Touchscreen questions/Mac Mini Install
Old May 3, 2005 | 11:25 AM
chiTSX's Avatar
I would like to install a Mac Mini into my TSX without installing a secondary flat panel. I mostly want to use the stock TSX touchscreen for OEM appearances and to reduce the cost of this project. I am wondering if anyone has the following information:
1. Running a VGA/RCA/SVIDEO signal into the TSX LCD. I have seen RCA adapters that allow DVD/Video playback, but I am wondering if something for VGA exists.
2. What kind of I/O does the touchscreen use? From what i have seen on other touchscreens, this is either a serial or USB based connection, unless it's something proprietary on the TSX. I would like to know more.
I can find switches for VGA and serial; if that is all that is required, installing a Mac Mini will not be difficult. Then I would buy that SHOND adapter for the audio, although I am also planning on replacing the stock amp. I am hoping to either integrate the Mac Mini's audio-out into the TSX's stock system, or run a bypass/switch for an after-market amp. I will upgrade the stock amp at some point any ways, but if anyone has a better way to do this please share it with me!
I would like any information people have on PC installs also. Thanks!
Old May 3, 2005 | 11:46 AM
Jonesi's Avatar
For the video I would assume you can do the Navi conversion to add a video input to the screen..
Either way though the touch screen will not work for the computer.. Atleast I don't know of a way to keep it fully functional..
Old May 3, 2005 | 02:00 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ You won't be able to use the touch screen to control and/or interface with the Mac mini.
You should maybe consider something like this if you want touchscreen control:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Check if this will fit, but you can maybe mount this where the storage bin normally is. CCColtsIceHockey has a screen in that location. You should hit him up.
Does the apple mini support touch screen interfaces though?
Old May 3, 2005 | 02:52 PM
umcp's Avatar
i have put a pc in my car with a 7" vga touchscreen.
pm me if you have any questions. i'll be glad to help.
Old May 3, 2005 | 03:10 PM
Jonesi's Avatar
Tsx536 - Very clean and beautiful setup...!!
Old May 3, 2005 | 03:23 PM
chiTSX's Avatar
From what i have read about OS X, it has all kinds of built in drivers for touchscreens. It also works with all kinds of open source Unix based drivers, so i am not terribly worried about operating system functionality. However, knowing the interface type would help. I'm fairly sure it's serial though, unless anyone knows for a fact that it's USB. Thanks for all the good responses.
Old May 3, 2005 | 03:25 PM
chiTSX's Avatar
UMCP how does one find your private message? I'm not very familiar with this forum.
Old May 3, 2005 | 03:32 PM
dark inspire's Avatar
El Presidente
wow thats a slick setup!
Old May 3, 2005 | 03:39 PM
Jonesi's Avatar
Click on his username on the far left, it will bring down a scroll menu, select send private message
Old May 3, 2005 | 04:26 PM
umcp's Avatar
i've done a little research on the navi touchscreens in our acura's and have concluded that the t/s cannot be used with a pc/mac.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
TxRzrBk
Sep 17, 2015 01:07 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
