spark plug wires?
Old Feb 16, 2004 | 01:45 PM
nujunglist's Avatar
El Donko of Punchstania
spark plug wires?
I got some shit installed a while ago and I have a bit of a high pitched whistle coming through my speakers when the car is running. When the car is just idling, you dont hear the noise until about 4k RPMs. When I am driving the noise starts at about 2k RPMs, and gets louder the higher they get.
I had the guys at tweeter look at it, and they redid the ground connections, and made sure that the rca's and power and ground cables were all as far apart as possible. It didnt help. One of the intallers told me that replacing my spark plug wires would probably help.
Has anyone encountered this before? Could anyone give me a little more insight on how to get rid of this annoying whistle the drills into my brain while I am driving?
Thanks.
Old Feb 17, 2004 | 05:49 PM
nujunglist's Avatar
ok come on now, none of you motherfuckers know anything about this? proaudio22 help me out here yoda of car audio!
Old Feb 17, 2004 | 07:15 PM
wilp99's Avatar
u can try sparkplug wire or u can add another ground from your battery to the chassy. just a 8" piece of 4 guage wire with two female ends. cheaper than wires and it cant hurt.
Old Feb 17, 2004 | 09:47 PM
proaudio22's Avatar
-S namyaC-
Originally posted by nujunglist
yoda of car audio!
Commercial audio, commercial! I just like cars.
How long are the grounds from the amp to the chassis? A friend of mine's car whined like a biatch. Shorted the grounds from ~4ft to prob a lil over a foot cut it out. I'd really have to see your car. The more describing you can do, the more guessing we can do.
Old Feb 17, 2004 | 10:40 PM
JD22CL's Avatar
Rollin to GT in da CL
Hey
I got the solution for you, ive got the same problem. It is based in your ground wires and the signal is created because of the rcas that go to your external amp for you speakers. Go to radio shack and get two "rca ground loop isolators" and it should clear your problem up.
Old Feb 20, 2004 | 03:39 PM
nujunglist's Avatar
quick update...I got some Crane FireWire spark plug wires off of www.optauto.com and installed them today. NO MORE NOISE COMING THROUGH MY SPEAKERS!!!
Old Feb 20, 2004 | 07:59 PM
nujunglist's Avatar
nevermind...just went out to pick up some chinese food about an hour ago, and the noise is still there. F@@%%&!!!!
Old Feb 21, 2004 | 10:44 AM
Hobo's Avatar
Flap.
lol
that sucks
it is almost certainly a ground issue, so replace and make sure that the current ones are as short as possible and clean
Old Mar 3, 2004 | 07:27 PM
nujunglist's Avatar
Originally posted by JD22CL
Hey
worked like a charm. thanks.
Old Mar 3, 2004 | 10:57 PM
SilverKnight's Avatar
Retired. Not available.
This is the simplest solution. Ppl would say the ground loop isolators degrade your signal. Unless you are a hardcore competitor or judge with trained ears, you would not notice the loss in your frequencies. These ppl are at most 10% of the population.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
