Chevrolet Corvette vs. Porsche 911 and 911S **C&D gets 4.1 to 60 for the Z6 (p. 2) **
Source of pics above: www.RoadandTrack.com
I was reading a couple of mags while at the DC airport about the 911S vs C6 (Z51 equipped) comparo.
From a performance perspective as far as speed, the 911S was faster. And that was the case in both mags (it was Automobile and Road and Track mags).
From memory:
0-60
911S= 4.4
C6 = 4.5 (4.6 in the other mag)
1/4
911S = 12.9
C6 = 13.0
The trap speed was a mile or two higher for the C6, signaling more power on the ground.
One mag said, in real world driving, the C6 is faster; it's just that it hooks better at launch due to the fact the engine is in the rear and the polar inertia favors it more than with the C6.
I will give two more personal reasons:
1. The 911 has sticker and lower profile tires when the C6 has run flats. By the way, no car has spares. Justifiably so for the C6 due to the run flats but what's up with the 911S? So if you have a flat tire, you're stuck on the road waiting for AAA? Embarrassing I say...
2. Looking at the gearing, you can see why. The 911 has shorter gearing on ALL gears as compared to the C6. But first gear is the ultimate proof of the fact that the 911S engineers were trying to find other ways to make this car post fast/quick times, other than using engine power. There was a 10mph!!! difference in first gear alone between the two cars, with the 911S being the shorter geared one in this case of course.
So because the 911S, due to its design (engine behind the rear axle) can hook like hell, the engineers try to take advantage of that launch at its maximum, cos they know it won’t be fast enough once it hooks.
So the
0-120
and
0-140 mph runs, the C6 won by far.
Note that the C6 gets it max./top speed wit 5th gear! Just to get an idea of how long-geared this car is designed to be. I doubt this will be the case with the Z06 C6. So 911 Turbo watch out.
So if you are on the highway with a C6 and a 911S wants to play, you can pull on it all day long. That's what the mag means when it says, the C6 is quicker/faster in every day, real world driving situations.
If one looked at where each gear topped from a mph standpoint, you'd understand why the C6 lost both 0-60 and 1/4 mile runs. They were both at the redline of a particular gear in the case of the 911 and nowhere near the C6's redline. Typical as always!
Even on the track, in the case of one mag, the 911S was faster, but only by a fraction of a second. I think the other mag. had the C6 as faster. So it depends on how many straights the track has so the C6 puts all that power on the ground.
There was not a big difference with the breaking performance, but even there, the 911S won.
Although if this were a comparo between the C6 and the 911 (not the "S"), the C6 would have smoked it from every performance angle, I have to admit, I was disappointed to see the Chevy again, lose that way. It's the typical, "I got the power, but cant show it" type of story that has been going on for ever now when comparing the German icon to the American icon. When will Chevy just put a stop to EVERY loophole that German engineers use so that one day you will see all mags say this: The 911 is a DOG compared to the Vette, from any performance angle. NO matter how you cut it, the Vette is faster and quicker. It stops better, it turns faster AND IT'S 50 GRAND CHEAPER!
Also the mags mentioned that the C6 is BY FAR easier to drive both in traffic on the highway, as well as, on the track. The 911S is twitchier than the 996 911 they wrote in surprise.
R&T measures who the winner is by giving points on every aspect of measuer to the cars as you know. In this case, the C6 won, but only because of the fact that it's $35K less expensive. Before that measure, the 911S won (but not by very much).
Car and Driver had the C6 faster in every acceleration test. They gave the nod to the C6 by only 1 point. They did say that the price of the 911 is what killed it from winning. A $20k price difference for nearly the same level of performance is crazy.
At first, I thought the C6 was hella hot but it's pretty bland looking now. Of course, that may well be because I've seen too many damn shots of it... but still. I say the 911 looks better, and I'd still never buy it.
Was that the 911 or the 911S?
Originally Posted by cusdaddy
They got 4.1 0-60 in the C6 vs. 911 story in C&D
What did the 911S get? Was it an S or was it the base 911?
