Secret Navigation Menu
Old May 28, 2003 | 12:20 AM
9th Gear
Question Secret Navigation Menu
I believe there was talk a long while back about a secret Navigation menu, that would enable the changing of colors on the Navigation screen, view the satellites that are currently active etc.
The way to reach there, was by pressing 3 buttons simultaneously while switching on the car or something along those lines.
I have been trying all kinds of combinations with no success in my 2000 TL. A long time back, I had definitely gone into that menu.
Any idea what are the 3 buttons that need to be pressed and how to go about entering the "secret menu" ?
Thanks in advance.
Old May 28, 2003 | 10:45 AM
fla-tls's Avatar
On the way!
From the menu, the top two and then the fourth one down. It should be done in that order 1, 2, 4 (very quickly) and hold until the screen changes.
Old May 29, 2003 | 10:32 AM
9th Gear
Thumbs up
Thanks ! I will try it out today.
Old May 29, 2003 | 09:17 PM
9th Gear
Thumbs up
Yup ! It works.
Old Jun 3, 2003 | 08:43 PM
njacura32tl's Avatar
will this work on 99 tl
Old Jun 7, 2003 | 09:36 PM
Got_3.2?'s Avatar
nice ill hve to try that.
Old Jun 8, 2003 | 10:21 AM
rmarin2's Avatar
I tried it but I can't get it to work, the screen changes too fast. Also, you mean to press 1,2,4 on the menu items, not the buttons on the right by the joystick right?
-Rich
Old Jun 9, 2003 | 02:58 AM
dordal's Avatar
no, you press the buttons above the joystick. press (and hold) menu, map, cancel, in that order. Hold all three for a few seconds, and the diagnostic menu will come up.
Old Jun 9, 2003 | 06:53 PM
fla-tls's Avatar
On the way!
As dordal said, it's the buttons on the right side of the screen.
Make sure you start from the main menu. I've had problems if I tried it from that map or anywhere else.
Old Jun 10, 2003 | 11:38 AM
fegbri's Avatar
I did it, but there is no place to change the colors? Any info?
Old Jun 10, 2003 | 01:13 PM
Onerastaman's Avatar
Ialso followed the instructions listed above. When, I got to the menu, i didn't know where to go from then. Can anybody shed light on what happens next?
Old Jun 10, 2003 | 08:04 PM
EmuMessenger's Avatar
Worked for me and there was a place to change colors, but would have to go back to remember the screen name.
Old Jun 10, 2003 | 08:59 PM
Got_3.2?'s Avatar
i got to the screen to change the colors but when i press set it dosent set.
Old Jun 11, 2003 | 02:23 AM
rmarin2's Avatar
I just did it and it works. I'm still figuring things out, but in order to make the color stick, you need to manually change the red, green, and blue values from that same screen. Then press set and the colors on the map will change. Not sure if there is a way to make the menu colors change though!!
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
