whole system in 1st gen tl
i already have the speakers put in and i have an amp and 2 subs waiting to be put in. my problem is my flip up monitor when they put it in they added a switch that bypasses the e-brake but it was right before they closed so they never connected it where and how would i connect it and also any tips on a sub box enclosure that can hold two 12'' subs that wont take up much room in my trunk with room for an amp thanks...
ray
ray
Originally Posted by Reach
Lets try this again with proper English sentences and punctuation before I will even attempt to answer your questions.
creative grammar
i already have the speakers put in. I have an amp and two subs waiting to be put in. My problem is my flip up monitor when they put it in they added a switch that bypasses the e-brake but it was right before they closed so they never connected it. Where and how would i connect it and also any tips on a sub box enclosure that can hold two 12'' subs that wont take up much room in my trunk with room for an amp thanks...
ok how do you bypass the emergency brake hook up for the flip up monitor so i can watch dvds when ever and not just when the e-brake is pulled. and does anyone have any ideas on a sub box that can fit two 12in subs and a amp with out taking up too much room.
1. can't answer it fully as i never done it on an acura. did it on my brothers lexus though and it was just grounding a wire behind the HU. should be similar
2. Build one, don't get prefabs; they suck. Don't know what you drive, but it'd probably be hard to fit a proper sized ported box for two twelves if you drive a mid-size sedan. Sealed might do you well though.
3. Are you really 18?
i was planning on building my own to cover the back of the trunk so i still have some room for my hockey bag but there is enough room fo have both subs next to each other with 2in on both sides and in between.
yes i am 18 i just turned it on monday
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
