simple question
Old Nov 27, 2003 | 06:50 PM
green972.2's Avatar
simple question
is it possible to hook up a home dvd player in your car with the use of a power inverter?
Old Nov 27, 2003 | 07:55 PM
pimpedcl's Avatar
luvs my cl!!
yes
Old Nov 27, 2003 | 08:11 PM
Titand19's Avatar
East Coast Boost.!
yeah, I was wondering also, but can home dvd players withstand the heat, the cold and the vibration.
Old Nov 27, 2003 | 09:19 PM
proaudio22's Avatar
-S namyaC-
Depends how well they are built Titand19.
Also, about running on an inverter, the unit must have a nice power supply. Most inverters output a modified sine wave. If the unit has a poor converter, it will only recieve about 80 volts - same as if you plug a normal mulit-meter into an inverter, it will read 30-40 volts less. If you hook up a true RMS meter to an inverter however, it will read the correct voltage.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
