sub question
Old Jan 2, 2005 | 06:24 PM
glott's Avatar
sub question
my sub amp is wired from my 6x9's, also i have a switch installed that allows me to turn off the sub amp whenever id like to. the only problem i have is that the 6x9s are also switched off when the sub amp is off, why is this and how can i fix it???? id like to have my stock system running fully when the sub is off. thnx
Old Jan 3, 2005 | 12:22 AM
elduderino's Avatar
VP Electricity
Put the switch in-line on the sub remote to wire...
Old Jan 3, 2005 | 01:06 PM
glott's Avatar
the switch is in line with the sub amp remote turn on and does turn on and off the sub amp... i think it has to do with how the 6x9 are tapped to the amp...any other suggestions???
Old Jan 3, 2005 | 09:18 PM
musicbox's Avatar
2004 TSX
the amp is getting signal from the 6x9s, OR is the amp powering the 6x9s?
Old Jan 3, 2005 | 10:58 PM
glott's Avatar
as far as i know the amp is getting signal from the 6x9's, there is no way the amp is powering them , the 'tapped' lines are going to the amp input via the built in loc
Old Jan 4, 2005 | 12:19 AM
elduderino's Avatar
VP Electricity
any chance the by-nines are unplugged? When the sub is on it would push them around a lot and make them look like they are moving...
Old Jan 4, 2005 | 02:08 AM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ I bet that's it...Good thinking Eld!
Old Jan 4, 2005 | 09:10 AM
glott's Avatar
agreed, i will check it out today, my only indication that the 6x9s were on was a 'feel' test, which like you said could be affected by the subs anyway. thanks for the help everyone
Old Jan 4, 2005 | 12:33 PM
Tsx536's Avatar
Rep'n Taxbrain.com
To test it fully, you could also disconnect the sub from the AMP speaker terminal for a sec before you turn it on. That way you will only hear the x9s.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
