What size and type of wood.....
What width and type of wood do I need to do a custom installation in my trunk? I want to do something original but not crazy!! Anyone have any clean pics?? Will post pics when I'm done.
Medium Density Fiberboard. Solid stuff, cuts and shapes pretty easily (its tough on bits/blades though). Use sharp bits and carbide tipped saw blades. It will split pretty easily if you do not predrill holes for screws (use coarse thread screws...I used the galvanized ones). Soaks up water like a sponge...I would seal it with Kilz or something before final install.
You should be able to find it at any hardware and lumber store (Lowes, Home Depot, mom-and-pop lumber yards). Usually 4'x8' or 2'x8' sheets, 1/2" or 3/4" thick.
Read up on good box building techniques and bracing.
http://www.jlaudio.com/tutorials/boxdesign/index.html
http://www.jlaudio.com/tutorials/bracing/index.html
I agree that you should use 3/4" thick minimum for 12" subs.
Received 1,080 Likes
Yes MDF is very good for building enclosures, but if you wanna do it the professional way, use Baltic Birch. Do a search on the web for it and you'll see how many car and home audio builders use it. It's expensive, but it doesn't warp, crack, bend, split......
Originally Posted by shawhite
yeah i wanted to do my enclosure in birch but could not see spending $50 for a sheet of it.. plus that stuff is heavy...
thanks guys. f'n frustrated because I just tried to hook up my amp back up (temporary bass fix) which worked two days ago but now I get nothing. checked the power cable- good, ground- good. the only other thing i can think of is the damn remote wire. Now i have to f'n take everything apart at the dash............
Boomer SOONER
Originally Posted by guapoTL
One more thing... OU: do you have any supports for the sub behind the board?
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
