Speaker Self Install
Old Mar 10, 2004 | 04:40 PM
982.5TL's Avatar
All about JDM
Question Speaker Self Install
I know several people on the board have replaced their front and rear speakers, and i was wondering if any of you have replaced them yourself rather than having a shop do it.
How difficult is it?
Im sure the rear is gonna be a snap, but the front may be a little harder. I want to use the stock grilles to keep the stock look.
BTW im getting Polk db650 and db690. Getting them this friday, and plan on installing this weekend.
Any feelings towards these speakers? Are they pretty good?
Old Mar 10, 2004 | 07:02 PM
demons rage's Avatar
Installed my own.. both rear and front. Took about.. 2 hours to do it. Its not that hard, just that when ur replacing the rear speakers, have fun being cramped laying down in ur trunk
Old Mar 10, 2004 | 08:41 PM
TLBaller's Avatar
i havent bought components for my car yet..actually i did buy image dynamic components (6.25") and was going to let the place install it but they said they'd have to make that grill stick out. in other words, it wont be flushed. im still trying to figure out if 6.25 can fit in the doors with a special ring. 96TL once posted up a link to a place that sells these rings... ill need to look into it when i buy some diamonds
Old Mar 11, 2004 | 10:56 AM
96TL's Avatar
Ex-Mod
6.5's will fit as long as you either use the pre-fab MDF rings or if you modify the OEM basket.
Old Mar 11, 2004 | 02:03 PM
slownlow32tl's Avatar
Thats what I did all you need to do is cut out the back of the white plastic holder so that the magnet can fit. I did this with the infinity Kappa series 6.5 which has a pretty big magnet and i still have my fac. grill flush.
Old Mar 11, 2004 | 06:19 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Some speakers won't work even with modifying the factory plastic rear shield. I made my own mounting plate out of 1/2" mdf, just make if big enough to fit the speaker and with only small tabs at the corners for the screws, otherwise the door panel may not fit back on properyly.
Old Mar 11, 2004 | 06:58 PM
982.5TL's Avatar
All about JDM
How hard is it to remove the inner door panel?
Old Mar 11, 2004 | 10:00 PM
for the front speakers? not that hard
its just held together by all thse tabs.. once you take off one of the tabs, its a sinch.. putting it back on is a pain in the rear though xD
Old Mar 12, 2004 | 07:22 AM
Cornflake's Avatar
Reppin' the T-Dot!!
To remove inner door panel:
1. Remove screws under the little flaps in the door handle areas (2 - Lock/handle machanism and the pull handle on the armrest of the door).
2. simply pull the door panel off starting at the bottom, then lift it out.
3. To replace, follow reverse order. Note: it is easier to replace panel with the window down, as the top part has to slide in, and having the window up makes this more difficult.
Hope that helps!!
Old Mar 16, 2004 | 11:55 AM
982.5TL's Avatar
All about JDM
Ive got the back in. I need to know which wire is male and which is female. There is one "plug" with 2 wires attached and one with 1 wire attached to it. They both seem to be the same sized plug though, should i just use electrical tape?
Old Mar 16, 2004 | 09:07 PM
LDH's Avatar
LDH
I
What do you mean by which wire is male and which wire is female? or are you looking for positive and negative?
Old Mar 16, 2004 | 09:58 PM
982.5TL's Avatar
All about JDM
I guess i dont mean wire, i mean which lead on the speaker is male or female. I guess those correspond to positive and negative. Now for the wires, which one is positive and which one is negative? Like i said earlier, one connector has 2 wires in it while the other has only 1.
Old Mar 16, 2004 | 10:21 PM
982.5TL's Avatar
All about JDM
Nevermind, i got it. They sound great! Even with the stock head unit, i cant wait till i get a new headunit that supplies more power. All i need to do now is the install the fronts and im good to go!
Old Mar 19, 2004 | 04:15 PM
982.5TL's Avatar
All about JDM
Hope that helps!!
That helped big time. Thanks. Just put the fronts in today, they just fit in the factory speaker basket. They sound awesome. Thanks for all you help.
Again I bought the Polk DB 690 and 650. I reccomend them!
Old Mar 19, 2004 | 08:12 PM
once u get a new headunit in.. you're gonna love it
Old Mar 21, 2004 | 01:29 PM
982.5TL's Avatar
All about JDM
I bought a CDA-9807 today and will get it installed soon, i may end up doing that myself too. Im excited!
Old Mar 21, 2004 | 03:16 PM
LDH's Avatar
LDH
I
thats a great headunit my friend has one in his integra..you should install it yourself it isn't that bad. I still need to install my hu but i havent gotten around to buying a dash kit yet It's pretty simple to remove the headunit..its just a few clips for the woodtrim but be very careful around the headunit because its really easy to break the clips and then 4 screws around to take out the unit.
Old Mar 22, 2004 | 07:34 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Yeah, pretty simple. That whole piece of wood trim around the head unit and temp controls comes off (the temp control comes with it), then just unscrew the radio screws. You will need the dash kit to mount the radio and of course, Get the wiring harness. Also, the sound system is amplified externally so you will have to run new soeaker wires to the speakers in the car from the new headunit. You can use the factory wires for the power, ground, etc. though.
Old Sep 26, 2008 | 02:50 PM
Carter31's Avatar
Man i wish youve waited for some one to explain, cause im stuck right there. I dont know which one is positive and which one is negative. I just got some pioneer speakers, and I am trying to install them.
I dont understand what to do with the plastic clip that has the two red wires, and one brown wire.
Can anyone please tell me what to do with it? Thanks.
Old Sep 26, 2008 | 03:48 PM
TLin401's Avatar
'13 Hyundai Sonata
But some harnesses that will fit into the factory harness so you don't have to cut the wires. I got mine from Best Buy for like $8.
Old Sep 26, 2008 | 05:35 PM
vas25tl's Avatar
The Box
Or you can just push the wires in and secure them with electrical tape....I was stuck in a shop with no store nearby and that's what I ended up doing, works fine
Feb 25, 2020 09:57 AM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
alan_rich
Sep 7, 2015 11:08 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
