wiring question
Old Apr 11, 2005 | 09:09 PM
MistaWrongy's Avatar
wiring question
so my friends and I were wiring my amp back to my box and found out that when we wire like this:
positive-negative
negative-positive
instead of
positive-positive
negative-negative
it sounds a lot better. I'm not sure why, it could be because i wired the box wrong but i'm about 95% sure i didn't. If i am actually running it from negative-positive, is this damaging to the amp/sub?
Old Apr 11, 2005 | 09:16 PM
elduderino's Avatar
VP Electricity
Is this a single voice coil woofer?
If it is, you have discovered that reversing polarity can make a big diff in SQ for a woofer, especially in a sedan. Always worth trying, and no, no harm at all.
Does this mean that the hifonics you were trashing is working fine?
Old Apr 11, 2005 | 09:54 PM
no its a diff amp, and its a dual voice coil i believe
Kicker S12L7
Old Apr 11, 2005 | 10:01 PM
elduderino's Avatar
VP Electricity
OK, in that case, help me out like this:
(+) of amp goes to:
(-) of amp goes to:
VC #1 (+) goes to:
VC #1 (-) goes to:
VC #2 (+) goes to:
VC #2 (-) goes to:
Old Apr 11, 2005 | 11:26 PM
(+) of amp goes to:
(-) of amp goes to:
VC #1 (+) goes to:
VC #1 (-) goes to:
VC #2 (+) goes to:
VC #2 (-) goes to:
VC #2 (+) goes to: VC #1 (+)
VC #2 (-) goes to: VC #1 (-)
(+) of amp goes to: VC #1 (-)
(-) of amp goes to: VC #1 (+)
i'm pretty sure its that way unless i wired the box wrong which i don't think i did. But wiring it this way gives cleaner/better bass.
Old Apr 11, 2005 | 11:42 PM
elduderino's Avatar
VP Electricity
The the two VCs are in "phase" with each other and reverse-polarity in regards to the amp than the way they were before... so my earlier post applies.
BUt if you had toe two VCs out of phase before, that would have sucked totally.
Old Apr 12, 2005 | 02:20 AM
xaznperswaesonx's Avatar
looks like you just did a parallel reverse polarity ..
just for info .. way you can tell polarity is this .. get a battery or some low voltage battery ..
connect speaker wires to the speaker .. use the other end and touch the battery. notice the initial movement of the woofer ..
--- if it moves up ... then what ever wire set up you have will yield the correct polarity
--- if it moves down .. then it's reverse
example .. Terminal 1 -----speaker wire----- (-) of battery
................ Terminal 2 -----speaker wire------ (+) of battery
the cone moves up ... then terminal 1 is indead the negative terminal and terminal 2 is the postive one.
the cone moves down ... then terminal 1 is indead the postive terminal and terminal 2 is the negative one.
Old Apr 13, 2005 | 01:39 AM
confusing for my little brain
Old Apr 13, 2005 | 02:04 AM
when you say "down" do u mean the woofer moves in, like into the box.
Old Apr 13, 2005 | 09:28 AM
elduderino's Avatar
VP Electricity
"down" means inward towards the magnet, "up" means outward and away from the magnet.
Old Apr 13, 2005 | 11:53 PM
elduderino's Avatar
VP Electricity
As an aside, looking at the top of this page, Google can't figure WITF this thread is about : )
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
VA2000TL
Oct 2, 2015 08:26 AM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
