CL: Someone Please Explain this to me...
Old Aug 30, 2012 | 11:56 PM
4ank's Avatar
I found this great article in the DIY sticky but I am terribly confused at this one section that says...
"Connect 4 speaker wire to amp outputs (these will be connected to the inputs of the aftermarket amp) and 4 speaker wires to the speaker input (these will be connected to the outputs of the aftermarket amp.). Locate the remote wire and tap into it (do not cut it since the factory amp needs it)."
Link to article
http://web.archive.org/web/200307131...net/sound.html
What is this saying? I am installing a mono amp + sub and I am thinking I need a line out converter. If someone could explain this (maybe in color code) it would be a huge help. Also, which color is the remote wire? Yellow/White?
Old Sep 1, 2012 | 05:14 PM
4ank's Avatar
Man, not much action over here anymore. Alright, so let me put it this way.. did the guy who made the DIY cut the speaker wires and run them through the aftermarket amp?? That's the part I don't really get.
I'm looking to do the same thing only with a mono amp/sub and believe I only need to tap into the rear speaker wires.
Old Sep 3, 2012 | 02:20 AM
Skirmich's Avatar
Before I Switched out the OEM Stereo I had a Line-To-RCA converter from the Sub Wires. There must be 4 wires going into the subwoofer convert them to RCA.
Old Sep 4, 2012 | 10:44 AM
4ank's Avatar
Yup, that makes sense, thanks. That is what I am planning on doing as well just want to clarify that I do not need to cut the rear speaker wires and instead just tap into them.
knight rider
Mar 4, 2016 08:59 AM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
atsx1313
Sep 22, 2015 09:04 PM
