AUTOWEEK; Infiniti M45 vs Lexus GS430
styling on you
1 Post
http://www.autoweek.com/article.cms?articleId=102927
Double Take: 2006 Lexus GS 430 vs. 2006 Infiniti M45 Sport
Luxo Grudge Match: Infiniti’s M45 sedan matches wits with the electronic brain of the Lexus GS 430
AUTOWEEK
Published Date: 8/15/05
The polite thing to say here is that one of the cars in this comparison makes an excellent commuter and long-distance autobahner, while the other is a surprising amount of fun to drive at the track.
But that’s only three-quarters of the story, because the car that is a surprising amount of fun to drive at the track is also an excellent commuter and long-distance autobahner. So the winner was pretty obvious to us, though we didn’t expect it to be such a runaway. If you want to know the winner, you can skip all the way to the end of the article, but you have a whole week until your next issue arrives, so why not read on and let the suspense build?
We’re talking here about the new Lexus GS 430 and Infiniti M45, which are statistically nearly identical cars. When they came out several months ago they just begged, pleaded even, to be thrown into a comparison test. Both offer big, smooth, powerful V8 engines, commodious four-door cabins, and both are from Japanese carmakers that wended their ways slowly and steadily up the scale to sit at the top of the luxo-sedan heap along with only a few other manufacturers. These cars cried out for a grudge match.
Both cars compete in the luxury segment once dominated by Mercedes-Benz, then pollinated by Audi, Jaguar and Cadillac. Now Lexus and Infiniti are in the mix. (Acura doesn’t count, because its RL has a V6 while all the others have V8s. Why? Who knows, since the new RL is an otherwise magnificent car and could go mano a mano with the best in the segment if only it had two more cylinders. As it stands, Acura is still back in Camel Lights.)
Let’s look at the contenders.
The GS 430 has so many electronic handling acronyms that it should be sponsored by Post Alpha-Bits breakfast cereal. There is even a program to counter crosswinds.
The GS 400, as it was first known, was created to fill the gaping hole between the entry-level ES 300 and the luxury-party-crasher LS 400. The first GS was actually a show car built by Giugiaro, presented at the 1990 Geneva motor show as the Kensington. It was intended for Jaguar, but when Jaguar passed, Lexus made the car into the GS. It met all the criteria for the luxury semi-performance class, and it was a good high-speed cruiser. For 2006 the GS gets fully revitalized with a new engine, new brakes and enough electronics to strangle a goat. More on the latter later.
The lineage of the Infiniti M45 is not as direct. This model is basically a stretched and more powerful G35. The previous M45 had no relation to the G35, but was a version of the Japan-market Cedric/Gloria. Now Infiniti has dropped the old M45 with its Q45 platform and replaced it with this stretched and V8-ed version of the G35. So the car went from Q to M and then from G to G-and-a-half and is now called M but is really a G. If you’d like to be confused about anything else, please call us. Whatever it is, this is the car that plugs the gap between the two ends of the sedan spectrum at Infiniti.
Both of these cars sit on nice rear-wheel-drive platforms, though the Infiniti sits on that can-do-no-wrong FM platform riding under the mighty 350Z, G35 and the coming GTR.
The fundamental difference between the two is that the Infiniti has built-in sporty goodness, while the Lexus takes a fairly good substructure and tries hard to make it great through electronics.
The single most noteworthy electronic aid on the M45 is the Rear Active Steer. Sensors for wheel speed and steering angle feed a computer, which decides how much to adjust the rear lower links to steer the rear wheels up to one degree—electric motors do the work. The result is more stable cornering and greater grip. It’s not scary like super HICAS was back in the day.
The most noteworthy electronic aid on the M45 is the Rear Active Steer, with sensors for wheel speed and steering angle. The result is more stable cornering and greater grip.
The GS 430, meanwhile, has so many electronic handling acronyms that it should be sponsored by Post Alpha-Bits breakfast cereal (assuming that tasty product is still manufactured). Basically the VDIM (vehicle dynamics integrated management system) controls variable gear ratio steering (VGRS), vehicle stability control (VSC), electronically controlled brake system (ECB), ABS, electronic brake distribution (EBD), brake assist (BA) and engine torque via electronic throttle. There is even a program to counter crosswinds, not to mention the pre-collision system that uses the cruise control’s radar to sense imminent impact and then tightens the seatbelts and pre-pressurizes the brake lines so they grip more quickly when the driver steps on the pedal.
In a straight line, these are both fine cars to drive.
“Excellent on the freeway,” is one comment on the M45. “All I hear is a very subdued thumping from the tires, nothing comes through to the cabin.”
“Fast and smooth on the freeway,” says one tester of the GS 430. “This car is ticket bait, and you’d never even realize it.”
We wrote as much about the GS 430 at the car’s introduction, where we never really pushed it too hard. But as we said in that story, “While it feels sound and fun now, we will withhold judgment until after we can thrash it without adult supervision.”
There were no adults on hand the day we brought these cars to the California Speedway.
First thing we did was go down the drag strip. While it’s true the Infiniti has 200 cubic centimeters more displacement, giving it 335 hp vs. the Lexus’ 300, the GS 430 has 250 pounds less curb weight, 3745 pounds to 3995. So the GS’s smaller 4.3-liter V8 has that mitigating factor going for it compared to the M45’s 4.5. Also, we tested the Lexus first, under slightly better atmospheric conditions, if you believe in those things.
