wiring a 4 channel amp w/ components??
fellow MASShole
i currently have boston pro series components up front with a boston rm9's in the back ... with an ecliplse 100x4 amp
im havin balance/fade issues ( wont do either ) and i think its the wiring ... whats the correct / best way to wire this setup?
1 channel per speaker ... would the components require 4 channels themselves??? 2 for each set i dunno any help is appreciated
MaCe
MaCe
you're correct, 1 channel per speaker. the components require 2 channels. 1 for each speaker...then the crossover for the pros/components splits the signal between the midrange/woofer and the tweeters. seems like the some wires were mixed. if i were to determine which wire corresponds to what speaker, i would disconnect each pair of wires in the amp and connect them one at a time and see which slkeaper makes the sound. then connect that wire to the appropriate connection to the amp. that's how i would do it unless someone can come up with a quicker way.
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
