Subwoofer phase
-S namyaC-
You mean subwoofer POLARITY, meaning reversing the wire at the terminals. Phase is a misnomer for that. Lots of manufacturers label a polarity switch as phase reversal too so it gets kind of confusing.
Like Titand19 said - you should be able to hear it. If you have two subs together and you flip the polarity of one - it'll sound like you almost unhooked them from inside the car (cancellation). You have the same effect with the mids-to sub but not quite as noticable. You should really play a song that has a nice rock beat (kick and snare). Now listen to it. Does the kick hit at the right time? Or does it sound off? For the general idea, I like to use the newer Creed CD, track #4 (I forget the song). It has an odd beat that makes it easy to tell when it's off. From there I check with some test equip, but that should get you close enough.
Now back to the phase thing. Your sub is probably at a right angle to your front stage unless you have HLCDs or kick panels. This puts the sub 90 degrees out of phase (basically it's a time thing, the one wave is shifted from the other). However, the extra distance the sub has to travel would pretty much make up for that (again a time thing) - but one polatity setting should sound the best, either normal or reversed (to line up the waves).
AndrewS
19
03-14-2024 06:59 PM
kb1rl
09-30-2015 10:17 AM
4drviper
09-23-2015 07:42 PM
3GTLOwns
09-09-2015 09:51 PM
