CL: Subwoofers + CF Trunk = FAIL?
I couldn't find this in a simple google search. I have 3 12" subs facing towards the trunk. Right now I need to replace my trunk. Basically will the subwoofers "damage" a Carbon Fiber trunk causing it to warp and become wavy?
if so WTF!? thanks
if so WTF!? thanks
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I'm sure it wouldn't warp the CF, only heat should be able to do that, however with enough pressure if you don't vent it, the air will try to find the weakest point of exit which could be your mounts or latch
Or, OP, you could just seal the trunk off from the cabin, and do a box that is front facing sub/ports. When properly sealed, that gives you the least amount of pressure in the trunk, and should get the loudest inside as well... However, you're going to likely have to take out the rear seat bracket...
my trunk is already done, i have 3 subs its just so much work to redo a custom trunk. i like it, but if i were to do it again, i'd throw in 2 10's or 2 12's and just do a simple box, but it would be facing up to "save" trunk space.
i'll take it into consideration.
In a hatchback or SUV, yes... From a trunk, it's not the loudest... Because if your sub is up, it's likely firing straight at the the trunk lid. This is the weakest point of the trunk, so you're going to lose a lot of SPL that way... On the other hand, sub/port forward and sealed off from the rest of the trunk is ideally the way to go. That way, you can build your box to spec, and you don't have to worry about losing pressure to the outside air as much. Also, you have less "stuff" in the way of the sound waves on their way into the cabin. Another thing is that you have a smaller space to pressurize so you need less cone area, port area, and power to get the same SPL out of the car. The only problem is that it would likely raise the peak frequency of the car, and if you're tuned low, this could cause a peak in music at certain frequencies... Nothing a good EQ can't fix though...
Im my younger years I had a 97 accord with a CF trunk, and I ran 2 12's facing back with 1000 watts and never had a problem with warping or cracking. Just make sure to use LOTS of dynamat or it will rattle like a bitch, the light weight aspect of the CF makes it prone to rattles.
CF will rattle bad with subs. Dynamat and new seals are your friend. Flip those around so they're firing at the rear of the vehicle - you'll get better resonance that way.
I had 2 rear firing 12s in my CLP, only on a little 4 ohm stable 2x250 Orion Cobalt - and it was enough to pound it home.
kb1rl
09-30-2015 10:17 AM
justin.w13.walker
09-22-2015 02:21 PM
