stock speakers make intermittent snapping sound
I saw a thread on this awhile ago, but I couldn't find it again using the search. I know this is normal, but I'd like someone to explain it to me. My speakers make a "snap" or electric "pop" sound (pretty quiet) every couple minutes regardless of whether the stereo is on or off. Someone mentioned that the sound is the AC compressor turning on and off. Can anyone elaborate?
What car? TSX I'm assuming based on the PM you sent me. Is the system completely stock? Have you added anything to it? Any mods that would affect the electrical system at all or anything drawing off of it?
Mine does the same thing
Jottle,
I have the same exact problem...yet every time I take it in to the dealership, they can never hear. Its very frustrating to say the least. Have you had any luck with fixing this problem? Any help would be much appreciated. Thanks.
Chris
Chris
Originally Posted by chouston75
Jottle,
Chris
Chris
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Did you have the techs sit in your car with you? I really think that in order to get anything done at the dealership, you have to have them there with you and specifically point it out to them. The techs and service managers purposely ignore sounds that they think they can't isolate and fix. Just read the stories here and on t s x c l u b.
Yup. I confirmed it. The snap sound happens when the AC fan turns off. Right after it turns off, not when it turns on. So it's tied to the electrical system. If I turn off the hvac, and the by necessity the compressor fan as well, no more snapping sound! anyone else out there have this?
I have it as well. I have replaced my entire system other than the stock NAV unit. I never noticed it with the stock system, but it very well could have been happening then as well. But like you, seems to be with the AC fan.
It looks like it's just the way they designed the electrical system, which is a real bummer
You'd think they would pay a little bit more attention to these things.
Still no solution. Anyone else notice this problem? My grounds are all good. The snap noise comes through the tweeters (subtlely) when the ac fan shuts off from running for a couple seconds.
its semi - common to have a turn on "pop" and some times a turn off "pop". but thats when intagrating factory equipment.
what did you do to check your grounds? i curious if the amp/radio shares the same ground point as the ac.. can anyone confirm this? if i a car in front of me i could be of more assistance. also is the tweeters ran through a passive filter like a single capacitor running in series with the tweeter?
AndrewS
19
03-14-2024 06:59 PM
Joseph Stansbury
34
12-04-2015 01:57 PM
alan_rich
09-07-2015 11:08 PM
