WTF???...... subs are shot
Old Jun 3, 2002 | 01:42 PM
Marc S's Avatar
yesterday i was driving along and my system just shut down. I figured i had a loose wire, so i checked it out. I couldn't figure out the problem. So today i took it to the guy who installed it and he told me my subs blew. WTF?? what are my options now? I got them off ebay. Im thinkin i can call JL and ask them about repair. SE any idea on what i can do??
Old Jun 3, 2002 | 04:44 PM
DirtyHarryFSU's Avatar
Seminole Fan
Are you sure they're blown? Normally, blown speakers still play but sound like garbage(unless they're totally destroyed). It's also odd that both would blow at the exact same time.
I'm willing to bet it's a bad connection or blown fuse somewhere. Have you checked the fuses on the power wire and amp? Is the amp turning on?
Old Jun 3, 2002 | 04:50 PM
Marc S's Avatar
When i got back in my car i decided to turn the bass up. What do you know, everything works fine. So for the last 1/2 hour its been playin like nothing happened. I called the guy and told him whats been happenin. He said that the subs might work for a little then go off again. Im gonna wait and see what happens.
Old Jun 3, 2002 | 05:59 PM
Woodsdaddy's Avatar
Everybody Wang Chung
I don't think that guy has any idea what the hell he is doing. You may have over extended the voice coil out of the magnet, in which case it is slightly possible that it fell back into place. Or there is something wrong with the wiring. If you fry a voice coil I don't think there is much chance of it working again.
Old Jun 3, 2002 | 06:02 PM
Woodsdaddy's Avatar
If it stops working again you might try to pull out the sub and attatch a 9v battery to the terminals and see if it pushes out. This will not hurt it but it will tell you if it is the sub or something else.
Old Jun 3, 2002 | 07:50 PM
Seminole Fan
I hate to tell you but that guy has no idea what he is talking about. If a sub blows - it's not going to play again. It sounds like your amp overheated and shut down - that would explain why it works now. How do you have it wired? If it's 2 ohm mono then that's probably what happened - amps tend to get very hot when pushing those tough loads. If you have the problem again I'd get a fan on it or something to help keep it cool.
Old Jun 3, 2002 | 09:35 PM
Marc S's Avatar
I checked the amp when i first noticed it and it was not hot at all. Thats why im confused
MrHeeltoe
20
Feb 23, 2023 01:54 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
