viper 790/791 remote programming
Old Jan 18, 2005 | 08:31 PM
Black-n-Tan's Avatar
I have a Viper 790XV alarm/remote start. my controller recently died and i bought one for a 791XV which according to several of my installer buddies would be compatible. however, i cant seem to get the new controller programed. the alarm set/ and open fumctions are the only things working (and i have to use the lock button for both functions). i followed the auto- reprogramming instructions that came with the remote.
Anyone have an idea of whats wrong?
now is a time when i could really use my remote starter
Old Jan 18, 2005 | 11:07 PM
Scott P's Avatar
Mobile Elec. Guru
you are programming it for single button configuration. Do this to program it correctly:
1. open the driver door and leave it open
2. put the key in the ignition and turn to the on position
3. with in ten seconds, press and release the valet switch 8 times, and then on the ninth time hold it.
4. if you have done this correctly, you will hear the siren chirp 8 times.
5. if you have heard these chirps, then press the lock button on the new remote, as soon as you have pressed the button you will here the siren chirp again.
at this point you can turn the key back to the off position and you will have programmed your new remote for standard configuration.
Old Jan 19, 2005 | 08:06 AM
i'll try it as soon as the weather breaks into the double digits. thanks for the info
Old Jan 19, 2005 | 11:26 AM
elduderino's Avatar
VP Electricity
If you would like a PDF of the install manual with programming instructions, PM me your email and voila!
Old Jan 19, 2005 | 02:02 PM
yep thats the code. came in handy this morning in 2 dgree weather. im assuming that the code that comes with the replacement transmitter is for the 791. thanks for the responses
Old Jan 19, 2005 | 06:15 PM
elduderino's Avatar
VP Electricity
So you want the manual? Drop me a note...
Old May 20, 2008 | 10:29 PM
patlew41@yahoo.com's Avatar
Elduderino,
I have a viper keypad FCC ID: EZSDE1476
I was wondering if you could send me that programming manual
Old May 20, 2008 | 10:45 PM
Ron A's Avatar
Administrator
Originally Posted by patlew41@yahoo.com
Elduderino,
Welcome to the forums.
This thread is 3 years old and Elduderino hasn't been here in over a year so you might not get a reply, but someone else might be able to help you.
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
