what will happen if I?
what will happen if I cut the tension bar holder for the trunk lid underneath the sub position, i want to do this because i want to put a bigger sub in its position????
oh ok, i wont want to do that, if u guys have any info on what subs can fit in that area can u please post it, i know about the mid bass driver but i want more bass, and i want to put in in the stock position where the stock sub is. any ideas??
look into illusion audio subs...they offer relatively thin subs because the inverted magnet.
www.illusioinaudio.com
I am about to install an Illusion Audio 12" sub in a custom fiberglass box in the driver's side of my trunk. I am also putting Illusion ND5.1 components in kicks in the front. I bought my Illusion equipment off of ebay.
A couple important things to note. You need to get a freeair sub. If you get the Illusion then make sure you get the freeair version.
Also, Illusion audio went out of business earlier this year so don't expect company support. Their website is still up:
Illusion Audio
Some other high-quality 8" freeair subs to look at include Morel HCW8 and WR8. The Kicker RMB8 is a freeair that some on here have used as a replacement for the stock sub. I have a pair of RMB8s that I will put in my front doors for midbass use.
David
Illusion Audio
David
SidhuSaaB
05-30-2020 12:40 AM
