TSX factory audio amp help!
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Hi all recently my audio amp fuse keep blowing out on me. I've check all the speaker to see if they were touching any ground but they were fine. So my next concern is the amp...So far I'm too busy at work to take the center console off to check the amp. Any advice if it isn't the amp would be much appreciated.
My 3 questions if my amp is blown is
1) where (besides acura) can i get a replacement
2) How much would it cost me?
3) what kind of upgrade amp can i use to replace it?
Thanks!
Thanks!
Are you out of warranty is the obvious first question, if not this is a dealer issue.
Sadly, I don't have much info on any replacement amps. My first thought would be just to get an aftermarket (better) amp wired in and call it a day before spending any money just to replace the tiny stock amp.
You can install a new amp using my harness and you will likely want to upgrade your speakers while you are at it. The TSX HU will work with only certain types of amps so if you want to go that route let me know before you buy.
As far as your factory amp it would cost about $100 or so to fix depending on what’s wrong. If you ship it to me I could give you an idea. It’s probably not worth fixing when you compare it to an aftermarket amp.
jeff
jeff
navtool.com
09-25-2015 05:15 PM
Pegon95
09-15-2015 01:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
