Splicing regular wires into RCAs?...
I am installing two 4 channel amps in my car. I want to use the stock head unit, and bypass the stock amp. Since the head unit output is low level (3-5 amps) I can't use the speaker inputs on my amp, since it's designed for high input. So i am left with using the RCA inputs on the amp, which is low level inputs. So the only thing I can do is splice the regular speaker cables into the RCA cables. Do you guys think that it's okay to do, or is it a big NO NO?
Also, the second amp which I am gonna use for the SUB; do I use the outputs comming out of first amp? if yes which ones?
The problems that I have been having were very strong alternator noise, and hissing noice which can be heard when the music plays low. I bought two filters, and the alternator noise seemed to go away, but the hissing still persists.
I hope I gave enough info here for someone to give me some good suggestions and advise. Thanks.
East Coast Boost.!
If you're changing the amps and the speakers your system is being restricted by the stock headunit. It's still going to sound like bose crap with the bose unit. Sorry to tell you but that's the truth. You may not realize it now, but you will in the future. For example: I put in a new headunit before i put in new speakers and it makes so much of a difference as opposed to new speakers and amps.
If it's a faceplate you're concerned about there are a few people on here that will make or sell you one.
I'm not here to flame, just sounds like you want some serious stuff and a stock unit is not going to allow that. Another alternative would be to get a EQ, crossover or processer. Goodluck.
an adult perspective
Got da Internet Goin Nutz
To keep it simple...
1. Tap the lines BEFORE the bose Amp (between the headunit and amp, not the amp and speakers). The signal leaving the headunit is simple a preamp signal.
2. You will probably need a filter on the output lines. They should clear all noise. Check all of your grounds to clear noise too.
3. Your 4 channel amp may have a set of RCA outputs. If it does just run RCA's from the 4 channel amp to the sub amp. Your sub amp should have a crossover built in.
4. If your 4 channel doesn't have outputs just use a spliter to run signal to both of your amps.
5. You HAVE to replace your speakers.
5. The only thing gained in replacing the factory headunit is the extra's the comes with an aftermarket headunit (ie controls over this and that, extra EQ controls, soundstage adjustments and the like). I like to avoid aftermarket headunits so my car can have a stock appearance. To me aftermarket headunits in expensive cars just say that this person has something serious in the trunk.
Here you go
Pin #1 =BRN/BLK--Passenger Door speaker and right tweter (-)
Pin #2 =RED/GRN--Passenger Door speaker and right tweter (+)
Pin #3 =WHT/YEL--Constant Power
Pin#4=Not used
Pin#5=YEL/WHT--Radio Switch
Pin#6=Not used
Pin#7=BLK--Audio Unit Right Rear(-)
Pin#8=BRN--Audio Unit Right Front(-)
Pin#9=GRN--Audio Unit Left Rear(-)
Pin#10=ORN--Audio Unit Left Front (-)
Pin#11=Not used
Pin#12=BLU/YEL--Left Rear Speaker (+)
Pin#13=GRY/WHT--Left Rear Speaker (-)
Pin#14=BRN/WHT--Right rear Speaker (-)
Pin#15=RED/YEL--Right Rear Speaker (-)
Pin#16=BLK--Ground
Pin#17=LT GRN--Shielding
Pin#18=Not used
Pin#19=Not used
Pin#20=BLU--Audio Unit Right Rear(+)
Pin#21=YEL--Audio Unit Right Front(+)
Pin#22=RED--Audio Unit Left Rear(+)
Pin#23=WHT--Audio Unit Left Front(+)
Pin#24=Not used
Pin#25 =GRY/BLK--Driver Door speaker and right tweter (-)
Pin#26 =BLU/GRN--Driver Door speaker and right tweter (+)
You should tap before the amp on pins
7,8,9,10,20,21,22, and 23.
Pin#4=Not used
Pin#6=Not used
Pin#11=Not used
Pin#16=BLK--Ground
Pin#18=Not used
Pin#19=Not used
Pin#24=Not used
I forgot, on the wires mentioned before, the negatives get soldered to the outer connector of the RCA's (shield) and the positives get soldered to the center connectors.
Additionally, in order to bypass the stock amp you will have to disconnect the wires labeled for speaker from the stock amp and connect those to your new amp unless you are going to run new speaker wire.
hope the info helps you out.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
Joe Avesyan
09-29-2015 03:57 PM
MrHeeltoe
09-28-2015 05:43 PM
