TL: Volume is adjusting with throttle.
Old Nov 13, 2009 | 05:32 PM
ANC297's Avatar
Bonki' Ehrite!
I have a 02 tls with a pioneer premier headunit. When I apply the throttle the volume gets louder and when I brake it gets lower....Any idea why, and how to fix this?
Old Nov 13, 2009 | 08:17 PM
Jonesi's Avatar
Is this the actual volume or is this strictly road noise? ()High pitched)
Old Nov 13, 2009 | 09:47 PM
ANC297's Avatar
Bonki' Ehrite!
No, this is the actual volume of the music...Lets say that the volume is set on 7, when I hit the gas it plays louder then like a volume of 20, but then I hit the brakes and it goes back down to what it should be. Also, most of the times it does this it throws the speakers off and it sounds like they are blown, but they're not.
I have a AUX port that connects to my Ipod if that makes any difference?
Old Nov 14, 2009 | 11:05 AM
kyamcg's Avatar
That's probably so your music doesn't get drowned out by the sound of your engine. I know it's a feature on some new cars, such as Audis.
Old Nov 14, 2009 | 12:40 PM
n0rm's Avatar
I ♡ PEK PEK
Automatic Volume Level Control or something like that.
Old Nov 14, 2009 | 07:27 PM
ANC297's Avatar
Bonki' Ehrite!
Do you know if there is anyway to turn it off, because it gets so loud at some points that it distorts the sound.
Also, whoever installed the headunit disconnected the steering wheel controls.....Is there any way to get those to work in conjunction with the Pioneer headunit?
Old Nov 14, 2009 | 09:16 PM
n0rm's Avatar
I ♡ PEK PEK
You would have to check your owner's manual on how to turn off the feature.
In order to get your steering controls you need to install an PAC adapter.
Old Nov 14, 2009 | 11:17 PM
ANC297's Avatar
Bonki' Ehrite!
The manual for the headunit, right?
Old Nov 15, 2009 | 12:45 PM
Jonesi's Avatar
I don't think there's escalating sound in a 02 TL. I have no idea what the issue might be causing it..
When you upgrade a headunit you lose steering wheel controls it's nothing the installer did. You also lose factory sub, 6 disc in dash and Navi voice.
Old Nov 15, 2009 | 01:10 PM
ANC297's Avatar
Bonki' Ehrite!
My car does not have Navi, and I primarily use my Ipod in the car....But is there ANY way to get the factory sub back?
I have a Rockford Fosgate amp and a off brand sub (10) in a box in my garage, how might be able to hook that up? Do I need any specific cables or connections?
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
lowgrowl
Sep 26, 2015 05:18 PM
flybyglass
Sep 24, 2015 01:12 PM
