what is damping factor??
Old Aug 25, 2004 | 09:14 PM
uncleb's Avatar
under the specs of some amps it says damping factor : >x@x ohms
the x's just represent random numbers, it says dampning factor at certain ohms.
what does this mean and what qualities does it affect??
Old Aug 25, 2004 | 10:07 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
well, in electrical engineering, damping of the system is basically sensitivity of the system and how well it recovers. although for sound engineering, it pretty much seems to relate to how accurately the amp can control the speaker. example: some amps cannot drive loads at two ohms, so the damping number would drop lower, telling us that it cannot accurately control the load (in this case a subwoofer) at that ohms rating. the higher the number the better. i suppose you could comparatively shop for an amp solely on the damping factor, although there are many other features i would look at first. some manufacturers don't even bother listing that info.
i wouldnt worry about it too much if i was you. just don't try driving a load it can't handle. hope this helps!
SSTS
Old Aug 25, 2004 | 11:15 PM
I'm Batman's Avatar
Boom goes the Dynamite
Satin that is a great definition on dampening factor. While it is not the most important spec to buy an amp by, I would consider it a factor. I guess it depends on how someone is going to play their subs and what type of music they will be playing.
Old Aug 26, 2004 | 05:51 AM
ChairmanMaoSaysRTFM
thanks for the props Batman
true on your second point also. i know for instance that an orion competition amp is stable at 1ohm. i suppose if you were a real audiophile and into competitions you would want to know what the damping factor is at that 1ohm rating compared to a rockford fosgate/pheonix gold/etc. at the usual 4ohms/2ohms rating. no sense in buying in amp that can't accurately reproduce sound i suppose.
SSTS
Old Aug 26, 2004 | 12:48 PM
uncleb's Avatar
i see
does that first number have any relation w/ the watts or something, or is it just some random scale of measurement??
Old Aug 26, 2004 | 02:42 PM
ChairmanMaoSaysRTFM
i see
well, i would say the scale was chosen arbitrarily. i would imagine it could have been 0 to 1 or 1 to 1,000,000 if they wanted. (honestly i'm not 100% sure of it's origins offhand anymore). it's not related to watts though. it's really a representation of the system at the specific load rating. how many watts the amp puts out really won't affect this number much, if at all. this number is affected by how it was designed and what components were used during assembly really. does this actually help or did we make it worse?
SSTS
Old Aug 26, 2004 | 02:45 PM
uncleb's Avatar
cool man, yea thanks, that does help...
Dec 7, 2020 05:39 PM
Froid
Sep 27, 2015 06:16 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 14, 2015 03:16 PM
Sep 14, 2015 10:48 AM
