Subwoofer Issue
Old Dec 15, 2005 | 09:09 PM
FL3.2TL's Avatar
Just chillen..
Subwoofer Issue
What's going on? In my previous car I had a 1 12" Kicker Comp VR, which I currently transfered into the TL. For the time being I want to have extra bass in my car, untill I dont get JL's. Im keep everything stock just adding the same woofer but im using the line outpout convertor.. I ran all my wires but I just have two questions.. 1st) Everything turned on, but subwoofer isn't working... The convertor is spilced into the sotck 9", but the 9" works, 12" doesnt. Any ideas?
2nd) I need a proper fuse location for the rem wiring to go.. I wanted to use a cigrate lighter but I couldnt find it, I checked on the fuse boc but nothing there. I believe its 12V you need.
1999 3.2 TL. Thanks!!
Old Dec 15, 2005 | 10:07 PM
CQ7String's Avatar
metalguitarist.org
I'm not quite following you. You're tapped into the input for the stock sub for the high-level input on your sub amp, correct? Or are you trying to drive the Comp VR using the stock amp, as well as the stock 9"?
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
3GTLOwns
Sep 9, 2015 09:51 PM
alan_rich
Sep 9, 2015 11:38 AM
