So I order the Pioneer RGB1
Old 12-05-2001, 10:36 PM
The Creator
soopa's Avatar
found a place that had one in stock... should be here soon.
my boys at APG will be tackling the install...
Were gonna see if we can get audio without an RF modulator...
Old 12-06-2001, 08:41 AM
mcdanjw's Avatar
Join me in the 'no RF modulator' club! Sound quality is king!
You're gonna love this mod!
It blows people away too...
Old 12-06-2001, 07:04 PM
Evil Bob Knieval
Rescuer's Avatar
i'm going to look into other ways too. i havent installed the RF modulator in my car YET, but i'll definately check out the other things
something else too, is to check out the 4pdt RELAY to run less wires
Old 12-06-2001, 07:29 PM
Caddy©'s Avatar
Re: So I order the Pioneer RGB1
Ok, educate me: what's an RF Modulator ?
Old 12-06-2001, 07:48 PM
kensteele's Avatar
Click here to buy 4PDT switch.
I use the RF modulator and it works well for movies (mostly talking) and even for the music videos that are done well.
How do you plan to do this w/o playing thru your car stereo? External speaker?
Old 12-06-2001, 08:44 PM
Got da Internet Goin Nutz
bl^5's Avatar
Anti RF
caddy,
An RF modulator plays an aux. source through your fm radio (ie tune into 88.7 and listen to aux. source). The problem is that the quality through the RF is mediocure(sp?).
kensteele,
You can do it buy putting a switch in between your amp and your headunit. You can then switch between the headunit and an auxillary source. Sony has one (XA 39) and you can probably make one with those 2 leftover switches you have. Believe me, what you are hearing right now is horrible compared to a direct input. The only downside is the lack of an EQ for the aux input (unless it has one built in). I have the sony switch and it is an upgrade from a RF modulator, and I enjoy it so much.
Old 12-06-2001, 08:50 PM
Crazy Bimmer's Avatar
anyone know where i can buy the pioneer RGB1 online?
Old 12-06-2001, 11:32 PM
mcdanjw's Avatar
Re: Anti RF
Originally posted by bl^5
caddy,
BLING BLING!
Old 12-06-2001, 11:36 PM
Retired. Not available.
SilverKnight's Avatar
From the below schematic, when you turn on the head unit, the current going throught the coil in the relay will switch the inputs to blue so the signal the amp is from the Head unit. When you turn off the head unit, the electromagnetic loses its magnetic characteristic, so the poles go back to their original position (red) thus change the inputs to DVD player.
This is how I wire my system. Let me know if there is anything unclear.
I think Sony is gonna sue me for damages.
4PDT relay from Radio Shack: $7.99
6 Phono out jack board from Radio Shack: $2.99
Solder everything together: 30min.
Listen to your system directly (not via RF Modulator): Priceless.
tsx_boy
12-13-2019 08:33 PM
gatrhumpy
19
12-31-2015 04:22 PM
xsilverhawkx
09-28-2015 06:51 PM
jmaxima03
09-27-2015 10:22 AM
Eggs999bacon
09-24-2015 10:08 AM
Quick Reply: So I order the Pioneer RGB1