Nonetheless, the M spanked, getting to 60 mph in 5.95 seconds compared to the GS’s 6.27. That latter figure is a little surprising, since Lexus lists 0 to 60 mph in 5.7 seconds. Quarter-mile times are closer, with the M45 going through at 14.54 seconds at 97.7 mph and the GS 430 at 14.76 seconds at 95.9 mph. At least some of the blame should go to the traction control on the Lexus, which, even when switched off, turns itself back on above 30 or 35 mph. That is really annoying, too. It’s like HAL refusing to open the pod bay door. “I’m afraid I can’t do that, Dave.” Now we all know what happened to HAL, don’t we?
The Infiniti also stops better: 120 feet from 60 mph vs. 124 feet for the Lexus. The Lexus brake-by-wire system feels slow to respond compared to the M45, an observation backed up by our computer printouts of each braking incident, which suggest the Lexus system is slower to build up maximum effort compared to the Infiniti. And yet, when driving around town, it is the Lexus brakes that feel way too touchy and overboosted.
In the slalom we loved the Infiniti but wanted to drive the damned Lexus into a wall. Since there is no way to turn off the stability control at the speeds at which we typically go through the slalom, we had the traction/stability/everything else system in full operation on every run. We had to hack our way through the slalom around the interference of the enormous Lexus electronic brain. The Infiniti, meanwhile, even stayed in the gear we selected as we wended our way through the cones, while the Lexus kept choosing the gear it thought was best. Results: Infiniti, 44.5 mph; Lexus, 43.8 mph.
The Infiniti costs less too, with a base price (including delivery) of $50,160 for the M45 Sport compared to $51,775 for the Lexus.
So yes, the Infiniti is easily the winner here. Buyers who are never going to push their luxury sedans as hard as we do, and who like the greater isolation and the extra brake and steering assist of the Lexus, might disagree. While it may not be as sophisticated and road-course smooth as a BMW 5 Series or even an Audi A6, the Infiniti M45 is easily the Japanese champion in this class. Sayonara, Lexus.
OTHER VIEWS
> My decision was made as soon as I discovered the Lexus’ traction/stability control reactivated at 30 mph, even though I switched it off. It is bad enough when automakers—Mercedes comes to mind—won’t let you fully turn off such systems, but they usually allow some slip-angle. Lexus apparently thinks the only reason to turn off the baby sitters is to get a good launch.
Mac Morrison
> The M name has come a long way since Nissan first rebadged its Cedric/Gloria and sent it over. While still no visual screamer, the M does attract attention with its subtle good looks. And a sleeper body is always my first choice. Inside you find roomy and very well-appointed accommodations, so much so that this new M seems well on its way to butting up against the flagship Q, and that’s not necessarily a bad thing.
Carrie Roca
> The M45 has undergone a transformation from bench warmer to big-time baller, a vehicle that now clearly has the game to take on all comers in the luxo-themed sport sedan segment. Gobs of power, improved driving dynamics, a nicely upgraded interior and slick curbside appeal combine to make this new M mighty good.
Mike Floyd
> This M45 isn’t just better than the car it replaces, it’s arguably in the top-three in its class. Where it ultimately finishes on the podium depends on your interpretation. I’d take the M45 because it has the muscle, robust handling and aggressive lines to keep me entertained. I appreciate the GS 430’s plush ride and isolated environment, but at the end of the day I need to get my blood going.
Andrew Luu
Lexus gets owned again (not really but they lose anyway)
AUTOWEEK
OTHER VIEWS
Mac Morrison
Carrie Roca
Mike Floyd
Andrew Luu
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I feel the need...
The Mugen Legend blows the doors off M45 and Lexus 430 by a wide margin in the looks department...
(w/o the hood scoop)
http://www.jalopnik.com/cars/concept...max-030124.php
http://www.mugen-power.com/topics/legendmax0501/
http://www.autoblog.com/entry/1234000537028084/
Homeless
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I think the M is sexy as candy pancakes w/extra syrup...especially when they combine the silver exterior with the gunmetal rims...:sickashell:
I'm the Firestarter
I'm kind of disappointed that the GS430 keeps getting nailed in reviews, I love the looks and the interior on that car, much more than the M45 and the RL.
Not sure about that Mugen Legend, but the Legend Modulo looks REALLY hot:
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Those wheels are just incredible.
![](http://sohc.vtec.net/news_files/319284/05tas-02.jpg)
misanthropist
Originally Posted by chef chris
I think the M is sexy as candy pancakes w/extra syrup...especially when they combine the silver exterior with the gunmetal rims... :sickashell:
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Moderator Alumnus
Well...atleast in your opinion...![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Damn Right. I love the looks of the M, though I do think the GS is a good looking car too (after seeing it in person).
![Bandito](https://acurazine.com/forums/images/smilies/bandito.gif)
Originally Posted by biker
I'm sure Lexus doesn't mind losing in reviews as long as it doesn't lose the sales race.
Homeless
Originally Posted by phile
The Infiniti isn't too far behind the Lexus in terms of GS vs M sales. I think Lexus should mind a little, even if it's not losing.
(To us CR, may mean little beyond a reliability index but to the masses, it's the Holy Bible of consumer preferences.
![hide](https://acurazine.com/forums/images/smilies/hide.gif)
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
