TSX: Sub install to factory h/u
Anyone know how to install subs in the factory h/u ?
Some people told me i need a adapter but idk if its true or not.
im trying to hook up a polk momo and a JL 1000watt amp. Lmk plz!!
I'm looking to do the same thing. The cheapest decent one I have found is at Amazon:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
$34 currently.
This site has better pictures of it:
http://www.sonicelectronix.com/item_...OEM-HON20.html
My understanding is that it should plug up directly to the head unit without any splicing necessary. Please someone chime in if I'm mistaken.
$34 currently.
True. Just to clarify for the next person searching, the PAC AOEM-HON20 is a plug and play solution that doesn't require any splicing.
Yes a speaker level to line level solution is cheaper.
a JL Audio Cleansweep is great for this. ive used LOCs for years and they always sounded like shit. the JL is a little more complex in the way it works, just google it, its a little more expensive too, but it makes it sound like you arent even using an LOC.
ive done over 50 cars with various LOCs over the last 15 years and nothing compared to the cleansweep. im not a jl nut hugger, your mom is my nut hugger. i know my stuff, i know what sounds good and what doesnt, just because its JL it doesnt mean shit, it could be alpine and i dont care, if it sounds good it sounds good.
let me rephrase the sound like shit part....you are stealing a signal from spliced wires when you use these and you rarely get a clean signal when you do this. there is no bass control except through your factory deck, it doesnt sound like it would when you run it through aftermarket.
Lots of bad information here,
You do not have to splice any wires to add a sub to the TSX, just use a pair of Honda speaker adapters (98 and up). Unplug the 6x9s and connect the adapters, easy.
If your amp has speaker level inputs then just run speaker wire from the adapters to the amp, easy, but your amp must be able to handle 10 volts or more at the inputs or you will clip like mad.
If your amp can’t handle 10volts (the JLs only go as high as 8v if I remember) then you need a pair of high powered LOCs. Hi powered LOCs are designed specifically for connections to decks and amps that use BTL (like the TSX amp). Using a standard LOC will cause distortion; this is where the “I’ve used LOCs in the past and they always sound bad” misconception comes from.
Using a clean sweep as a LOC is overkill, the clean sweep has the correct type of input for connection to the BTL speaker outputs but it is really designed to remove factory EQ which is not really needed here. Granted the Sub outs on the factory amp have a little bump in the response but there are so many variables with enclosure type and placement that it would hardly factor in.
So the OP needs a pair of 98 and up Honda speaker adapters and a pair of high power (25 watt min) LOCs designed for BTL amps.
I just need the ear plugs…
Jeff
Jeff
Alright I dont want to sound like a dumb ass or anything, so I do not need to remove the head unit at all? I just need to connect the rear 6x9 speakers to the LOC and then hook up any amp like how you would on any other car?
Jeff
Jeff
Thats one route. But like I said I've used a cheapo loc and been fine. And my setups are by far superior to most here.
Any good car audio place will have hi powered LOCs (you don’t need the $100.00 type).
Jeff
this will work
http://www.crutchfield.com/p_142LOC8...=detailed_info
Brum Brum!!
I think this is me not know a ton about technical audio setups, but if you just use the LOCs and honda adapters like you mentioned to hook up an amp. Can those wires handle the load that the amp is drawing? I always thought there needed to be a giant 10 guage wire(for example) going from battery to amp. Thanks for the clarification for the noob (me)
The LOCs and adapters do not supply power to the sub amp and you will just need basic RCA cables to connect the LOC(s) to the amp input(s). All the LOCs do is lower the voltage level from the speaker wires to something in the amps input range.
Jeff
TLDude876
12-28-2016 03:18 PM
BoricuaTL
04-08-2016 01:08 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
asahrts
09-04-2015 05:55 PM
