wheels at the front and 10 x 20" offset 40 at the rear fitted with Pirelli 245/30 ZR20 and 295/25 ZR20 tires respectively.
Last but not least: inside the Hartge H50 V10 besides a 330 km/h speedometer, the first things you notice are the carbon interior trim, the 3-spoke steering wheel with carbon inserts and the leather/aluminum brake handle.
With the H50 V10, Hartge maintains its long tradition of building wolves in sheep's clothing for individualists who prefer understatement.
Specifications
Engine
Type: V10
Power bhp (kW) at RPM: 550(410) / 7750
Torque lb-ft (Nm) at RPM: 391(530) / 6100
Brakes & Tires
Tires F-R: 245/30 ZR20 - 295/25 ZR20
Length × Width × Height in: n.a.
Weight lb (kg): 3676 (1670)
Performance
Acceleration 0-62 mph s: 4.4
Type: V10
Brakes & Tires
Performance
Hartge E92 3 Series Cabriolet Revealed
WYHI...?
World famous BMW tuning house, Hartge, revealed their E92 3 Series Coupe styling package in the M5 V10 engine transplant prototype known as the H50 V10. Minus the ventilated bonnet, the kit is essentially the same for the cabriolet model seen here. But now, you don't have to imagine it. Feast your eyes on the snappy renderings of what it will look like. Hopefully, Hartge will give our man on the scene, Nick Hall, a crack at it so we can give you the details and real life shots. For the 335i bi-turbo engine, no major engine mods have been announced other than an ECU upgrade which gives a pawltry 34hp and 37 lb-ft of torque (293 kW / 340 hp @ 5800 rpm and 450 Nm / lb-ft 332 @ 1500 rpm) extra.
The perception of ECU tuning on an aspirated engine leaves one uninspired by these numbers. But expect more dramatic engine tuning packages in the coming months as tuners devise a completely new development program for BMW's first turbo engine in 30 years.
Originally Posted by TLyoung'un
way to much money to spend on a 3, v10 or not.. there are better cars to be bought for that money (to me)
Hartge BMW 3-series Touring
WYHI...?
Hartge H50
I just met this nice guy(Keith) at the local Flagship car wash and he was driving a Hartge H50 V10 E90 It's the first time I ever see one with my own eyes. Basically what he did, he bought a 335 and shipped it out in Germany to get it modified. We're talking about an M5 motor, suspension, 7 speed sequential the whole thing. He turned it on and I nearly died. It's a beast. I regret not asking about the price. I cussed myself not to have my camera ready.
http://www.youtube.com/watch?v=CsBn8...eature=related
