Subwoofer Wiring Question Please Help
Old Feb 21, 2004 | 12:19 PM
JD22CL's Avatar
Rollin to GT in da CL
Ok, well i got a new box which has seperate chambers for each sub because its a tuned ported box and for some reason has seperate chambers. This creates a wiring problem for me, before they were wired to a bridged 2 ohm load and it was great. If i wire each one to a one ohm load, and then bridge them outside the box, does that create a .5 ohm load or a 2 ohm load?????
Old Feb 21, 2004 | 03:00 PM
Vector02's Avatar
Just drill a hole in the center wall between the subs run your speaker wire through, and silicone seal it. Then you can run your same 2 ohm load.
With 2 4ohm woofers, you can run those speakers inline a few different ways...you just need to make sure that the speaker are inline.....don't make it harder than is has to be.
Old Feb 21, 2004 | 07:15 PM
SilverKnight's Avatar
Retired. Not available.
If you wired them in series, you will have 2 Ohm load.
amp - <=== - sub1 + - sub2 + ===> amp +
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
