using relay on nav conversion...YEE...???
Old Dec 27, 2001 | 06:19 PM
systek's Avatar
Question using relay on nav conversion...YEE...???
hey yee...i saw that u used a relay instead of the toggle switch. i went looking for the switch and found that same relay, but am not exactly sure how to hook up the power leads...the video wires i figured out...the main thing is this:
is the switch for power(ur purple switch) simply an on/off switch?so all i need is to run a positive wire from where ever to switch, then that wire to the relay. then ground wire to the other post on the relay? is that it??? please specify...thanks
Old Dec 28, 2001 | 06:36 PM
asiankidd's Avatar
yeah pretty much the extra 2 leads into the 4pdt relay is for power...i just grounded one end and used a on off switch with a +12 volt signal going to the relay...it worked for me..
Old Dec 28, 2001 | 09:55 PM
systek's Avatar
Thumbs up great, thats all i wanted to confirm...
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
