SUBWOOFER JL 8w7 Help
Old Mar 24, 2009 | 01:33 PM
hydeng90's Avatar
3rd Gear
I have a TSX 09 and as you know the stock sub is okay. but can definitely slap hella harder. especially with a 8w7. question is, will it fit? second of all, 1000 watts and 500rms 3ohms, will literally removing and replacing the stock sub work? (of course adding a stronger amp) and can the hole hold on this strong bass ? does anyone know or can give educated inputs to this thoeritcal upgrade? thanks
Old Mar 24, 2009 | 01:42 PM
mattastick's Avatar
You're going to be better off building an enclosure for a separate sub... This is due to the design differences in the drivers...
Old Mar 24, 2009 | 01:43 PM
TypeSinNC's Avatar
You can not just drop in a sub in place of the factory sub. Running a sub IB in our rear deck requires work to the rear deck, and making sure your trunk is completly sealed from the cabin. I'm not even sure if a W7 can be run IB, anyway...I have never seen anyone do it.
I'm guessing your wattage question means that the sub is 1000w MAX, 500 RMS, and single 3ohm voice coil?
Old Mar 24, 2009 | 01:46 PM
mattastick's Avatar
I think you're right about the W7 not being able to run IB...
Old Mar 24, 2009 | 04:38 PM
uncald4's Avatar
Former Sponsor
^^ These people lie to you man.
I would personally love to see you drop an 8W7 in the factory subwoofer hole.
Old Mar 24, 2009 | 05:59 PM
hydeng90's Avatar
3rd Gear
okay. im confused. uncald4, was that sarcasm or was that a statement knowing it is possible? thanks
Old Mar 24, 2009 | 06:35 PM
eggyhustles's Avatar
yes you can. possibility of it sounding like crap? yes, but you can drop it in.
Old Mar 24, 2009 | 06:37 PM
uncald4's Avatar
Former Sponsor
Sorry. I couldn't resist a comment. Thank you for allowing me the pleasure.
But seriously, do not entertain that idea any further. A W7 in a free air setting mounted to a thin piece of metal would sound as good as me kicking the back of your seat.
Your best bet is to remove that OEM subwoofer and install an aftermarket sub and enclosure in your trunk. You could get an amp, sub and enclosure for the same price as an 8W7. And it would sound awesome.
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
