are the stock 6 discs really this horrible?
just bought an 03 cls6 with a broken head unit. dealer shipped me a used one with cd's stuck in it. got the codes for the original that has a broken screen and put that back in. put a cd in and it jammed right away. is this a common problem or what?
Yea they suck balls
I dealt with problems for months with my original until finally it wouldn't accept or eject any cd's. I got a replacement, which after less than a year is doing the same. Im still under warranty so I will get it swapped again, but then after than indash DVD here I come
the dealer said if i wanted to get an after-market head unit they would do that, but i would have to change all the speakers, being that it is a bose right?
It's not that bad IMHO. 3 CL's & only 1 had a jammed up player. It was fixed under warranty.
But I do hear of it more often on this board, but there are so many TL's with the same HU & you rarely hear of it from them.
Originally Posted by uncald4
That is false. You can use a PAC Audio OEM-2 to integrate into the BOSE system. This allows you to retain the factory amp and speakers. The OEM-2 is designed to use when installing an aftermarket deck into a BOSE or other amplified factory system.
where do i get a PAC Audio OEM-2? are they expensive?
am i better off with an after-market, the dealer will prob give me only $500. I think thats how much they spent on the broken replacement they sent me. just had to invest in some steelies and winter tires. cant spend more than the money i get from them.
SidhuSaaB
May 30, 2020 12:40 AM