The 911 is actually longer than the C6 this year
Sure the 911's back seat are made for 10 y/o's, but it does have a back seat. Hmm.. I wonder if the 911 still has a folddown seat back, so the back seat can be used as a parcel tray. I really like having a back seat (or I might be driving a 350Z instead of my CLS).
The C6 is definitely the better bang for the buck...
Originally Posted by 03CLsPunisher
the november car and driver -
911S - 0-60 4.1
1/4 = 12.6@112
911S - 0-60 4.1
1/4 = 12.6@112
Holy shit! These numbers are way too quick and fast to believe. Something's wacky here.
http://www.caranddriver.com/article....&page_number=1
Originally Posted by srika
Vettes have been like this since the first 6-speed was introduced in '89. 6th gear is an overdrive gear, designed to maximize fuel efficiency. Top speed is attained in 5th gear.. Vipers are also like this, along with some other 6-speed cars...
Right, but my point was that the 911 does not have an overdrive gear.
see it for yourself -
Wow! The lesson here is: "that's what gearing does for ya!"
From the C&D article above:
"Even with the rear axle tramping violently almost all the way through first gear, the Carrera S could be horse-whipped to a 4.1-second 60-mph run and a 12.6-second quarter-mile at 112 mph, slightly quicker than the slightly lighter 400-hp C6 Corvette [C/D, September 2004]. The old 911 GT3 with 380 horses was but a 10th quicker to 60 and the mighty 415-hp 911 Turbo just 0.2 second. Nominally shorter ratios in the Carrera S's revamped six-speed manual give it extra spurt-ability, but don't try clutch drops with a car you plan to keep."
Just a FYI:
The Car and Driver article is a 911 Carrera vs. C6 Z51 ... Not a 911S
The 4.1 sec 0-60 from 03CLsPunisher's statement above comes from a full C&D test about the Carrera S ONLY! Not the comparo of the 911 against the C6Z51. Two different C&D articles.
So I am now wondering, does anyone know how fast was the Carrera in the comparo article?
Even with this aggressive gearing though, it's still a surprise to see a lighter C6 with 50more HP be slower at 60 and the 1/4 mile.
http://www.caranddriver.com/article....rticle_id=8774
easier to believe now, but still seems like the 911 has a little more than 321hp...
and, I guess I expect car magazines such as C&D to have top-notch proofreading.. look at the picture they have for this comparison at this front page...
http://www.caranddriver.com/default....ion_id=15&uc=1
Incidentally this test was conducted at Gingerman Raceway in Michigan.
12.8 @ 109... the numbers are on page 5:
I dont know how C&D got those numbers. I mean it's amazing for both cars. 4.1 to 60 for the C6?! What's the Z06 gonna do? 3.1? Ditto for the 4.3 for the (base) 911 car. I dont understand.
Almost Supercars - - BY LARRY WEBSTER - - Source: Car and Driver December 2004
Chevrolet Corvette Z51 - Porsche Carrera
C/D test results:
acceleration, seconds
0-60 mph 4.1 4.3
test average 4.2
0-100 mph 9.6 10.5
test average 10.1
0-150 mph 25.0 28.5
test average 26.8
1/4-mile @ mph 12.6 @ 114 12.8 @ 109
test average 12.7 @ 112
rolling 5-60 mph 5.1 5.3
test average 5.2
top gear
30-50 mph 10.3 7.6
test average 9.0
50-70 mph 9.6 7.9
test average 8.8
top speed, mph 186 (drag ltd, mfr's claim) 181 (redline ltd)
test average 184
C/D test results:
0-60 mph 4.1 4.3
test average 4.2
0-100 mph 9.6 10.5
test average 10.1
0-150 mph 25.0 28.5
test average 26.8
test average 5.2
top gear
30-50 mph 10.3 7.6
test average 9.0
50-70 mph 9.6 7.9
test average 8.8
test average 184
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
