TSX tweeters.
Old Mar 10, 2007 | 01:52 PM
dirty651's Avatar
TSX tweeters.
Who has successfully installed after-market tweeters in the factory location? What brands fit with the least modification? Does any brand fit? I have a set of infinity reference tweeters that I want to install.
Old Mar 10, 2007 | 02:35 PM
Reach's Avatar
I have infinity tweeters in the stock locations. They fit with one of the infinity supplied platic mounting buckets. It was a very tight fit on one of them, so I dremelled the hole out a little. You may or may not have to shave them a bit to get them in, but its no big deal, and its worth it.
Old Mar 10, 2007 | 08:22 PM
jlukja's Avatar
Reach, what bit did you use on your dremel?
Old Mar 11, 2007 | 01:40 PM
Reach's Avatar
300 sand wheel. Not a cutoff bit, just something to grind the plastic down.
Old Mar 11, 2007 | 02:57 PM
jlukja's Avatar
Thank you sir.
Old Mar 13, 2007 | 06:02 PM
dirty651's Avatar
Excellent, Thanks Reach!
Old Mar 16, 2007 | 02:41 PM
defjukie's Avatar
I've got Polk Db6500's in mine.
The holes were slightly too small for the tweeters so I fixed it in a very ghetto like manner:
with a serrated knife.
yes, i know
it worked though... just took off a little at a time and tried to fit them in. They now rest perfectly in the holes though, they are not 'attached' in any way.
Looks good, sounds good. Good enough for me, at least.
Old Mar 16, 2007 | 05:00 PM
daicacharco's Avatar
where are the stock tweeters located at ?
Old Mar 16, 2007 | 06:55 PM
shrykhar's Avatar
Under the windshield, in the corners.
Has anyone given any thought to these tweeters?
http://www.kenwoodusa.com/products/L...&k3=168&pr=208
They have an inline crossover, so I'd imagine they'd be less prone to blowing.
Old Mar 22, 2007 | 07:53 PM
Integraboy22's Avatar
TSXRCR22
I have used the Kicker tweeters that came in the Kicker SS Component system. They worked with little to no real custom mods. I mean I made my own bracket to house them out of ABS but that only took 10 minutes for each tweet.
Old Mar 23, 2007 | 12:19 PM
jlukja's Avatar
This one seems to have pretty good specs, decent price, and a flush-mount adapter that I think will fit the stock TSX location:
http://www.madisound.com/cgi-bin/ind...5.4473&pid=635
Old Mar 23, 2007 | 12:37 PM
arch's Avatar
Im curious to hear everyone's results of their changes. Are they just louder? Do they sound cleaner and more detailed or are they just louder? Did they raise the sound stage and imaging above the dash? The OEM solution has the staging really low and I cant stand it.
Old Mar 23, 2007 | 03:30 PM
rrfrey's Avatar
I believe that's the tweeter used by Avincar. It gets a lot of mentions over at diymobileaudio and I keep planning to order a pair and try them... It might need a small capacitor to raise the x-over point a little bit.
This one also looks interesting: http://www.madisound.com/cgi-bin/ind....4473&pid=2135
Old Mar 23, 2007 | 08:19 PM
jlukja's Avatar
Originally Posted by rrfrey
I believe that's the tweeter used by Avincar. It gets a lot of mentions over at diymobileaudio and I keep planning to order a pair and try them... It might need a small capacitor to raise the x-over point a little bit. [/url]
If so, then try a 4.7uF capacitor.
Old Apr 9, 2007 | 02:38 PM
bullyx2's Avatar
'05 TSX CG W/NAV
I have not replaced mine yet, but I have a friend who purchased a JL XR set for his truck. I am planning to rplace my front speakers so for giggles, I took the tweeters out to my car. With the addl. trim ring they come with, they fit ABSOLUTELY PERFECT. At first they looked to be a hair to big, but pushed them a tiny bit and they wedged into the hole perfectly. Since there is a little lip there, the trim ring basically was completely flush with the dash. Sorry I didn't take a pic.
Old Apr 12, 2007 | 10:31 AM
dizzy1's Avatar
I have JL XR tweeters in the factory housing, perfect fit. Just used a little shoe goo on the backside of the tweeter to keep it from vibrating out. Sounds great!
Old Apr 12, 2007 | 03:02 PM
how do you get to your stock tweeters? and what size is the stock tweeters?
Old Apr 13, 2007 | 08:21 AM
bullyx2's Avatar
'05 TSX CG W/NAV
Use a tiny flat headed screwdriver (jewelery type) and pry very carefully.
Old Apr 13, 2007 | 09:29 AM
jlukja's Avatar
Hint: wrap it in electrical tape, less of a chance you'll scar the trim.
Old Apr 14, 2007 | 01:39 AM
tsx_boy
Dec 13, 2019 08:33 PM
mlody
Dec 4, 2019 02:11 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ceb
ILX
Sep 27, 2015 10:56 AM
