simple question
-S namyaC-
Depends how well they are built Titand19.
Also, about running on an inverter, the unit must have a nice power supply. Most inverters output a modified sine wave. If the unit has a poor converter, it will only recieve about 80 volts - same as if you plug a normal mulit-meter into an inverter, it will read 30-40 volts less. If you hook up a true RMS meter to an inverter however, it will read the correct voltage.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
rboller
09-23-2015 02:49 PM
