using relay on nav conversion...YEE...???
Old 12-27-2001, 06:19 PM
systek's Avatar
Question using relay on nav conversion...YEE...???
hey yee...i saw that u used a relay instead of the toggle switch. i went looking for the switch and found that same relay, but am not exactly sure how to hook up the power leads...the video wires i figured out...the main thing is this:
is the switch for power(ur purple switch) simply an on/off switch?so all i need is to run a positive wire from where ever to switch, then that wire to the relay. then ground wire to the other post on the relay? is that it??? please specify...thanks
Old 12-28-2001, 06:36 PM
asiankidd's Avatar
yeah pretty much the extra 2 leads into the 4pdt relay is for power...i just grounded one end and used a on off switch with a +12 volt signal going to the relay...it worked for me..
Old 12-28-2001, 09:55 PM
systek's Avatar
Thumbs up great, thats all i wanted to confirm...
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
greeneyes.hypnotize
09-27-2015 02:47 PM
Quick Reply: using relay on nav conversion...YEE...???
