Sound System Redone and Now Completed
Old 06-10-2004 | 02:53 AM
olicuzTSX's Avatar
This is an update to my earlier post I did a few months back:
http://www.acura-tsx.com/forums/showthread.php?t=8294
Since then, I have relocated my MTX mono sub amp from the back seat location to a custom board setup in the trunk next to the Kenwood amp. Also, I have added two 1/2 farad capacitors to each 4 channel Kenwood amplifier and I relocated my 1 farad capacitor from the back seat. These capacitors can"t be seen because they have been installed behind the amp board that the Kenwoods sit on so as to make sure that as much wires are hidden as possible.
This is where I had the MTX amplifier mounted before(I didn't like the mess of wires poking through the fabric):
This is what it looks like now(the capacitors are hidden behind the Kenwood amp boards):
Old 06-10-2004 | 03:20 AM
slo007's Avatar
Master in Science
What effect do the capacitors have? I've only read bad things about them.
Old 06-10-2004 | 05:07 AM
pansuria's Avatar
Pretty sweet setup. I'm wary of putting a sub in my car because I actually use the flip down seat feature in the TSX once in a while.
If I went with new front speakers & an amp for them, is there a way I can have an installer mount an amp next to the Navi DVD system? That area up there seems to be out of the way and unobtrusive.
Old 06-10-2004 | 11:16 AM
olicuzTSX's Avatar
slo007
I had the capcitors from my old car and I just wanted to reuse them. At the time I wasn't too sure of where to mount them until just recently. In theory, the capacitors are supposed to help improve the power required to an amplifier whenever a peak in music occurs. Rather than trying to get power all of the way from the battery (a long distance) during a musical peak, the capcitors help in that the amplifier can get power from a closer source during the musical peak. I haven't heard anything bad about them just that people are unsure if they help out or not....but from my experience, I am not taking them out
pansuria
I think somebody already did that somewhere on this forum. Looked prettty sweet. You would have to do a search for it.
Old 06-10-2004 | 11:56 AM
gfxdave99's Avatar
6MT Snob
You could also build an amp rack so the amp would mound underneath the rear deck
Old 06-10-2004 | 02:46 PM
olicuzTSX's Avatar
You could always mount the amp on the side of the trunk like I did. This way, if you ever needed the fold down seats, you could use them without worrying about damaging your amplifier from being mounted on the back of the fold down seats. You would just have to remove the subs first.
Old 06-10-2004 | 02:55 PM
musicbox's Avatar
2004 TSX
Don't lick them!
I've run caps in a few of my installs, but I never "added" them, so I don't have a before and after to share. but I never had any problems with them...
Old 06-11-2004 | 09:45 PM
TSXSTI's Avatar
Not only do the caps act as an intermediate power source, but can also be used as a low pass filter when an audio signal is run through them. I think an inductor acts like a high pass filter but can't remember for sure
Old 06-11-2004 | 10:28 PM
elduderino's Avatar
VP Electricity
Actually, a series capacitor acts as a high-pass filter (filters bass). A series inductor acts as a low-pass filter (filters highs). (Assuming there are no other parts in the filter.)
The idea behind the stiffening caps is to "stiffen" the voltage during peak draws, for amps which do not have tightly-regulated power supplies. For amps with highly-regulated power supplies, caps do not help.
Old 06-12-2004 | 12:49 AM
Mokos23's Avatar
well now, congrads!
the radio reception must be a lot better now, better than whatever stock system acura put in the TSX.
Old 06-12-2004 | 02:20 AM
olicuzTSX's Avatar
04EuroAccordTsx
Hell yeah!! Everything sounds ten times better than before, especially with full range being played out of the rear speakers
rockyboy
08-04-2024 11:35 AM
mada51589
05-03-2022 09:54 PM
02-25-2020 10:57 AM
jpadilla
3G RLX (2013+)
11-18-2017 08:13 PM
