Stock Sub HELP!!!
Old May 2, 2002 | 12:04 PM
Bfor3's Avatar
Stock Sub HELP!!!
Does or has anyone replaced just the stock SUB??? I think it's a 9" Sub or something?? I would love to replace it to save truck space!!! Plz HELP!!!
Also does anyone know how many watts the stock amp/eq has? 4x than 1x for the Sub! Thanks a lot.
Old May 2, 2002 | 12:26 PM
Here is the anwer to your stock sub replacement question:
Kicker RMB8
Enjoy!
Old May 2, 2002 | 08:53 PM
randomwalk101's Avatar
I read from a car magazine that Blaupunkt came out with a super slim sub that sounds better or equally good as regular sub....Should be a direct replacement for the stock sub unit. Might be something to look into.
It's new so it's not on their website yet but you can call them ask inform about it. Get their number from their website at
www.blaupunktusa.com
Old May 3, 2002 | 12:05 AM
shawhite's Avatar
you might also want to check into the illusionaudio carbon series sub....the only thing with the kicker rmb8 is that it is a mid bass not a subwoofer.....so you will not be able to get a good low freq response.....if you are interested in the illusion audio sub....you can find it here....www.illusionaudio.com.....i have email the guys over there a couple times and i think this sub would probably work they do make a sub for free air applications as well....
Old May 3, 2002 | 01:52 AM
Bfor3's Avatar
Wow that's a lot of work!!! That stock sub looks like crap 4 sure! I guess I'll just do the tube in the trunk thing!!! Thanks all!
Old May 4, 2002 | 09:09 PM
SuperDave's Avatar
Illusion Audio subs are high-end but the company is no longer in business. I actually have the Illusion Audio ND12 that I am putting in the driver's side of the trunk in a custom fiberglass enclosure. Be careful in getting the ND8 as they make a sealed and freeair version. If you are replacing the stock sub or putting them in the doors, you would want the freeair version.
Illusion Audio
I have also purchased a pair of the Kicker RMB8 for use as midbasses in the doors. As was already mentioned, they are made for midbass reproduction and not as subwoofers.
Some other shallow subs to look at include the Morel WR-8 and the Morel HCW8. These are pretty highend subs in the neigborhood of $350-$400 a pair.
David
Old May 8, 2002 | 04:34 PM
AcuraTLDriver's Avatar
Question Fact of Fiction??
I've heard two different things. I heard that you can replace the sub only and add a 1-channel amp or the whole sound system needs to be replaced because it's a Bose system. Does anybody know for sure? I'm looking to add 1-12" JL sub with a H0 box with a Sony 150W Mobile ES amp.
Old May 8, 2002 | 11:09 PM
SuperDave's Avatar
Subwoofers usually get a mono signal since they aren't directional. Therefore, you can use a single channel amp or bridge a two channel amp into one. As far as I know you can replace the stock sub without changing the rest of the system. Just bypass the sub amp and you are golden.
David
Old May 9, 2002 | 09:12 AM
shawhite's Avatar
with a little knowledge and a helm manual you can basicly replace any part of the bose system you feel is inadequit.....i mean if you want you can replace just the door speaker......just the headunit......just the sub.....it all depends on your preference....i mean anything in the bose system can be bypassed to get the desired effect you are looking for....just my $.02
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
DerrickW
Nov 15, 2015 05:52 PM
rangomango
California
Sep 24, 2015 05:47 PM
