TSX: Wiring OEM Acura Backup Camera
Has anyone successfully wired up an OEM camera?
Seems like most are on a 6 pin setup with the following connections:
CAMERA ADAPT
CAMERA SH
CAMERA V
CAMERA GRD
VCC GRD
CAMERA VCC
I also secured a voltage regulator since the camera voltage is less than 12 volts.
I hooked up the following and got no signal:
CAMERA V --> Video out
CAMERA GRD --> Ground
VCC GRD --> Ground
CAMERA VCC --> Signal from voltage regulator
Any help will be greatly appreciated!
CAMERA ADAPT
CAMERA SH
CAMERA V
CAMERA GRD
VCC GRD
CAMERA VCC
VCC GRD --> Ground
