TL: Steering Wheel Buttons?
Old Jul 21, 2009 | 04:15 PM
Legault's Avatar
Hey everyone,
I'm putting an aftermarket head unit into my 00 TL and want the volume up and down buttons on the steering wheel to remain functional. I already know what to do, but was wondering if anyone knew the color code for the wires and/or where they're connected (Equalizer?).
Old Jul 21, 2009 | 09:55 PM
blazjusdj's Avatar
6th Gear
what brand of head unit are you putting??
Old Jul 22, 2009 | 12:20 PM
Legault's Avatar
I'm putting in a pioneer 3100 DVD system. It has an input for a wired remote which is where I want to route the volume up, volume down, and change preset (this will become a mute) buttons. All I need is for each button to provide the correct resistance when pushed and the system will perform the action it associates with that resistance. What I would like to know before I start the switch is what is the wire colors for those buttons are and where they enter the stock sound system. (If I know the colors I could probably figure that out) I would like everything planned in advance so I can do the whole switch rather quickly. Thanks
Old Jul 22, 2009 | 03:09 PM
blazjusdj's Avatar
6th Gear
I did the same yesterday but I've used Steering Wheel Control Interfaces swi-jack (for alpine....) you need to use swi-ps (pioneer.....) you can find it here: http://www.pac-audio.com/productDeta...&CategoryID=29 or look for it on amazon it is cheeper
Old Jul 22, 2009 | 05:55 PM
Legault's Avatar
Thanks for your response, I have actually seen those but the reviews said that they tend to lag. I figured this had something to do with the fact that you programmed a (probably slow) circuit as opposed to a direct interface. How responsive is yours?
Old Jul 22, 2009 | 07:42 PM
blazjusdj's Avatar
6th Gear
mine is quite slow, but I'm good with it
Old Jul 23, 2009 | 09:18 PM
Legault's Avatar
Yeah since its only three buttons I want to just do it directly with my own resistors as that should make it faster. So do you happen to remember what color the button wires were when you did the swap and do you remember if they went into the equalizer or the actual head unit?
Old Jul 23, 2009 | 11:15 PM
blazjusdj's Avatar
6th Gear
before I bought interface I took a part steering wheel control and there was 2 green/silver wires and then interface use only one (pin #3 on factory harness, check link I posted) maybe you need to use both I don't know
no equalizer
and just for the record I own 2003 CL type S
Old Jul 24, 2009 | 10:45 AM
Legault's Avatar
Yeah I think I'll take the controls apart when I get the chance and take a look at the buttons because I've also been assuming that they are just simple buttons. Thank you for your input.
Old Jul 27, 2009 | 10:55 PM
smACURAssCLS's Avatar
It is in pin #3. Usually a green wire with red stripe. The delay was done purposely so the vehicle doesn't immediatly send the wrong comand to the HU.
Old Aug 8, 2009 | 04:24 PM
tangsauce's Avatar
Mind posting a DIY when you're done. I'd rather splice a few wires than buy a $70 adapter.
Old Sep 2, 2009 | 07:38 AM
CLSspeedx's Avatar
I'd be interested in this also. I have my Kenwood Double-DIN I'll be changing over from my Accord to my new CL and really want to complete the buttons this time, as I was to lazy and cheap to buy the adaptor for the Accord. I figure it would be nice to have one less thing to fumble with as now I'll be shifting while driving too! Thanks.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
Charlespsu
Sep 2, 2015 09:54 AM
