wiring...
wiring...
im getting some 4 gauge stinger HPM wire for my system.
is this wire ok to use for the power AND ground? or is there a specific kind of wire for the ground?
also, would it be ok to change the stock wires that are connected to the battery with this same wire?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
U can use the same 4 gauge for a ground, just don't get the colors mixed up, and ground your power wire to your car.
I would just buy a 4 gauge battery wire kit if I were u, I wouldn't use it for your battery/alternator wires, but amp power and ground are fine.
![Run](https://acurazine.com/forums/images/smilies/run.gif)
El Presidente
Originally Posted by car_lost
Is there a reason you wouldn't use them for the battery wires?
I don't see why you couldnt use those wires to do the "Big 3" upgrade. Just makesure u dont confuse yourself if all the wire is the same color
El Presidente
cool, thanks.
what gauge should i use for the stock battery wires?>
I believe 4 Guage is adequate. You could go all out and go 0/1 Guage if you wanted, but your call
El Presidente
well, for the power and ground wire for the amp i'll be using 4 gauge.
what is the gauge of the stock wires for the battery?
no clue
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
