View Poll Results: Which Set Up To Go With
Current - Fosgate P3 with power Fosgate amp 500 watt
![](https://acurazine.com/forums/images/maestro/polls/bar2-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2-r.gif)
![](https://acurazine.com/forums/clear.gif)
33.33%
Re audio sub with current Forgate amp 500 watt
![](https://acurazine.com/forums/images/maestro/polls/bar3-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3-r.gif)
0%
Re audio sub with US Amp 2k watt
![](https://acurazine.com/forums/images/maestro/polls/bar4-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar4.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar4-r.gif)
66.67%
Voters: 3. You may not vote on this poll
TL: Subwoofer Advice
:( Harminder Is Lost In
Subwoofer Advice
Hey guys, i needed some advice. I currently hacve 2 12 inch fosgate p3 with a mono 500 power fosgate amp. I was recently offered a re audio subwoofer for a 100 bucks. My friend totaled his car so he said i can take it off his hands for a bill. Its a 12 inch re audio sx sub in a box. I love to take it becuase i will have more room in my trunk. He used to have it hooked to a 2k watt us amp. Should i take it? My system slams hard now. Ive heard the re and liked it. Nice and clean. What should i do? Keep current set up? Use current amp with new sub? New sub with new us amp??
I would take RE over Rockford Fosgate anyday. They're built well and they slam hard. Idk how one would compete with 2 P3s but I'm sure you wont be disappointed. Plus you'll probably gain a lot of trunk space.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I don't think you need 2000 watts, 1000-1200-1500 should be more than enough, but I say take the re amp
IIRC, US amps are numbered by the max watts they put out, not rms. So it would be ~1kw rms. Assuming you're at 1ohm, then you should be pretty solid. Just keep in mind that the US amp is going to draw more current, so make sure you have the electrical to support it, or you could be back to the Rockford in no time...
Personally I've tried many brands of round subs and then my friends and I switched to Kicker squares. One square 12 and people will think you have 2 15s in there. And you will have a trunk again, which I never cared about until I was older. 750 to 1500 watts for the L7 12" with the surface area of a 15", tuned or ported to your taste. Or the SoloX at 2500 rms in 12". I had 1 L712" in a 99 Accord and it was way too much. I stepped down to 2 round 12" and quickly left those at a pawn shop, re-installed the Kicker. Just my worthless opinion.
The SX is a much better sub than the P3. It'll get lower, louder, sound better, and handle more power than the P3. They're not even in the same class of subs.
Jonathan321, you've obviously never heard a good "offbrand" setup. Kicker's alright if you want something that's stupid loud but doesn't sound that good. They're kind of like the Alpine Type-R's. I was running an RD Alpha V2 12 on 1200w and I'd guess it was louder than your L7. If it wasn't, my rebuild will be...
soupi
14
11-15-2015 11:15 AM
kb1rl
09-30-2015 10:17 AM
