something wrong with my tweets
Old Jul 29, 2004 | 04:15 PM
acuratsx03's Avatar
Future Seminole
just recently ive been hearing my alpine type r tweeters start to make an odd cracking clicking sound, specially when i play rock music. im not sure if i blew them or not, i dont think i did, but the noise bothers the hell out of me and i cant stand it. the tweets are part of the component set but i dont have the 6 1/2's or xovers installed. maybe the xovers will help this? anybody have any ideas why my tweeters are doing this?? any help is appreciated. thanx
Old Jul 29, 2004 | 04:18 PM
jiggaman's Avatar
I spend 2 much time here
you using the factory amp?
Old Jul 29, 2004 | 04:20 PM
elduderino's Avatar
VP Electricity
Possibilities:
1) Blown tweets
2) Clipping amp (as Jigga said, factory or aftermarket?)
3) Clipping the front end of the aftermarket amp IF you have a line driver...
4) Amp clipping due to instalaltion-related voltage drop (does it do it on bass notes?)
Old Jul 29, 2004 | 04:21 PM
jiggaman's Avatar
i doubt that that tweeters are blown.
Old Jul 29, 2004 | 04:46 PM
elduderino's Avatar
VP Electricity
oh... make it on all sources?
Old Jul 29, 2004 | 04:59 PM
acuratsx03's Avatar
Future Seminole
im running the stock amp, so maybe its that? anyway to pinpoint the problem more accuratley... maybe id be better off replacing the stock amp to power the 6x9s, tweets and doors?
Old Jul 29, 2004 | 05:54 PM
elduderino's Avatar
VP Electricity
While it is very possible that the stock amp is either running out of power or in some other fashion having a problem, here is my first question:
1) Did you use the xovers that came with the Alpine seperates? Or did you simply connect the tweeters in place of the stock tweeters?
Old Jul 29, 2004 | 06:52 PM
acuratsx03's Avatar
Future Seminole
just swapped em... crossovers are still sitting in my closet with the 6 1/2s
Old Jul 29, 2004 | 06:56 PM
elduderino's Avatar
VP Electricity
Just re-read your original post.
Your tweeters may be blown. I believe that they have been playing too much midrange. You state that you did not use the xovers that came with them.
I believe that the TSX amp is a Front/Rear/Sub six-channel amp, and that the tweeter outputs are actually the same signal as the mids, only with a series capacitor on them.
We know that the doors aren't band-passed (i.e., with both the lows AND highs taken out) because when people put coaxials in the door, they play high notes (so the highs aren't being taken out by any crossover).
So I suspect your tweets have been playing with a capacitor first-order 6dB/octave crossover. (Even if I am wrong, we can assume the crossover is still not the right one for those tweets...)
If this theory is correct, the crossover point could be wrong (since the tweeters probably have different impedance curves) and the crossover filter slope would be too gentle (i.e., midrange would be too loud, forcing the tweeter diaphragm to try to move too far).
Maybe they haven't blown up. To find out AS A TEST take the wires at your tweeter and connect them to the input of your xover, and connect the tweeter OP of your xover to your tweeter, and play the system and listen to that tweeter (disconnect the other one). Do not leave it this way... this is just a test.
If that sounds OK, the real long-term solution is to install the xovers in the center console by the amp. Run the F mid wires into the xovers, and then cut the tweeter OP wires at the amp and connect them to the tweet outputs of the xover
Always use the xovers that come with, unless you are going with a complex active system that you control.
Old Aug 2, 2004 | 12:58 AM
elduderino's Avatar
VP Electricity
What's the determination?
Old Aug 2, 2004 | 01:09 AM
acuratsx03's Avatar
Future Seminole
so far ive just kept the music down. im gonna take it to my friend who installed my system to see what he says, though i pretty much believe everything you say. were gonna first disconnect the tweets to make sure its them, which i am 95% sure it is them thats making the horrid sound. after that ill probably install the xovers and pray that the tweets are not ruined... ebay buying has come back to bite me in the ass... we'll see about that though now wont we. anyways, thanx a lot elduderino, your input has been 0-so-valuable and it is much appreciated. you are def. one of the top audio guys on this board. thanx and ill let yo know how it goes
Old Aug 12, 2004 | 09:18 PM
esk's Avatar
esk
I've had my car a few months and still have the stock radio. I also get crackling sounds from the tweeters when playing certain rock music. Hope it's coming from the amp and not the head unit. It also seems to be prominent on the pasenger side of car. Come to think of it, it's usually softer rock (Rolling Stones) and I need to turn the volume past 30. When I play Korn I can't turn it up past 20 without getting a headache.
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
rangomango
California
Sep 24, 2015 05:47 PM
