TL: Speaker Size
Speaker Size
Im looking to get new speakers for my 03 TL I've never taken the door panel off and was wondering what size speaker do i need to get front and rear. Im looking to get JL Audio any suggestions on what models r good nothing to expencive and don't want cheap ones
If you don't want too expensive, don't look at JL... JL is extremely overpriced, imo.
I personally like the Pioneer TS-A and TS-C components. I'm going to be putting some Eclipse 3 way comps in my Celica this weekend, so I'll let you know how those sound.
Speakers are extremely user specific. So what I sounds good, the next guy to post may claim they sound like crap. So try to listen to as many different speaker setups as you can and then determine what you want...
This. Both of those would be awesome substitutes for JL. I would also suggest Bravox comps, but I doubt you'll be able to find any in the States, unless you're in Houston Texas...
Need more room in
Components for sure on the fronts.... coaxials for the rears (but really... with a good set of fronts properly powered, you dont need rears).
Please don't get suckered into buying JL's in the store. If anything order it online.... but if you're gonna order online.. i wouldn't even go JL's. FWIW
Alright I picked up a set of these hertz hks 165 component for the front and coax for the rear. Got home and took my door panel off and tryed fitting the speaker in looks like I need to make a spacer just wondering what size I need to make so everything fits and have the door panel fit back on
Need more room in
Dude, have you at least tried to put in some effort to get your answers?
I'd be more understanding if it was just written specifications, but Hertz has a frikken picture there for you.
![Name: Screenshot2010-04-27at91414PM.png
Size: 60.3 KB](https://acurazine.com/forums/attachments/audio-video-electronics-navigation-22/86522d1501791993-speaker-size-screenshot2010-04-27at91414pm.png)
Edit: Sorry for being harsh, guess I read it wrong. A 3/4" MDF spacer will most likely do the trick. You may need to cut the metal panel a little for basket clearance.
Well thats because they have shallow mounting depths, some of the top end conponents have large mounting depths which means they need big spacers and maybe some cutting..if you just had some reference pioneers then they fit good..
crutchfield.com shows 5.25" for front and rear on 2nd Gen TL(S)
Here too:
http:///forums/f38/exact-size-door-s...-2000-tl-8391/
.... plus a number of other sites as well....but some people say it's 6.5"
Now, I'm confused what's the stock size really, 5.25" or 6.5"?
I'm also looking to replace my stocks with components but I don't what to install spacers.
Can someone who knows, let me know the TRUE stock size and depth of the front and rear speakers in a 2002 TL-S.
Are you sure the speaker size is 6.5"?
Here too:
/forums/f38/exact-size-door-speakers-2000-tl-8391/
Here too:
built some tweeter pods what do u guys think still gotta work on sanding and filing in the pin holes
https://acurazine.com/forums/album.php?albumid=5493
Those Hertz will be a tight squeeze in the front. I used a 3/4" mdf spacer for my Phoenix Gold comps. There might have been 1/8" space behind them. I would start with some measuring tape and the windows rolled down of course.
6.5" works in most cases
Originally Posted by travs 2002 tl type
s;12000259
s;12000259
i dnt mean to thread hijack but how big r the rear door speakers
idk if its true but some 1 told me that there 6.25
Finally found the paint that matches the interior to paint my pods with. For the ppl looking for matching interior paint and live in CANADA i found this at canadaintire
![](https://acurazine.com/forums/members/032tls-205267-albums-tweeter-pod-5493-picture-left-tweeter-pod-30113/)
Not sure what you mean by top end, Pioneer does and always has made an excellent product. I've used them for 25 years and always been very satisfied. Why would I not use something thats a direct replacement for the factory bose units?
Pioneers arent a direct replacement. Bose speakers are 2ohm. Pioneers are 4ohm. You'd loose volume if you put these in.
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
